Is it only me or look it more round than the other?
The one on the right definitely looks rounder, the curve continues further down the arch. It also looks better!
  • Replies 3.4k
Posted Images
I see the problem. What has happened that the bendy axle isn't pushed in all the way on the left picture and on the right, it's all the way in. As it is longer on the left, this will make the curve less circular. Hope this helps.
they are both pushed completely in. my theory is the following:
the right one has at the inner diameter no gaps between the liftarms and so they support the flexible axle to a smooth curve. the left one doesnt have this support and bends like it wants.
Wow. Your truck looks amazing. The gearbox system is very clever. It could be fun to operate it. Do you have started to build trailer yet or do you finish the truck first?
thanks
i finish frst the truck, then comes the trailer and in between i have to sail the technic sea. when my idea works :laugh:
Edited by efferman
thanks
Ah dam i was hoping you were not going to take part,then i could of had more chance of me winning something in my life.:laugh:
VERY cool project regarding your Mercedes-Benz G-Wagen/G-Class! I think you maybe should shorten the wheelbase a bit if u can. Otherwse, absolurtely astonishing...as i expect of builders like you, Efferman. Great Job. I sure hope you make some instructions, like your Jeep Willys (on my builds list once I get another toggle joint)
Cheers from Arizona!
-88high
-88high
first i must reanimate this moc, but rock crawlers are actually too boring for me.
well, if you aren't going to finish it, then i will. As soon as i work through my massive backlog of other projects anyway...
So even the best of Builders have a backlist of unfinished projects. Does that mean i'll never finish a Moc, maybe so. I hope not, as I have something in my head.
