So only one axle has a gear rack or some other method to steer an axle and the rest also get steered using the axle connections shown in the underside picture?
That is really interesting, thanks for sharing!
  • Replies 3.4k
Posted Images
17 hours ago, efferman said:
on the convention this weekend we talked about havy duty modules and here is a small sketch
Interesting idea, I have been contemplating building a mobile dockside crane which would have a multi wheel under carriage similar to your HD trailer.
I was thinking of using the small 28Z turnatbles for each wheel with steering via worm drive, but a lever & reach rod system looks less complicated.
How secure would the axles be in the various connectors under tension ?
Each axle in your set up appears to turn a different amount which OK if being used as a trailer, for mobile crane need all wheels to turn together in unison.
Several cranes of this type are at work at the Port of Tyne near where I live and also are built in the NE England by Liebherr.
For a Dogwalk it is neccessary to have on all wheels the same steering angle, but when it should have a good turning circle the ackermann geometry is neccessary. How stable the steering system is will only show a test under load.
27 minutes ago, efferman said:
No Panels, but 5x7 frames.
So I suppose that you will use it as transporting platform for some container ore something like it?
Coupling back on back works, even when i have still not enough tires
edit: small video of the wide coupling
Edited by efferman
Efferman I love you. I've been waiting for someone to build a scheuerle-style Technic trailer for years and you deliver <3 Is there any chance you'd do reverse building instructions for this?
I am always amazed Mr Efferman how fast you can go from version 1.0 to 3.0 and the design improvements its hard to keep up with LDD.
I do have to confess I love the look of version 1.0 with the open frames and the steering system as it gives a fully closed over deck but the
part count compared to version 3.0 is a lot higher.
Not only the Partcount is improved. The 5x7 frame version doesnt work really smooth, because all the gaps let the steering hook while it moves.
