From the Lego Technic Challenge webpage:
"Take the Technic Challenge - Vote on the 2011 Adult Finalists
"This is the LEGO® Technic Challenge AFOL FINALS! Since March, all of you talented Technic builders have submitted hundreds of wonderful creations for the monthly competitions, and YOU have selected the monthly winners. It's time now to pick the best of the best from our 2011 adult builder submissions! The winner will receive the full 2011 LEGO Technic product assortment.
"Voting
Selected adult entries from March through September are in the final voting round. You can vote NOW until the end of the month! - Hurry up and go!
"Go Vote!" :cry_happy: There are 16 AFOL finalists! :thumbup:
I wish TLG should have taken up the challenge of their own to let the finalists present their models in a better way than trough these horrible thumbnail-pictures...
I have always thought the same thing!!! TLG should have an option to post a video alongside the photos and maybe allow 2 or 3 photos instead of the terrible tiny thumbnails, which make it extremely hard to see the actual model.\
tim
Here are the 16 Lego Technic Challenge 2011 AFOL finalists (for side-by-side comparisons, and to record them for posterity). I corrected some typographical errors and misspellings in the descriptions:
"Tajima's SX4 hillclimb special" by Prince_Ipactif -- "Model of the car with which Tajima broke the Pikes Peak record in 2011. It is remote controlled with a RC Buggy motor to drive and a M motor to steer. It is submitted as fastest Lego RC car":
"Stingray D-2" by grohl -- "48cm long RC model of a luxury speedboat weighing only 594g. Powered by 2 M motors that give it enough power for good speed and excellent maneuverability":
"Mean Mr. Mustard" by tamasfrank -- "An amazing V40 engine (5 x V8) - motorized suspension to adjust ground clearance - hydraulic gull-wing doors for easy access - adjustable pneumatic side wings to control air flow - opening hatch - metal rear hook for heavy towing - wheelie bars to prevent flipping over during the launch phase":
"Classic crane" by FIN-R2-D2 -- "This PF-ready crane is powered by NXT (in small building). Height 1.34m, lifting height 0.96m, working area (donut) with 200g load 1.34 m2 (car 500g). Manually-adjusted counter weight. Cabin turns down; ladders are in tower. It may bend, but it has never broken or crashed!"
"LegendaryStorm T4 Cabriolet'11" by Sheepo86 -- "Based on a very famous real car, this MOC has around 3500 parts, AWD and, as outstanding features controlled by PF: working 7+R speeds, dual clutch gearbox with friction clutches, disc brakes with rear lights, folding roof and spoiler, progressive accelerator, working steering wheel, handbrake and much more...."
"Sampson and Goliath" by Woolgie -- "A tribute to the largest cranes in the world - Sampson and Goliath at Belfast Ship Building Port. Each crane has two-motor independent lateral and longitudinal movement by remote IR control":
"Helipak" by vmln8 -- "Lightweight single-seat helicopter. It features a single motor, which drives a pair of contra-rotating, concentric propellers. It uses only parts from Technic sets":
"Beach Buggy" by Nimdian -- "This is a beach buggy. Fully RC. Features RWD, full independent suspension, functional steering wheel, opening bonnet and hood, V8 engine at the back. 2 XL motors for driving an M motor for steering. Drives at 1:1 gear ratio. For those who feels the freedom of summer. /peace":
"UNIMOG 416 U100" by tomaszajac1 -- "The model has: all-wheel drive with PF XL motor, working realistic suspension, 2-speed gearbox, portal axles with a reduction. Truck is remote control: drive, gearbox and steering. The vehicle is very efficient in difficult terrain. Obstacles are no problem for him - the same as for real UNIMOG!"
"Unimog 1600" by greasmonkiskid -- "This RC Unimog 1600 has Unimog axles, 4x4, and remote steering. It also has a remote working winch. The winch can go on the front or back of the vehicle. The V-plow is controlled by remote. It has three-link suspension with 4" travel up and down. The truck is 24" long and 9 1/2" tall":
"Flight Simulator" by jovel1974 -- "This flight simulator uses three mini LA's which enable the plane to tilt and lift in all three directions":
"Yellow Storm" by fmartinezsanta6 -- "This helicopter has two small front propellers and back jet engine. It is based on the 8046 Technic kit with several other pieces. The propellers are manually operated through a gearbox":
"crane" by karfo135 -- "Both truss booms and hook are operated by one of 3 winches. Each winch is connected to motor by 2-step gearbox and worm gear acting like brake. Hook and main boom lifting mechanism use pulleys to lower tension in ropes":
"Unimog Mower" by ledfss -- "The length of this model is 40 unit,and the width of it is 17 uints,two motors and one Remote Control and 3 differential.With these parts, I create a real 4×4 truck. Many ppliances can be used by it":
"Ford GT 40 Mk. IV" by grohl -- "Model of a famous racing car from 1967 with opening doors and bonnet, independent suspension, one M motor for steering and two XLs for movement, detailed engine and cockpit, adjustable seat, working front and rear lights":
"trailer" by simcer -- "Trailer combines linear functions with pneumatics. For lowering container it is horizontally moved by a linear movement over half of the length. Then the pneumatic system automatically starts and lowers the container. Can be switched to a tipper function (two linear actuators). All remote controlled":
Edited by DLuders
In the previous post, one can see that the picture WIDTHS of the 16 finalists are all the same, but the top-down LENGTHS are different. The pictures that are in a vertical, "Portrait" format seem to be larger than the horizontal, "Landscape"-format ones. The Technic Challenge webmaster is probably using a fixed webpage "template" to jam the various pictures into a certain width. SO, to have the largest-possible image for the voters to see, recommend submitting your Challenge entries in a photo collage made in a vertical "Portrait" format (like the red car below, and not the yellow truck which is hard to see):
Zblj (the 2010 AFOL winner) has already noticed that Sheepo/ Sheepo86 is the 2011 AFOL winner of the Lego TECHNIC Challenge! Congratulations, Fernando! :classic: Here is the "Legendary Storm T4 Cabriolet '11" winning entry:
"Based on a very famous real car,this MOC has around 3500 parts,AWD and,as outstanding features controlled by PF:working 7+R speeds dual clutch gearbox with friction clutches,disc brakes with rear lights,folding roof and spoiler,progressive accelerator,working steering wheel,handbrake and much more."
PRIZE:
More pictures of the "Porsche 911 997 Turbo Cabriolet PDK" are on Sheepo's Brickshelf gallery, and he has this YouTube video:
http://www.youtube.com/watch?v=ZnGj4wxsNZY
Edited by DLuders
Congratulations! I cant think of a more deserving model to win!! That is a sweet prize to.
tim
Congratulations Sheepo! Love your work, keep it up. Whats in store for next year?!
Thanks to all for your votes and comments!!
I have 3 new big MOCs in the oven for the next year ;)
Firstly and more importantly, well done on this achievement and would like to say congratulations to everyone who won and got this far. The Porsche is, in my opinion, a masterpiece.
BUT...and this is probably where I get banned or run off the board with pitchforks...am I'm right in thinking that model (and probably a few others) was roughly a year in the making? It's all down to Lego and if I was in the same position, I'd enter models that fitted the monthly brief. But there does seem to be a two tier standard - the 20 day build model versus the months of development, master builder models which were never really designed for the competition. To have the best chance of winning in 2012, I should have started building 6 months ago :laugh: and hoped a theme was broad enough to fit.
Actually Brickend you bring up a very good point that has been talked about in the past and also why I feel these contests are somewhat unfair as it seems most people don't exactly follow the rules. This Porsche model is quite fantastic, but if the rules did state that the models were only supposed to be built in a certain time frame and people are throwing in models that they either completed far before the monthly contest even started or spent over a year building them and then they found it was just a convenient time for them to add them into the contest, is that really fair for the other contestants that did follow the rules? So while it is great for Sheepo that he won the prize, can you really feel good about it knowing the fact that you won with having a large advantage that was just overlooked?
Edited by Meatman
@ Meatman: Consider that the Lego Technic Challenge contest organizers often could not clearly state the monthly submission DEADLINES without me having to write them AT LEAST THREE TIMES this year. They had dates that did not match, missing dates, etc. Most GOOD MOCs take a considerable amount of parts (i.e., Bricklink orders). It takes time to obtain all of the necessary parts, build it, then submit it on time. Typically, the monthly deadlines only allowed a maximum of 2-1/2 weeks to submit the entry. That simply is not enough time for INTRICATE MOCs like Sheepo's.
I personally don't mind AFOLs submitting their MOCs that happen to fit the monthly theme. Heck, there was so much PLAGIARISM going on in 2011 (month after month), it's a relief that a legitimate MOCcer won the prize!
Congrats Sheepo! Well deserved!
About the time frame for models to be built: I have spoken in person to the guy responsible for the Technic Challenge. I too was under the impression that the moc submissions could only be built within the contest time frame, but after I asked specifically about this, he assured me that it was perfectly fine to submit models that were previously built. Any moc could be submitted, regardless of time spent building it. All that is required is the "Technic Challenge" sign in the picture.
I have no problem with people submitting project that took a while to build, and If I get a chance, I'll probably submit some of my mocs as well. :grin:
I agree.
Edited by dhc6twinotter
David, I completely understand what you are saying, but what I am saying that it is just unfair to people if they are trying to abide by the rules. Say next year the theme is Lamborghini or exotic I don't think it would be too fair if crowkillers entered his Murcielago.
Like I said, I am happy that Sheepo won and I think his model was the best out of the entries.
I too believe the best model won.
I just think that a monthly competition could be about short, imaginative builds. They may not be the best technically, or be the most polished but they might still inspire and lead to further development.
You wouldn't need to worry about the time it takes to get orders in from Bricklink, just building with what you've got and to the theme.
Some of the competitors did this and I applaud them, they weren't perfect but they were very creative within the short time constraints.
I would also have an overall category for 'ultimate' builds at the end of the year. They should be acknowledged as well, but in a different sense.
Most of this is irrelevant as the plagiarism has knocked a lot of the spirit out of the event, I wouldn't be too surprised if it gets canned.
