  • Replies 3.4k
Posted Images
There are three function's if useing it like below (excluding the gear change),the motors would stay at the bottom in the chassis,or you could remove the upper part and be left with just two functions.
Doh, I'm sorry that I can't be more of a help for new ideas. I don't have many parts, so haven't much technical work that I can figure out.
That's quite all right.:thumbup:
You got to learn from something.:grin:
@alasdair
the motors in the chassis and only the driveshaft in the tower?
Yes the drive shaft and the second gear change if you want three functions.
My view it would be to change the orientation of the 3 crane motors to the horizontal plane this would reduce the hight of the tower and you can hide the motors in the chassis.
Edited by Firky
My view it would be to change the oration of the 3 crane motors to the horizontal plane this would reduce the hight of the tower and you can hide the motors in the chassis.
That would be a good idea. There would be plenty of room under the load bed at the back, so perhaps could fit them in there?
and where is the usefull difference to 3 single driveshafts for rotate/first boom/second boom and the motors in the chassis?
Smaller? i dont know.:blush:
If you keep the slew motor in the chassis you could have another function like teleboom or open close grab,also bare in mind that you will have wires going though the turntable that will twist if you go with motors mounted in the crane.
Edited by Alasdair Ryan
i dont think that it would be smaller, maybe below the turntable, but above the turntable it will be much bigger.And there is no space.
if i want more than two remote functions above the turntables, then i will use pneumatics.
i think i will try something different. i hope it works
edt:
something completely different
101_9192 von efferman auf Flickr
Edited by efferman
edt:
cool
That would make something really good, and an RC with one motor. But I have an issue, obviously, with the goal being to make it RC, this wouldn't make it RC as we'd still have to use our hands to select which way the direction it is turning. That obviously takes it out being RC, so is there need for it to be RC. Unless it's just driving and steering you aim to be RC.
Just a thought.
Oh, that makes it ok then. I reckon that would be very useful. What motor will power it? XL, L or M? I imagine that an XL, as it could come under strain if more than one function is used at once? Any plans to motorise the Claw?
i think i will use a single piston compressor for the claw and two combined PF-M for powering the compressor and functions. A XL would probably kill the clutch gears.
sorry, but there is currently no relevant progress which can be photographed. currently iam searching for a way to squeeze the gearbox in the truck.
