Zerobricks Posted October 26, 2011 Posted October 26, 2011 (edited) So two days before going to Legoworld I wanted to build a small unimog. After buidlinge entire night here is what I came up with: Features: Pernament all wheel drive Working live axle suspension on both axles Working fake I4 engine Motorized bed lift and rear PTO Optional front PTO powered by wheels. Here is the mechanics from under: Depending how you attach the bed with pins the bed can be tilted bacwards: Or sideways: The rear PTO is powered by a switching emchanism that switches power between bed lifting and PTO: Later while recording I noticed a possibility of a front PTO drive from the engine via the wheels: I made both versions in LDD: NORMAL VERSION LDD FRONT PTO VERSION EDIT: Link wont work, so here it is: www.brickshelf.com/gallery/zblj/Minimog/minimog-frontpto.lxf Also check the video: Hope you guys will try make one and play arround with different attachments. Edited October 26, 2011 by Zblj Quote
nikolyakov Posted October 26, 2011 Posted October 26, 2011 Very good little model. Congratulations! Quote
yoraish Posted October 26, 2011 Posted October 26, 2011 Very nice! I like it :thumbup: Too bad there is no room for a drive and steering motors Quote
GuiliuG Posted October 26, 2011 Posted October 26, 2011 It's a nice concept and your unimog seems to be very playable but I'm not fan of its look and how it's build ( the frame doens't seem very clean, maybe due to all these different colors, or is it just the way it is built?). Quote
bord4kop Posted October 26, 2011 Posted October 26, 2011 (edited) It 's nice, very nice. All these functions in such a small model. Looks are ok too. Especially when considering you build it in just one night! :thumbup: Edited October 26, 2011 by bord4kop Quote
apemax Posted October 26, 2011 Posted October 26, 2011 Very nice "Minimog" Zblj. I like how you managed to fit all those features in a small model. Well done. Quote
Alasdair Ryan Posted October 26, 2011 Posted October 26, 2011 (edited) Very nice unimog zblj , i do think the rear end and the front ends needs a wee bit more work. Edited October 26, 2011 by Alasdair Ryan Quote
dikkie klijn Posted October 26, 2011 Posted October 26, 2011 Nice model, I like the tipping bed . Have a RC chassis of small version still haning around need to finish it someday . Quote
T_Tank Posted October 26, 2011 Posted October 26, 2011 I took some time today to try an figure out how to make this unimog rc by connecting the rear pto system through the gear train to the motor an wheels. Steering was direct drive to the front rack. The shift ring is still inside the vehicle to be toggles a rubber band would be used to keep it in drive until you want to flip the switch to dump the bed. Quote
dhc6twinotter Posted October 26, 2011 Posted October 26, 2011 I like it! You've managed to fit a lot of features in a small space. Quote
timslegos Posted October 26, 2011 Posted October 26, 2011 Very nice creation!! I true expert builder like you is able to make technic creations at any scale, and pull it off well. tim Quote
DLuders Posted October 26, 2011 Posted October 26, 2011 (edited) @ Zblj: Maybe your "Black Wolf" and Minimog can have a Tug-of-War battle at LegoWorld! @ T_Tank: Can you share the LDD .lxf file of the Minimog's RC version? Here's how to do it: http://www.eurobricks.com/forum/index.php?showtopic=58423 . EDIT: T_Tank sent me a message with this link to the MinimogRCmod .lxf file: http://www.brickshelf.com/gallery/T-Tank/Randomstuff/minimogrcmod.lxf . Edited October 27, 2011 by DLuders Quote
T_Tank Posted October 27, 2011 Posted October 27, 2011 Like to see how well the rc conversion works since i don't have the physical parts atm to see how well it operates so post pics guys! Quote
Rocketbilly Posted October 27, 2011 Posted October 27, 2011 I'm not usually one for Technic, but this is a really nice little model, and would make a great companion set to the LEGO Unimog. I like the functionality of it, and I really like how tough and durable it looks. Quote
JunkstyleGio Posted October 27, 2011 Posted October 27, 2011 Both ZBLJ's model and T_tanks adaptation are very nice! They should both be added to rebrickable! Quote
T_Tank Posted October 27, 2011 Posted October 27, 2011 kinda hope someone can test out the rc version for any bugs that might be in the lxf in terms of gearing <,< Quote
Zerobricks Posted October 27, 2011 Author Posted October 27, 2011 (edited) Wow, nicw to see it get so popular and already modifyed! As seen by T-Tank you can easily put PF M motor inside. Now here is my suggestion: Put the old 9V battery box out and put two M motors side by side. They can be both used for driving, or one for drive and other for steering. There is much room on the back for a PF battery box Edited October 27, 2011 by Zblj Quote
T_Tank Posted October 27, 2011 Posted October 27, 2011 (edited) Wow, nicw to see it get so popular and already modifyed! As seen by T-Tank you can easily put PF M motor inside. Now here is my suggestion: Put the old 9V battery box out and put two M motors side by side. They can be both used for driving, or one for drive and other for steering. There is much room on the back for a PF battery box I've taken apart temporarly a few of my mocs to see how the gear box would hold an atm the motor seams to pop out under load so I'll put a updated LXF up later this evening with the fixes. I was thinking about putting both motors side by side on the frame but then the rear dump bed would not be able to stay in place an remain functional. edit-- Here is a update to the rc minimog with some gear reductions at the axles an return to center steering an the biggest fix is a different bracket for the M motor that drives the auxiliary an drive train so it doesn't fall out. rc minimog v2 Edited October 27, 2011 by T_Tank Quote
technicmad Posted November 6, 2011 Posted November 6, 2011 Both ZBLJ's model and T_tanks adaptation are very nice! They should both be added to rebrickable! Good idea :) Thanks DLuders for pointing it out, the v2 Minimog is at: http://rebrickable.com/catalog/zblj/minimog Quote
T_Tank Posted November 6, 2011 Posted November 6, 2011 Update for the rc lxf file now at v3 now with XL motor drive an pneumatic system to lift the bed up an down (switches not shown in the lxf unsure how to make the old style pneumatic switches) V3 rc minimog BTW the physical model i'm using to test these modifications More to come as I figure out how to put together some implements for the pto on the front an rear an when I get the PPTO parts from bricklink. Quote
