gyenesvi Posted August 18, 2023 Posted August 18, 2023 That axle looks very nice! Wish something approximating that would exist in lego, especially if your small differential could also be incorporated somehow.. How wide is it? 13 studs between the steering pivot points? Quote
efferman Posted August 19, 2023 Author Posted August 19, 2023 6 hours ago, gyenesvi said: How wide is it? 13 studs between the steering pivot points? the pivotpoint is 104mm and the mounting point für the wheels is120mm apart. So with the new short CV Hubs from the Audi it has overall a width of 18 studs. Quote
1gor Posted August 19, 2023 Posted August 19, 2023 7 minutes ago, efferman said: So with the new short CV Hubs from the Audi it has overall a width of 18 studs. ...when they will be available... Quote
efferman Posted December 22, 2024 Author Posted December 22, 2024 So iam still alive but i was to busy with something big and secret. Now iam free to build something just for fun. The goal is something similar to the Dakar Daf X1. And yes, this is the batterybox from the Cada Combine Harvester. Quote
bruh Posted December 22, 2024 Posted December 22, 2024 Nice starting chassis! Is the "big and secret" project something that will be posted for all of us to see? :D Quote
efferman Posted December 22, 2024 Author Posted December 22, 2024 The time will tell, but not me. Quote
efferman Posted December 24, 2024 Author Posted December 24, 2024 (edited) The rough design is done. Till now it has around 750 parts. I hope it will stay below 1000 parts when it is done. Edited December 24, 2024 by efferman Quote
1gor Posted December 24, 2024 Posted December 24, 2024 I see hub reductios, so I suppose slow output, then red differential then hub reductions or one motor powers each rear wheel? Quote
1gor Posted December 24, 2024 Posted December 24, 2024 Slow outlut at front and slow output at rear...with hub reduction... Quote
efferman Posted December 25, 2024 Author Posted December 25, 2024 Exactly 998 Parts and ready for the preliminary Instruction. Quote
1gor Posted December 25, 2024 Posted December 25, 2024 For offroader probanly very good, but for solid surface... I suppose that you don't use original Lego buggy motors because they have always second-two delay when using pure Lego powerfunctions elements Quote
efferman Posted December 25, 2024 Author Posted December 25, 2024 I will use Cada buggy motors and electronics Quote
1gor Posted December 25, 2024 Posted December 25, 2024 Some people mentioned that Cada motor is not that strong as Lego, not to mention BuWizz, but as you once told me, for some normal usage 100-130Ncm is more than enough on torque, so I suppose you know what you expect speed wise from yor Daf Dakkar truck. Quote
efferman Posted December 25, 2024 Author Posted December 25, 2024 I have the Cada Electronics, so why i shouldn't us it? Quote
1gor Posted December 25, 2024 Posted December 25, 2024 I was just wondering how is your experience with vareus brands, nothing more... Quote
efferman Posted December 25, 2024 Author Posted December 25, 2024 I had never an Buwizz product and the Lego buggys are ... hard to deliver with power. Quote
1gor Posted December 25, 2024 Posted December 25, 2024 (edited) I have only Lego buggy motor and first I thought that IR receicer(s) are malfunctioning, but with single/coupled M, Large, XL motors they work without problems...and then I decided to test Servos that I thought don't work...but then 3 tested Servos are fine, so now is time to wait for tires...btw Lego buggy motor works only directly connected to battery box, perhaps polarity swich would help, but some time in future... BTW Daf looks well proportioned, perhaps tappered panel would be nice behind cab? Edited December 25, 2024 by 1gor Quote
vliet Posted December 25, 2024 Posted December 25, 2024 Looks really good, I remenber the truck from the late 80s from TV and I have seen it for real in the DAF museum. Can't wait for instructions :)) Quote
jorgeopesi Posted December 25, 2024 Posted December 25, 2024 That truck looks very good those tyres are perfect for it, Quote
1gor Posted December 25, 2024 Posted December 25, 2024 31 minutes ago, jorgeopesi said: That truck looks very good those tyres are perfect for it, Actually tires are perfect for every offroader and industrial vehicles (like your) front end loaders, telehandlers, mobile crane trucks...of course Unimogs... But Micha's inspiration is real beast (it overtook even legendary Pugeot 205 16... https://nl.m.wikipedia.org/wiki/TurboTwin Quote
efferman Posted December 25, 2024 Author Posted December 25, 2024 Thanks guys! I managed to raise the ground clearance and get spare tires into my 1000 parts limit. Quote
efferman Posted December 26, 2024 Author Posted December 26, 2024 (edited) Hey Guys, here is the preliminary instruction for the Dakar truck. Don't mind the coulours, use what you have in stock. This thing is made to be colorful The body is connected to the frame with only two Pins. So the removing should be easy. https://bricksafe.com/files/efferman/dakar-twin-engine/x1_twin_preliminary_instruction.pdf https://bricksafe.com/files/efferman/dakar-twin-engine/X1 Twin_preliminary_instruction.io Edited December 26, 2024 by efferman Quote
