  • Replies 3.4k
Posted Images
your road train is beautiful😍😍
you are not nice to us😉 because we want to have all your construction instructions😍😍
On 10/1/2011 at 8:54 AM, efferman said:
so my new rims are arrived and i could make a little testride
the climbing performance is nearly the same like my willys. unfortunately the long wheelbase is limiting a bit.
the currently dimensions are:
wheelbase 43 studs
width 25 studs
steering pivot point distance 15 studs
ground clearance between the front axle 6.5 studs
ground clearance between front and rear axle 7 studs
Very cool. And holy crap that's a lot of fire wood.
jep
I'am trying to build an inloader. It is actually in an early prototype stadium, so it looks a little bit Pizza.
I've asked because inloaders that I see on highway on my everyday journey to work usually transport large objects that are fragile like glass or objects that are are sensitive to weather conditions
The pivot point for making the wheel go up and down was an axle supported on both sides.
For the wheel I used an axle going through 2 beams, but the pivot point there was a black pin.
On 10/31/2020 at 11:46 AM, efferman said:
Vielen Dank für Ihre Meinung, es hat sehr geholfen.
wäre es möglich eine BA nur von der Kabine zu bekommen für eigene MOGs?
Hello and welcome to EB.
Please take some time and read the site rules and guidelines.
You need to use English when posting.
I think he also needs to disable automatic translation into German on his browser, otherwise it will happen again and again and again...
We'll see what he says, and we will try to help him.
He asked about building instructions only for cab; perhaps it could be wise that he PMs efferman, but he needs more than one post to publish in order to do that, you'll se when he replies...
17 hours ago, BJBrick said:
Would it be possible to get an instruction for the Cab alone?
I will take a look what i can do, but give me some time.
super :daumen hoch: ich warte gerne da ich schon einmal versucht habe einen MAN TGS zu bau am ende ist es en MAN 33 geworden :p ir_tong2:
Sorry mein 2. Beitrag zu diesem Thema habe ich auch auf Deutsch gepusht, weil ich diese Nachricht zu spät gesehen habe:d ef_shrug:
It's okay, just try to use English from now on.
