efferman Posted August 25, 2018 Author Posted August 25, 2018 (edited) A small vid of the realistic wide version. edit: station wagon anyone? Edited August 25, 2018 by efferman Quote
efferman Posted August 26, 2018 Author Posted August 26, 2018 On 8/24/2018 at 9:20 PM, I_Igor said: Something like 1:18 ? Have searched for the dimensions and the scale is rough 1:17 so it fits nearly to the arocs scale Quote
1gor Posted August 26, 2018 Posted August 26, 2018 1 hour ago, efferman said: Have searched for the dimensions and the scale is rough 1:17 so it fits nearly to the arocs scale That idea I had when I was building 1:17.5 Unimog because I wanted to make Humvee, but it also has portal axles and independent suspension what was to much to integrate in such small scale, but your pickup version is cute. Really like it will h rims fro m 42080 set if I'm not mistaken. If it is roughly 1:17 it could also be close to your Scania is which is like M.A.N. some 1:16.67 scale Quote
efferman Posted August 29, 2018 Author Posted August 29, 2018 a small test of a forklift. one Servo, and 3 PF-M Lifting height is 24 studs Quote
BrickbyBrickTechnic Posted August 30, 2018 Posted August 30, 2018 Is the forklift height you show in the video the maximum height? If so, I find that to be a bit low. Quote
Ivan_M Posted August 30, 2018 Posted August 30, 2018 Seem to me a little bit too wide and I don't like that mLA in cabin as well Quote
efferman Posted August 30, 2018 Author Posted August 30, 2018 (edited) @BrickbyBrickTechnic 24 studs are the max Height with the string of 42079. 31 studs are no problem with a longer String. @Ivan_M The width is only 18 studs at front Edited August 30, 2018 by efferman Quote
Ivan_M Posted August 30, 2018 Posted August 30, 2018 It is difficult to judge from the pictures, maybe it is correct width. Do you work with some kind of real world reference machine or just build for fun without too much hassle? Quote
efferman Posted August 30, 2018 Author Posted August 30, 2018 @Ivan_M it is losely based on the dimensions of a kalmar dcg 90-6 Quote
1gor Posted August 30, 2018 Posted August 30, 2018 Width is as it should be, perhaps there is s possibility to put linear actuator below cab, IMHO lifting height is really good Quote
AFOLegofan66 Posted August 31, 2018 Posted August 31, 2018 this looks to me like this could lift a really heavy load. Is it designed to do so? if so how would the counterweight work? I know in real life these machines can weigh a lot but some have a very heavy counter weight built in the vehicle. Are we to assume that this forklift has the same capacity? Quote
efferman Posted August 31, 2018 Author Posted August 31, 2018 The lifting capacity is not high enough to make a counterweight neccessary. Quote
brickless_kiwi Posted August 31, 2018 Posted August 31, 2018 Sorry tired tonight, But IMO it is a buildable and playable MOC, I have Kevin Moo's forklift built and the part count for that model is 1768, I would think Effermans would be hard pressed to be more than 800? parts. I suspect that you could build this moc ( minus the PF ) out of a 42076 and 42079 and still have change to buy a Bugatti compared to kevins. As for the tilt ram in the cabin, My Mitsubishi 6.0 tilt ram pivots sit right next to the brake and accelerator pedals and honestly I use it as a foot rest when travelling between yards ( about 3km's ) Model Comments, I would add work lights to the cabin, maybe also a seat and controls detail, ( ok that's uping the parts count ) but Efferman Moc's always have those suttle details. Quote
efferman Posted August 31, 2018 Author Posted August 31, 2018 (edited) @brickless_kiwi Partcount of the lxf screenshot is 737. I guess even with upcoming details the partcount should be below 1000 parts. The next Chassis revision with a significantly lowered tilting pivot point to increase the lever for the tilting cylinder edit: some small scale test Edited August 31, 2018 by efferman Quote
efferman Posted September 1, 2018 Author Posted September 1, 2018 Which engine hood would you prefer? The thick or the flat one? Quote
WvG_853 Posted September 1, 2018 Posted September 1, 2018 My initial reaction was the flat one, but in the end I prefer the fat one. It is also more in line with the Kalmar ... Quote
1gor Posted September 1, 2018 Posted September 1, 2018 The fat one (in this exceptional case fat is OK) Quote
efferman Posted September 2, 2018 Author Posted September 2, 2018 Seems we have the same opinion. Quote
1gor Posted September 2, 2018 Posted September 2, 2018 this is only thing that I can say. It would be great official set the way you modified it. Quote
pagicence Posted September 2, 2018 Posted September 2, 2018 I'm a bit late to the party, but I also say stick with the thick one (which you obviously have). Quote
efferman Posted September 29, 2018 Author Posted September 29, 2018 New Project Converting my R530 into a Recovery Truck. First Tries with a bruickbuilt Towing Fork were not satisfying, So there was a need for a printed one. Unfortunately with a small bug in the printing file. Maybe you see the white parts There the parts were to close together. Quote
efferman Posted September 30, 2018 Author Posted September 30, 2018 (edited) The decission for the Axle configuration is done. The Wheelbase is a bit long, but the rotator will need its space. Crouch recovery Edited September 30, 2018 by efferman Quote
