I think he means more sections like we often see on trucks, mostly 4 or 5 sections.
So all the printed parts from the crane cost €105,- together?
That's a nice price.
Maybe in the future.
Edited by Dafgek81
  • Replies 3.4k
Posted Images
Effe you got 2 movable sections that are together so long as the base section. In real life is every section near so long as the base section and every section is extended with separate pneumatic cylinder.
Do you plan to make it so? Per section 1 pneu cylinder? And/Or to add more sections?
How rigid are the sections? I got your big LAs from shapeways and the material (nylon?) is significantly softer.
Max
max, the new pneumatics has a stroke of 48mm. To make the extensions the same length as the outer box is wasted money. And the connection points are not possible. More sections would make the tubing extremely complex so i have skipped this.
The sections are solid enough for the lifting power. No bending or squeezing.
Edited by efferman
Are the tilted beams for a base for the front axle which would give it caster? so that the axle itself remains simple so you can have reliable 4wd.
I ask because with most Rc buggy's i've seen the caster is pulled of that way (also in some moc's of mine and eg 8675)
Looking forward to the new version of your awesome G :p
Thanks!
Now i have to decide which body it will get at the back
Station Wagon, Crew Cab Pickup, Two seater with long flatbed or a convertible Pickup?
Edited by efferman
