Zerobricks Posted May 5, 2014 Posted May 5, 2014 In LDD shouldnt the top 16 tooth gear by a normal, not a clutch gear? Thanks for the file! Quote
efferman Posted May 5, 2014 Author Posted May 5, 2014 (edited) Oops, thanks for the Information edit: is fixed Edited May 6, 2014 by efferman Quote
efferman Posted May 11, 2014 Author Posted May 11, 2014 (edited) Because Mercedes has updated his U400 implement carriers i will do the same with my U400 Moc First point will be the Gearbox U530 gearbox von efferman auf Flickr The red lever controls the driving. position Up is the slow gear with roundabout 10 to 1 in combination with the full drivetrain. Position down the U530 will drive with roundabout 4 to 1 The yellow one shifts from neutral to the back or front PTO The blue one switches the compressor on or off All three drivetrains will be driven with one XL motor. Edited May 11, 2014 by efferman Quote
Pat-Ard Posted May 11, 2014 Posted May 11, 2014 Hi efferman, very nice gearbox!!! It looks that your infected again with die Unimog virus... Pat Quote
efferman Posted May 20, 2014 Author Posted May 20, 2014 (edited) a small afternoon project small 4wd chassis von efferman auf Flickr Lxf https://doctor-brick.de/threads/effes-technic-ecke.30/page-39#post-34423 Edited May 4, 2019 by efferman Quote
unimog123 Posted May 20, 2014 Posted May 20, 2014 Looks well built. Any body for this nice chassis, possibly a rally or trophy truck style perhaps? Quote
efferman Posted May 20, 2014 Author Posted May 20, 2014 (edited) Actually not , someone has asked for small 4x4 chassis with independent suspension. Edited May 20, 2014 by efferman Quote
JGW3000 Posted May 20, 2014 Posted May 20, 2014 (edited) Efferman - nice compact design, but please explain what the Servo motor is doing, I don't see how it is connected to any output??? thanks I think I get it, but won't the torque tear apart the red axle 2 inserted into the Servo motor output? Edited May 20, 2014 by JGW3000 Quote
efferman Posted May 20, 2014 Author Posted May 20, 2014 The servo actuates the steering like my rc valve which ibhave posted a few pages before. Tomorrow i will build it in real to show how it works Quote
Nico van Duin Posted May 20, 2014 Posted May 20, 2014 Looks nice! Does it have four wheel steering? Quote
rm8 Posted May 20, 2014 Posted May 20, 2014 The servo actuates the steering like my rc valve which ibhave posted a few pages before. Tomorrow i will build it in real to show how it works Do you have small custom 30 mm rims with 6 holes for this chassis? Or do you plan to use small racing rims/62 wheels ? Quote
efferman Posted May 21, 2014 Author Posted May 21, 2014 (edited) no nico, but with some changes it is possible. egor, actually i have no custom rims in this size so i will use the 62mm truck or the 68,8x36zr edit: note to myself, always testing things which are build only in ldd 100_1203 von efferman auf Flickr edit² Edited May 21, 2014 by efferman Quote
efferman Posted May 21, 2014 Author Posted May 21, 2014 a different moc, a new post some progress on the U530 please lego, produce the axle support piece Quote
efferman Posted May 23, 2014 Author Posted May 23, 2014 The Front axle with servo now i have to decide if short or long wheelbase Quote
Pat-Ard Posted May 23, 2014 Posted May 23, 2014 Looking very good with the servo directly mounted... I'd prefer the short wheelbase!!!! Pat Quote
Thirdwigg Posted May 23, 2014 Posted May 23, 2014 Go long, there are too many MOCs of the short wheelbase. Quote
D3K Posted May 23, 2014 Posted May 23, 2014 note to myself, always testing things which are build only in ldd I ran into that exact problem using the exact same parts making a similar setup, but without steering last year, and ended up cutting two 3L axles into 2,5L ones Quote
efferman Posted May 24, 2014 Author Posted May 24, 2014 ....... and ended up cutting two 3L axles into 2,5L ones me too Quote
efferman Posted May 24, 2014 Author Posted May 24, 2014 (edited) No, the son of the neighbours. edit: some work on the mudguards Edited May 25, 2014 by efferman Quote
efferman Posted May 25, 2014 Author Posted May 25, 2014 and some bodyworks this time with openable doors 100_1214 von efferman auf Flickr Quote
Pat-Ard Posted May 25, 2014 Posted May 25, 2014 Hi effe, looking good, but where's the hood gone ;) The doors are great... Pat Quote
