  • Replies 3.4k
Posted Images
my approach to make the xerion remote controlled is to hold the costs in electrics down. so i want youse only one servo and a XL for propulsion. To rotate the cab i will use the original lever, and switching between steering modes will be manual too
work in progress lxf
is it possible to 3d print dummy power function motors so someone could build non functioning MOCs. There must be a lot of lego builders out there that wish they could build a static MOC without the motors. If dummy motors were available all the plans for most MOCs would not have to be altered.I wonder if TLG would allow this to happen. Let me know
Looks good effe, although I don't have a strong preference for RC, I appreciate your ideas for improvements to the structure and playability.
Do you plan a trailer hitch, maybe like the prototype you made for your Arcos? I really miss this feature on the standard model.
looks great, you have such a knack for this stuff! I do think this is stretching the term "mod" a bit far though... I would consider this more a "xerion 2.0"
@Cumulonimbus i think this would collide with the attachment lift. More important would be a pendular front axle for which i had an idea yesterday evening.
  • 5 months later...
1L trans-clear pieces could work as extra lights in between the connectors in the grille, but 2L headlights which I assume you mean, I agree is probably best done as LXF suggests.
