efferman Posted March 8, 2021 Author Posted March 8, 2021 3 hours ago, suffocation said: This, to me, is right up there with the very best Lego tow trucks ever made, along with Sariel's and Andrea Grazi's. Thanks First test of the hooklift with 1500g (container and payload) Quote
1gor Posted March 13, 2021 Posted March 13, 2021 It works very smooth. (If I didn't miss something) I wonder if hook lift mechanics can be done with one L-motor? Quote
efferman Posted March 13, 2021 Author Posted March 13, 2021 2 minutes ago, I_Igor said: I wonder if hook lift mechanics can be done with one L-motor? it is possible to make a gearbox which switches between the functions. They dont have to work at the same time. Quote
1gor Posted March 13, 2021 Posted March 13, 2021 15 minutes ago, efferman said: it is possible to make a gearbox which switches between the functions. They dont have to work at the same time. But then it us not RC... Quote
efferman Posted March 13, 2021 Author Posted March 13, 2021 2 minutes ago, I_Igor said: But then it us not RC... indeed Quote
1gor Posted March 13, 2021 Posted March 13, 2021 5 minutes ago, efferman said: indeed I was thinking if there is some possibility using white 24 tooth clutch gear(s) but for now I'll work on my RC telehandler... Quote
efferman Posted March 13, 2021 Author Posted March 13, 2021 21 minutes ago, I_Igor said: white 24 tooth clutch gear(s) not on the hooklift. There are two modes: Tipping and unloading the Container. In both the actuators have to move in and out and the mode switch has to stand still while actuator movement. What is the function you need? Quote
1gor Posted March 13, 2021 Posted March 13, 2021 9 minutes ago, efferman said: not on the hooklift. There are two modes: Tipping and unloading the Container. In both the actuators have to move in and out and the mode switch has to stand still while actuator movement. What is the function you need? I was hoping to make sliding container until one point and then to activate hook... Quote
efferman Posted March 13, 2021 Author Posted March 13, 2021 with one motor? telescopic moves in, at the retracting endpoint it activates with a lever a gear switch wich is activating the lift and disable the telescopic. When the lift is coming down it activates a lever which switches the gearbox from lift to telescopic. Quote
1gor Posted March 13, 2021 Posted March 13, 2021 4 minutes ago, efferman said: with one motor? telescopic moves in, at the retracting endpoint it activates with a lever a gear switch wich is activating the lift and disable the telescopic. When the lift is coming down it activates a lever which switches the gearbox from lift to telescopic. Yes something similar like that. Actually inspiration came from @Sariel's autovalve idea. Quote
efferman Posted March 14, 2021 Author Posted March 14, 2021 Enough for today ....i know, i have to vacuum the dirt Quote
efferman Posted March 14, 2021 Author Posted March 14, 2021 Thanks Altough i will only make an PU instruction, PF fits with small changes too. Quote
1gor Posted March 14, 2021 Posted March 14, 2021 Well I'm in PF world and probably when I use all PF elements that I have, I'll see if there is something manual that can be built and then (most likely) I'll stop building with LEGOs. When I see how much sets with PU cost here it is simply to much for me... Quote
efferman Posted March 19, 2021 Author Posted March 19, 2021 It was a good time, but i guess the time of PF is over. As always, some parts are missing Quote
Jundis Posted March 20, 2021 Posted March 20, 2021 Looks very smooth :-) Do you have suspension on the rear wheels? The gap between wheel arches and wheels seems to narrow...? Quote
efferman Posted March 20, 2021 Author Posted March 20, 2021 21 minutes ago, Jundis said: Do you have suspension on the rear wheels? All 6 axles in this vid have a suspension. on the Truck with a half stud travel, on the trailer a little bit more. Quote
efferman Posted March 31, 2021 Author Posted March 31, 2021 (edited) Unbelievable! less than a month and it is copied Edited March 31, 2021 by efferman Quote
Jundis Posted March 31, 2021 Posted March 31, 2021 Lesson 1 in "How to be uncreative": Be a chinese copycat-company. @efferman I hope you can take it as an honor, not an insult. Quote
efferman Posted March 31, 2021 Author Posted March 31, 2021 43 minutes ago, Jundis said: @efferman I hope you can take it as an honor, not an insult. I know the mentality, but it scares me how fast they are. Quote
Scoar Sonander Posted March 31, 2021 Posted March 31, 2021 2 hours ago, efferman said: I know the mentality, but it scares me how fast they are. yeah. I went on their site, and found multiple other copied MOCs. Quote
