  • Replies 3.4k
Posted Images
thanks guys. a vid in open water will come next days, even when water is still very cold :laugh:
btw, better photos
both propellers are coupled together and driven by a single Buggy motor. the steering works with a PF-M on each propeller. the weight is roundabout at 3 kg and the center of gravity is at the end of the exhaust pipes.
Maybe you can make a third boathul in the middel of the bow, instead the 3 float boxes :wink: .
I now that the most weight is at the wheelhouse and proposul and the bow and to level it strait it must have some extra weight at the back.
It's looking promissing so far Effe :thumbup:
Edited by VFracingteam
I dont want more weight, so i have moved the containers backward and removed the heli platform. And i have placed three closed airtanks under the bow. If this is not enough i can mount the float boxes one or two studs deeper , then it should float horizontally.
The boat looks great! Soon to be an engineer in the field of marine technology, I find the Voith Schneider system very fascinating! :thumbup:
Why not try 2 L motors? It's a little bigger, but you'll have just about the same amount of torque and start out at 200 RPMs instead of about a 100 RPMs.
the size of the PF-L is not a problem and absolutely not the power. i only need a indicator where is the thrust direction
Edited by efferman
on the back i have used the boat hulls from my harbour tug
and on the front 3 of these boxes
Edited by efferman
Because finally my new portal parts are arrived, i hve made a quick axle to test them. the trackwidth is the same like 8110, but now there is an 13L gearrack for steering possible.
The Ackerman ngeometry is with actually setup very small in relation to standard methods in lego axles. here it can be adjusted by the height of steering rack. is ikt on height of the u-joint the wheels turning paralell. is it above of the u-joint the rack can be placed in front of the axle, down below it should placed behind the axle.
100_1153 von efferman auf Flickr
Looks good, I'm very interested in your findings once it is built in the 8110 and how it will affect the handling of the Unimog. Will the steering be smoother and require less force? Does the camber mean it will have a self-centering characteristic? I'm eager to find out.
to see if it made the steering more easy first i have to built the 8110. My U400 completely different, but why not, i have enough parts. the self centering should be possible, but i think the drivetrain of the 8110 steering needs to much force for it. it is simply to long.
Hi efferman,
that looks really very very good an promising. But you use some real special and I think rare parts - some of them I've never seen before...
Pat
