timslegos Posted June 24, 2012 Posted June 24, 2012 Looks like a pretty solid axle. Would you make instructions? tim Quote
efferman Posted June 24, 2012 Author Posted June 24, 2012 i dont know at this time, and first i must sort my parts that i could finish the logging truck. for small things is enough place on the table, but not for a 55cm moc. Quote
Alasdair Ryan Posted June 24, 2012 Posted June 24, 2012 Looks like a pretty solid axle. Would you make instructions? tim Surly you could build a steering axle your self? You will neaver become as good as me if you just copy other people design's. Quote
timslegos Posted June 24, 2012 Posted June 24, 2012 Surly you could build a steering axle your self? You will neaver become as good as me if you just copy other people design's. I am pretty sure that the last MOC I saw from you was a tiny boat, while I have been builder a over 3 foot truck and trailer with a working 8 function load . tim Quote
Saberwing40k Posted June 24, 2012 Posted June 24, 2012 Nice axle, but what purpose does having the steering axis set at an angle serve? And why are there four links in front and a torque tube in back? An explanation would be very nice. Quote
efferman Posted June 25, 2012 Author Posted June 25, 2012 only the c-frame is used at the torque tube part. the ball will be not used. the angled pivot point is used to save space inside the mudguard, and the angled lower wishbone is used to get the tire in a right angle to the ground. Quote
efferman Posted June 25, 2012 Author Posted June 25, 2012 thanks for sharing, but i think this rc system needs a own topic. two pictures for a better explain of saberwings first question first with horizontal steering arm now wikth angle steering arm the angled steering arm is reducing the slack in the towballs and the axles Quote
efferman Posted July 1, 2012 Author Posted July 1, 2012 my first true crawler 101_9394 von efferman auf Flickr and same error at every time: a jumping gear in the center of the rear axle Quote
timslegos Posted July 1, 2012 Posted July 1, 2012 Wow shes beautiful!! Another awesome build effe. I assume a video is coming? tim Quote
efferman Posted July 1, 2012 Author Posted July 1, 2012 thanks a video will surely coming, but first i have to to design a portal axle. the ground clearance between the tires is currently not high enough for my parcour. Quote
timslegos Posted July 1, 2012 Posted July 1, 2012 thanks a video will surely coming, but first i have to to design a portal axle. the ground clearance between the tires is currently not high enough for my parcour. You and your German engineering . Good luck! Will you take more detailed pictures of the axles and suspension set up? tim Quote
efferman Posted July 2, 2012 Author Posted July 2, 2012 do you wanht pictures from the actual setup or from the final one? Quote
chorlton Posted July 2, 2012 Posted July 2, 2012 (edited) That's nice. I like the use of the small LA for steering. Can I ask, was this an inspiration at all? I ask because when i saw this pic posted in the 9398 thread my first thought was "That would be a great MOC" :) edit: IGNORE ME! I just realised it was you who posted this pic in the 9398 thread Edited July 2, 2012 by chorlton Quote
allanp Posted July 2, 2012 Posted July 2, 2012 And you say you want to put portal axles on it? Surely the axles you have are better. Quote
efferman Posted July 2, 2012 Author Posted July 2, 2012 dont let me be misunderstood: i will not use the crappy portalhubs from 8110 Quote
timslegos Posted July 2, 2012 Posted July 2, 2012 Yes i would love detail photos from the final MOC. tim Quote
bord4kop Posted July 2, 2012 Posted July 2, 2012 (edited) Looks good already Effe I am looking forward to the final result! Edited July 2, 2012 by bord4kop Quote
skylinedan Posted July 3, 2012 Posted July 3, 2012 dont let me be misunderstood: i will not use the crappy portalhubs from 8110 I thought the hubs on the 8110 were nice, but hey. That just me, I kinda go against the flow any ways, LOL. Quote
efferman Posted July 3, 2012 Author Posted July 3, 2012 (edited) ok, they are better than nothing, but please take a look at this picture 101_9398 von efferman auf Flickr can you see the problem? edit is it not funny? i want add a portal axle and what iam doing? a whole new chassis 101_9402 von efferman auf Flickr and why iam build so many times a chassis like a unimog? Edited July 3, 2012 by efferman Quote
efferman Posted July 7, 2012 Author Posted July 7, 2012 the 9398 C-model has shown that simplicity has big advantages. So i decide to kill the big crawler and and have optimized the c model with external parts. but there is only one question: is it a skunk or a black kitten with a white stripe on the back? Quote
DLuders Posted July 7, 2012 Posted July 7, 2012 I like your "Skunk" -- it is very capable but it does not "stink"! Quote
efferman Posted July 7, 2012 Author Posted July 7, 2012 thanks in meanwhile i have made some pictures 101_9451 von efferman auf Flickr Quote
