Balrog Posted October 19, 2014 Posted October 19, 2014 Nope, correctly understood. But I understand this is a special challenge to construct, because of a) space in uppercarriage b) aligning the outriggers so they still provide diagonal support. I think the approach could produce very interesting and challenging results. Quote
efferman Posted October 19, 2014 Author Posted October 19, 2014 (edited) lets think about what happens when the turntable is between the chassis and the uppercarriage, and the outriggers are mounted to the uppercarriage. The outriggers will be pushed down to stabilize the crane. the crane is lifting the payload and the additional weight of the payload is pushing the stabilizers more to the ground. how the boom could rotate? stabilizers with wheels? Edited October 19, 2014 by efferman Quote
Balrog Posted October 19, 2014 Posted October 19, 2014 lets think about what happens when the turntable is between the chassis and the uppercarriage, and the outriggers are mounted to the uppercarriage. The outriggers will be pushed down to stabilize the crane. the crane is lifting the payload and the additional weight of the payload is pushing the stabilizers more to the ground. how the boom could rotate? stabilizers with wheels? I don't think that it would work if the uppercarriage could really rotate when the stabilizers are deployed. I didn't think about that before. It would work if the stabilizers somehow "rotate" around the uppercarriage, but that would pose similar problems as with stabilizers in the chassis. Hm ... forget my idea please Quote
efferman Posted November 13, 2014 Author Posted November 13, 2014 iam actually waiting for some parts, so i have began with the ldd file. Quote
efferman Posted November 15, 2014 Author Posted November 15, 2014 small update with the powerswitch Quote
efferman Posted November 16, 2014 Author Posted November 16, 2014 Batteryboxes and the sparewheel winch are added Quote
Zerobricks Posted November 16, 2014 Posted November 16, 2014 What a beast! Will you use AAA or LiPo? Quote
efferman Posted November 16, 2014 Author Posted November 16, 2014 Lipo Batterys, fortunately i have enough of them Quote
Zerobricks Posted November 16, 2014 Posted November 16, 2014 Lipo Batterys, fortunately i have enough of them Nice! Will you have any left Quote
efferman Posted November 16, 2014 Author Posted November 16, 2014 no, these are all of my lipos Quote
efferman Posted November 17, 2014 Author Posted November 17, 2014 the cab is done and the base of the outriggers is placed Quote
Freekysch Posted November 17, 2014 Posted November 17, 2014 All looks great and i cannot wait to see this mean machine in action ! . Quote
Pluto_MkII Posted November 17, 2014 Posted November 17, 2014 What a huge truck. How sturdy is the design? Quote
efferman Posted November 17, 2014 Author Posted November 17, 2014 The rear frame could twist a bit, but everything else is really solid. Quote
efferman Posted November 18, 2014 Author Posted November 18, 2014 The outrigger box is complete. lxf Quote
efferman Posted November 19, 2014 Author Posted November 19, 2014 in meanwhile a flatbed version of the THW, a technical support corps in germany. not sure if this colour scheme is possible but when it is extremele expensive Quote
Zerobricks Posted November 19, 2014 Posted November 19, 2014 That looks really nice! Nice usage of studded beams for the chassis. Quote
Zerobricks Posted November 19, 2014 Posted November 19, 2014 Thanks for sharing Effy Whyn you will be building this beasty make sure to turn the H frames on the axles in such way that the diff doesnt touch them (groves). The model looks just foxing maassive! Oh I would also reinforce the damper support a bit on the upper, chassis side. Quote
efferman Posted November 19, 2014 Author Posted November 19, 2014 oops, it seems i have forgot that. many thanks zblj, but ifirst i will try to finish my recovery truck. at friday the new parts should arrive. Quote
DrJB Posted November 19, 2014 Posted November 19, 2014 Very impressive build ... One question though (apologies if it has been asked already). Why such custom wheels? Are you planning some third party tires? Quote
efferman Posted November 20, 2014 Author Posted November 20, 2014 i use my ansmann tires on the planetary wheels Quote
Technyk32231 Posted November 29, 2014 Posted November 29, 2014 yes that was my inspiration and currently iam fighting with the front grille. in meanwhile iam working longer on the front than for the chassis 101_9756 von efferman auf Flickr hopefully the contest is not really a simple body shell contest, because this 1954 pickup is my idea for the contest.so be patient, more pics from the full moc will not come till the contest begins. Efferman, it seems as if this suspension is actually used in real life...https://www.google.com/search?rls=com.microsoft%3Aen-US%3AIE-Address&tbm=isch&q=sliding%20block%20rear%20suspension&revid=1547902220&ei=lwZ6VPeHJfSHsQSh94Eg&ved=0CCMQsyU&biw=1280&bih=599 Quote
efferman Posted November 29, 2014 Author Posted November 29, 2014 Cool, thanks for showing me this. Quote
