  • Replies 3.4k
Posted Images
The outriggers are nice, but as for the crane boom I'd reccomend using something like this: A 3 section boom, with the outermost section 15 studs wide, the second being 11 studs, and the innermost being 7 studs. This gives you plenty of room for reinforcements, especially if you want to lift 9398.
15 studs will be big and if i have 15 studs in height......
anyway, for the outriggerdrivetrain i neead more space in the frame so i try somethin which is not originally to the M.A.N
independent suspension. i hope it will give me more space in the frame and easier adding more shock absorbers if the final weight is too high for one shock absorber.
i hope it will work under high load
Looking good, efferman! I like how you are using the 20t and 12t bevel gears together for added strength. Clever idea there. :thumbup: :thumbup:
And if all else fail you can use knobs.
100 percent correct
during the search for a steered independent suspension, i have built a mcpherson version. u8nfortunately i have only 3 old style pneumatic zylinders so i could not build two front axles. but i want to show you one of the suspensions
Edited by efferman
This is too awesome!
100 percent correct
Forgive me for asking but I thought pneumatic cylinders haven't changed in like 15 years or so? How do they differ? Thanks.
I believe he is referring to the square bottom of the cylinders rather than just a studless mount.
The progress looks great effe, I love watching you build.
tim
indeed, i need the square bottom for the mcpherson suspension. and for this, purists may excuse me, i have raped a big pump and modified it to a pneumatic cylinder with one inlet.
please note that this is only a provisoric mount for testing the steering
Edited by efferman
tim
Arhh I see, thats pretty obvious. Thanks. :sweet:
Looking awesome Eff! :thumbup: :thumbup: :thumbup:
I'm kind of wondering why you just dind't just buy anothe one of off Bricklink :tongue: .
simple answer: my wallet is currently more than empty
Oh man, that sucks. By the way, I just noticed some black stuff wrapped around the U-joints in one of the pictures. What is that? I'd kind of like to reinforce my joints the same way.
I think its rope to reinfoce the joints.
yes it is thin rope from the lego sets. unfortunately it is neccesary to tighten the knots from time to time.
btw, a short test with an "bollerwagen"
roundabout 20 till 30 kg weights the flatbed with load
Edited by efferman
oh it is not mine, i am driving a lupo
btw small car
i think the flexibility is enough
Edited by efferman
at the rear axles it will be an damper/pneumatic hybrid. the dampers will hold the m,ost load and the pneumatic cylinders will do the load balancing between the wheels
