  • Replies 3.4k
Posted Images
That looks sharp! Will you please explain how you used those aftermarket parts?
tim
well, this is the complete RC unit. The RC receiver is a ccx pro 3 channel from Jamara. the speed controller is a V15 navy from graupner, it is a controller for ships and i have used it because it has a low maximum of 15 amps and i had the fear that more power would overheat the motors. but the buggy motors and the cables are not going warm, so i think speed controllers for cars mit more amps should work too. the batterys are aaa Accus (choosed for low weight) with 1000mah, and it seems that on high power situations they going very fast empty.
100_0710 von efferman auf Flickr
to connect the electrical lego components to the RC speed controller, i have modified two extension cables with tamiya connector plugs. at the baja bug the inner cables deliver the current to the buggy motors. the second plug was a mistake :laugh:
then i have needed an servo which is able to mount in a lego car, so i have killed one of my dozens of battery boxes and use it to make some mounting points on the servo. the bondic box contains a liquid plastic compund which hardens only under UV light and give me a proper connection between the lego cut off and the servo. at last action i have made two holes in the servo lever dish to connect the servo movement to the lego axles. on the baja boss i use a 20/12 tooth combination to get enough rotation for the lego steering mechanism
thats all
Ya know, I'd kind of like to see a light mod of this, with no rc motors or aftermarket parts, with instructions. It's an excellent model, and that's totally something you should do.
when i have made the video and had some fun during driving, i will make a hand powered version of it. on display i need no RC parts. then i will make an instruction. i hope ldd has the right parts included
Edited by efferman
i have on ldd started with the display version of the baja boss. here is the rear axle
yes it is very fragile, but for an handpowered model it should be stable enough
the complete front is finished. the lxf file of the actual standing you can find here
edit: pimped by westcoast customs :wink:
Edited by efferman
for the steering you can look in the link in the post above. but please note that is a fully handpowered chassis. i dont know how this front suspension will react on offrod terain
What part is the long axle with pin-holes on the ends?
wow, this helicopter is very tiny.
i have made the mechanism a little bit more compact
the levers of the cyclic control are now on one axle
Has anyone attempted an LDD/LXF or MPD of such design ? (Granted, LDD may not have the old rotor parts).
yes, i want do a rebirth of my twincat truck which had a long time two cats as galeons figures too. it is not a must have, but nice memories
haube2 von efferman auf Flickr
opinions?
Hi Michael, looks great!
How can I contact you? I am big fan of your work and would like to get some help from you for a rather simple problem...I think for you it is simple:-)
Many thanks, Axel
Edited by lcaa
