  • Replies 3.4k
Posted Images
Are you going to make a stick configuration for a peel grab?
this is plan B
Looks nice but the scraphead is to big for this mainboom
i think the same
no, it should not rotate freely. unfortunately the LA is rotating the grab when it is in its end positions. or it swings out of the vertical line
edit:
now the turntable is locked by a wormgear and the speed is reduced to roundabout 30 rounds per minute
100_9903 von efferman auf Flickr
Edited by efferman
@ efferman: Aanchir's Lego Technic Sprocket Wheel Template should work -- here it is on this Eurobricks post :
"LDD file (includes sprocket wheel wrapped in 6 tread pieces, straight length of 12 tread pieces, and green alignment tool)
User's Guide (step-by-step instructions, including tips on avoiding snags)."
From Aanchir's Brickshelf gallery, his User's Guide says:
"Hi! I'm Aanchir, and I created this template.
This template is for building models on LDD that require part 57520 (the small sprocket wheel) and part 57518 (the tread).
To use this template:
1) Download the file
2) Remove one or more of the tread pieces that surround the sprocket wheel so that it's no longer a complete loop.
I recommend removing one of the 60-degree tread pieces so there's a horizontal tread to connect to.
3) Connect as much extra tread as you need.
A chain of horizontally-placed treads is provided for you to use or copy.
WARNING!
Clips on LDD do not like to center correctly!
There will usually be a left or right offset, which can do a lot of harm if all of your clips are offset in the same direction.
The chain of tread pieces may not be lined up at both ends!
To avoid this, use the green alignment tool included in the file.
Place new tread pieces on every other pin, then place tread pieces on the pins in-between.
The alignment tool is entirely in green so you can use the "color select" tool to select all its parts at once.
If you need to use green parts in your actual model, feel free to select the tool and change its color to something a color you will not be using.
4) Once you have the length of tread you need, you will need it to wrap it around the other wheels of your model.
ALWAYS use the hinge tool to ensure the tread is wrapped snugly around each wheel.
It may help to paint the treads TRANSPARENT so you can see how they align in the grooves.
5) Some sets and MOCs will have some "sag room" on their treads, or will have wheels that have to be rotated to align properly.
I am not yet equipped to deal with either problem, but perhaps you will find your own solution.
If the alignment goes smoothly, the last hinge rotation will make your length of tread link back up at the ends.
Congratulations! You're done!
I hope this template proves useful."
Saberwing40k made a LDD File of the Lego Power Functions L-motor and Servo-motor, and posted it here. You can see how he built up the equivalent pinhole locations:
They represent Bricklink Part 99498c01, "Light Bluish Gray Electric, Motor 9V Power Functions Servo with Dark Bluish Gray Bottom".
...and Bricklink Part 99499c01, "Electric, Motor 9V Power Functions L with Dark Bluish Gray Bottom."
Hello,
It is a very nice crane, i love grapple cranes :)
I'm trying to make it grom your photos of I may?
Can you take some photos of the piece where the yellow arm is connected to the black one?
And also how the L motor fits the 2 la's :)
Thank you very much :)
Stephen
iam working currently at a ldd model of the uppercarriage, so you can see the drivetrain in detail. if you want pics from the second boom LAs please look here
and here pics of the connection between first boom and stick.
100_9904 von efferman auf Flickr
i have finished the uppercarriage. pleas ignore green parts, because they are placeholder for the PF-L motors or skip some connection problems. the booms will follow
http://www.brickshel...percarriage.lxf
undercarriage with tracks
http://www.brickshel...ewithtracks.lxf
edit:
i have stripped the ldd model, to show the drivetrain of the standard functions
red= track right
green= track left
blue= shovel
yellow= stick
orange= mainboom up and down
grey= rotation
uppercarriagedrivetrain1 von efferman on Flickr
Edited by efferman
no, my thought during building was a snowgroomer, but in meanwhile iam thinking i switch to build something like this
Edited by efferman
