efferman Posted May 30, 2013 Author Posted May 30, 2013 i have tried several setups in timing the steps and every exception the 10178 timing was looking really funny. so i think every unsynhronized movement is not an good idea the most stable way would be the following: 3 legs are on ground and moving with the same speed backward. the fourth leg is moving in the opposite direction with the foot in the air. this leg should move in a speed that it hits the ground, before the next leg loose the ground contact and moves forward. unfortunately i dont have an idea to realize this with an mechanical solution Quote
Alasdair Ryan Posted May 30, 2013 Posted May 30, 2013 Surly that is just down to gearing the legs differently? Quote
efferman Posted May 30, 2013 Author Posted May 30, 2013 sorry but it seems that understanding of inglish is out of order when i read your last post. could you please describe it in other words? Quote
Alasdair Ryan Posted May 30, 2013 Posted May 30, 2013 If you gear three legs that are the same speed as each other,and then gear the last one differently (like what you said above) then will that not improve the steering of the walker? Quote
efferman Posted May 30, 2013 Author Posted May 30, 2013 the problem is not the steering, the problem is the stability in general. two legs in air makes it simply wobbly Quote
efferman Posted June 1, 2013 Author Posted June 1, 2013 7th prototype, only the feet needs to adjust a little and the receiver needs the final place. Quote
jorgeopesi Posted June 1, 2013 Posted June 1, 2013 Is an interesting mechanic challenge, would it work to use 1 motor for each pair of legs on one side and slow it down to make the turn?. Quote
Alasdair Ryan Posted June 1, 2013 Posted June 1, 2013 Two more little suggestions: 1) What about using small LA's on each leg to increase the steering? 2)what about attaching some of the rubber connecters horizontal to the ground to stop the legs slipping. Quote
efferman Posted June 1, 2013 Author Posted June 1, 2013 Is an interesting mechanic challenge, would it work to use 1 motor for each pair of legs on one side and slow it down to make the turn?. hm, with an 8 legged walker like some of the clone wars walkers should it work, but on a four legged? it needs to try to find it out. Two more little suggestions: 1) What about using small LA's on each leg to increase the steering? 2)what about attaching some of the rubber connecters horizontal to the ground to stop the legs slipping. 1.) all leg steering? maybe this could give problems with the center of gravity 2.) good idea. i will try this in modifying the feet. Quote
Alasdair Ryan Posted June 1, 2013 Posted June 1, 2013 You have all ready improved the steering a lot,but maybe if you still require more responsive steering then it could be a option. I am unsure what such a mechanism will do on the 'balancing side' of things. Quote
efferman Posted June 1, 2013 Author Posted June 1, 2013 I am unsure what such a mechanism will do on the 'balancing side' of things. i can not placed the motors and battery box at the current place. currently it is more or less well balanced. for all leg steering i must place the motors more in front and the battery box higher or/and more forward. Quote
Alasdair Ryan Posted June 1, 2013 Posted June 1, 2013 i can not placed the motors and battery box at the current place. currently it is more or less well balanced. for all leg steering i must place the motors more in front and the battery box higher or/and more forward. Ah,yet another good use for a PF micro-motor.... What about steering the back legs as well as the front ones? Quote
Alasdair Ryan Posted June 1, 2013 Posted June 1, 2013 (edited) I think you should try motorizing both front ones and rear ones independently. If you find that there is a bit off misalignment between legs, you could always gear it up/down to synchronize the legs. Edited June 1, 2013 by Alasdair Ryan Quote
Zerobricks Posted June 1, 2013 Posted June 1, 2013 I think you should try motorizing both front ones and rear ones independently. That would desynchronise the legs. Quote
efferman Posted June 1, 2013 Author Posted June 1, 2013 nice idea, then a sound modul with a "wuff" and i can make them sit like a dog. Quote
Alasdair Ryan Posted June 1, 2013 Posted June 1, 2013 (edited) That would desynchronise the legs. Add gearing.... nice idea, then a sound modul with a "wuff" and i can make them sit like a dog. Lego do already make a roar sound brick. Zblj your Dino is doing the moon walk. Edited June 1, 2013 by Alasdair Ryan Quote
grego18f Posted June 2, 2013 Posted June 2, 2013 hi, great mocs . But I've seen in the previous pages that for your logging truck, you have made a crane. If it's already build, can you post pics of the crane basement? Quote
efferman Posted June 2, 2013 Author Posted June 2, 2013 (edited) did you mean this cranebase? i think i have finalized the steering mod you can find the lxf file here Edited June 2, 2013 by efferman Quote
grego18f Posted June 3, 2013 Posted June 3, 2013 did you mean this cranebase? i think i have finalized the steering mod you can find the lxf file here No, I didn't explain correctly, sorry I'm talking about the part of the crane with LAs, if you see what I mean. Really good AT-AT to . Quote
Technyk32231 Posted July 20, 2013 Posted July 20, 2013 i have built a new chassis. same wheelbase and width, but two studs more ground clearance between the axles. two pics is it only my opinion or are these rims the perfect mercedes rims? I used a very similar suspension setup on a small truck, except instead of using shock absorbers, I just put a single transverse torsion bar, and it worked very well. Quote
Technyk32231 Posted August 4, 2013 Posted August 4, 2013 ok, they are better than nothing, but please take a look at this picture 101_9398 von efferman auf Flickr can you see the problem? edit is it not funny? i want add a portal axle and what iam doing? a whole new chassis 101_9402 von efferman auf Flickr and why iam build so many times a chassis like a unimog? Aha, you did use the unimogs portal axles for something! Quote
