imajor Posted September 16, 2011 Posted September 16, 2011 It don't have to be as good as the trucks used on the TT competitions. I think most clients don't even know about these competitions, Quote
raus Posted September 16, 2011 Posted September 16, 2011 Hello everybody. Maybe someone has seen my Lego Rock Crawlers. So I would like to espresso my opinion. Xl rather put up with engines torque to a crawler, but without speed control. Lego impossible for universal joints do the work, so the project has to be an XL in each axle independently. The buffers need to be articulated attachment points and the suspension arms have to be more rigid and better fixation. And the foremost of all, impossible to climb rocks with existing Lego tires! The rubber is very tough. I made a model with the changes needed to walk like a rock crawler: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=448931 And I did one with original http://www.brickshelf.com/cgi-bin/gallery.cgi?f=481962 and videos Get your conclusions Quote
Meatman Posted September 16, 2011 Posted September 16, 2011 Very Cook Rock Climber! Looks very lightweight. But Like Paul had said yesterday. This new Lego set is going to more than likely be a large one at the price that we are seeing. It is going to be very interesting to see what the designers at Lego have come up with. Quote
allanp Posted September 16, 2011 Posted September 16, 2011 I think it's entirely possible that we COULD get an RC 180 euro rock crawler that can actually climb over rocks outdoors, just not so much with the current motors and gearbox parts. So the thought of it is actually getting me quite exited although I know I should not get my hopes up for thes new parts based on the info we have so far. Quote
imajor Posted September 16, 2011 Posted September 16, 2011 What is the problem with the current motors? Quote
allanp Posted September 16, 2011 Posted September 16, 2011 What is the problem with the current motors? Well you asked, so be prepared to once again be bored to death reading one of my usual rambles The M motor is not strong enough for this thing and the XL motor is too slow and creates too much stress. What you end up with is a model that breaks gears whilst going very slowly. That you need is a motor that can deliver lots of power (more than the XL would be nice but not needed for this) but does not put too much strain on key parts. This can be done by having a motor with much higher rpms, and less torque. Basically a motor that's powerful but has absolutely no internal gearing down. Non at all. Like the 9v motors of 1996 and older, just a bit more powerful of course! Then we can apply our own gearing that is suitable for a gearbox or whatever we want, and also protect parts using the white clutch gears. So not an XXL motor, but an L motor. I think what is also needed is a differencial that can fit into the 5x7 frame, but instead of being driven by a 20t double bevel gear, is driven by a 12t single bevel gear (so the diff itself has a sort of hollowed out 36t double bevel gear instead of a 28t single bevel), and can also have 4 gears inside instead of three. The gears going to the wheels could possibly be the 20t single bevel instead of the 12t single bevel. This would effectively more than double the gear reduction of the diff (by having 12t to 36t instead of 20t to 28t) and triple the the amount of torque it can deliver to the wheels. Of course other parts will need to be beefed up and redesigned to deliver more power more efficiently and more reliably but with a new L motor and diff, you are halfway to making pretty epic RC vehicles, all out of plastic! Of course we can't just add more volts and more amps until we get what we want, this would just wear and melt things too fast. Thing is the XL motor already has the power. But with it's internal gearing and the current parts selection it can't be used efficiently. I see the Unimog with it's portal hubs designed to take an 8t and 24t gear to increase the power to the wheel as a step in the same direction i'm talking about. Quote
mind storm Posted September 16, 2011 Posted September 16, 2011 Well you asked, so be prepared to once again be bored to death reading one of my usual rambles The M motor is not strong enough for this thing and the XL motor is too slow and creates too much stress. What you end up with is a model that breaks gears whilst going very slowly. That you need is a motor that can deliver lots of power (more than the XL would be nice but not needed for this) but does not put too much strain on key parts. This can be done by having a motor with much higher rpms, and less torque. Basically a motor that's powerful but has absolutely no internal gearing down. Non at all. Like the 9v motors of 1996 and older, just a bit more powerful of course! Then we can apply our own gearing that is suitable for a gearbox or whatever we want, and also protect parts using the white clutch gears. So not an XXL motor, but an L motor. I think what is also needed is a differencial that can fit into the 5x7 frame, but instead of being driven by a 20t double bevel gear, is driven by a 12t single bevel gear (so the diff itself has a sort of hollowed out 36t double bevel gear instead of a 28t single bevel), and can also have 4 gears inside instead of three. The gears going to the wheels could possibly be the 20t single bevel instead of the 12t single bevel. This would effectively more than double the gear reduction of the diff (by having 12t to 36t instead of 20t to 28t) and triple the the amount of torque it can deliver to the wheels. Of course other parts will need to be beefed up and redesigned to deliver more power more efficiently and more reliably but with a new L motor and diff, you are halfway to making pretty epic RC vehicles, all out of plastic! Of course we can't just add more volts and more amps until we get what we want, this would just wear and melt things too fast. Thing is the XL motor already has the power. But with it's internal gearing and the current parts selection it can't be used efficiently. I see the Unimog with it's portal hubs designed to take an 8t and 24t gear to increase the power to the wheel as a step in the same direction i'm talking about. It will also need bevels from stronger material, bigger tyres and better motot. Quote
Jim Posted September 19, 2011 Posted September 19, 2011 Hello everybody. Maybe someone has seen my Lego Rock Crawlers. So I would like to espresso my opinion. Xl rather put up with engines torque to a crawler, but without speed control. Lego impossible for universal joints do the work, so the project has to be an XL in each axle independently. The buffers need to be articulated attachment points and the suspension arms have to be more rigid and better fixation. And the foremost of all, impossible to climb rocks with existing Lego tires! The rubber is very tough. I made a model with the changes needed to walk like a rock crawler: http://www.brickshel...ry.cgi?f=448931 And I did one with original http://www.brickshel...ry.cgi?f=481962 and videos Get your conclusions Hi Raus, Nice rock crawler! What wheels did you use? Those are custom wheels. Where did you get them? Quote
Ondra Posted October 15, 2011 Posted October 15, 2011 Rock crawler with price 180€ is for this moment mysterious what we can expect for this price.Im expecting something big as this MOC http://mocpages.com/moc.php/147876 .Im not expecting radio control, problem with pieces crushing and another TT norms , but something with fancy funtions as lowering suspensions(Similar to 8297), four wheel steering, towing crane(? Big version of 8858 http://technicopedia.com/8858.html ) and doors similar to 8466 .So lets wait and we will see... Helicopter is another my expected set, I hope for same size as 9394 jet plane for 1H2012(50cm).But with motorized crane or rotors. Quote
davidmull Posted October 17, 2011 Posted October 17, 2011 Have we a Deffinate line up list for 2h2012 yet Quote
Wiseman_2 Posted October 17, 2011 Posted October 17, 2011 We don't usually see a 2H list until later in the year do we? I'm surprised we even had rumours so early. Quote
Ondra Posted October 18, 2011 Posted October 18, 2011 We don't usually see a 2H list until later in the year do we? I'm surprised we even had rumours so early. This year we have more themes with 2H speculations, most interesting speculations, that are going to be true, are about exclusive sets(Kingdoms joust for example), LOTR and one set in creator.Like past two years we will IMO see this sets in overall catalogue for year 2012 in the end of 2011. Quote
Meatman Posted October 18, 2011 Posted October 18, 2011 Over at technicbricks I read some speculation as to the letters on the license plate sticker on the front of the 9395 perhaps being a message to a certain builder who complained about the #44 toggle joints not being made in black for the extreme cruiser and this set actually has them in black. does anyone know if there is any truth to this? I have to admit, if this is true, it is quite hilarious. Quote
Ondra Posted October 18, 2011 Posted October 18, 2011 I have one questions,what "PB 9187" mean? Is there clue to some piece? Quote
Meatman Posted October 18, 2011 Posted October 18, 2011 I just realized that I posted this in the wrong thread. I guess I better correct it. Quote
DLuders Posted November 3, 2011 Posted November 3, 2011 (edited) Edited November 3, 2011 by DLuders Quote
davidmull Posted December 1, 2011 Posted December 1, 2011 Are we still to early for this :( I'm eager to know more about next years flagship!sorry for my impatience :) Quote
matias bendtsen Posted December 1, 2011 Posted December 1, 2011 i love the way you speak with images. Quote
Pauger Posted December 1, 2011 Posted December 1, 2011 http://www.youtube.com/watch?v=tpgM9XWS-90 Quote
AndoS Posted December 20, 2011 Posted December 20, 2011 (edited) Just noticed descriptions of new 2012 sets in Brickset: 9396 {heavy-lift helicopter} 9398 {remote control off-roader} Hopefully in coming days first preliminary pictures of the 2h 2012 sets will emerge. EDIT: First pictures are already available and you can read first thoughts at TechnicBRICKs Edited December 20, 2011 by AndoS Quote
captainmib Posted December 20, 2011 Posted December 20, 2011 (edited) pictures at legopictureHQ: Thoughts at technicbricks: technicbricks blog Helicopter looks great (but very red and yellow), but i need me some high quality pictures Off-roader looks nice aswell Edit: See 1h 2012 topic Copy People, shall we merge the 1h and 2h 2012 topics into one sticky topic called '2012 technic models'? This is getting a bit confusing. Also, one nice Topic Start with pictures, links and stuff like that will be highly appreciated! Please let me know Edited December 21, 2011 by KielDaMan Deeplinking of confidential preliminary images (even in a video) are not allowed in the site. Quote
