yesterday i had made a little torture for the drivetrain. the conclusion was to to make a stronger frame, even for tests like these . and the steering links has to prevent before popping out. but i think the drivetrain is stable enough.
since this test i had made a little progress. the servos for steering are skipped because the high steering angles are not good possible with a servo. and the tire winch is skipped to a manual one
  • Replies 3.4k
Posted Images
If you put a lift arm behind the ball joint (allowing room for movement) that might help to stop it coming of the chassis.
If you raised the back suspension up thus bringing down the front, might that improve traction?
Ps Do I spot a beer belly? :tongue:
i simply need the space for the drivetrain of the outriggers and other undercarriage functions
edit:
a few minutes ago, i made the final hosing for the pneumatic cylinders, i saw something what i dont like. a broken universal joint
Edited by efferman
my inspiration in cranebuilding does currently dont want working, so i need something little in between to get the head free. so i have a little quiz for you
a small hint: i have tried it some time ago and i have failed
I saw it on Flickr: :grin:
"This photo also appears in:
10178 with turning circle"
I'm looking forward to this project!
Edited by fresko
Cool!! That is very good!
I especially like that it has a turning system. Best one yet, and i cant wait to see it with a shell.
-ED-
PS: I would love to see some good pictures or instructions for this. Also, it would be great for Cuusoo...
thanks guys, but i will make instructions only when it works properly with head and on carpet. currently it works and turns well, but without the head and body it is useless
I'll be looking forward to that! :thumbup:
ok, carpet is again a small problem but this version works much better. it is now more narrow at the legs, but two studs longer between front and back legs.
and heres the vid
Edited by efferman
