Holodoc Posted September 28, 2012 Posted September 28, 2012 Lego minecraft brick and tile. As much as I like most of your ideas, I don't get the point in the minecraft brick. It looks bigger than the "normal" 2x2 brick, the axle holder seems a bit out of place, too. What is it good for? Quote
purpleparadox Posted September 28, 2012 Posted September 28, 2012 What is it good for? I'm not sure, but if it does ever get produced, don't tell my brother! He's a huge Minecraft fan and I bet he'd spend hundreds of dollars to make a huge Minecraft world MOC with those bricks. Quote
Nachapon Lego Posted September 28, 2012 Author Posted September 28, 2012 (edited) As much as I like most of your ideas, I don't get the point in the minecraft brick. It looks bigger than the "normal" 2x2 brick, the axle holder seems a bit out of place, too. What is it good for? It is good for Minecraft fan. The brick is 2x2x1⅔ and 2x2x1⅓ to make a cube minecraft block in minifig scale. (brick+2 plates and brick+plate+tile) The position of axle holder is same as technic brick 1x2 with crosshole sandwich by two plates. But it should up-down-up-down to prevent the collision of 2M cross axles at 90°. I'm not sure, but if it does ever get produced, don't tell my brother! He's a huge Minecraft fan and I bet he'd spend hundreds of dollars to make a huge Minecraft world MOC with those bricks. So do my little brother! I will try to make more blocks with different Minecraft decors and some Minecraft characters minifig. Edited September 29, 2012 by bbqqq Quote
Nachapon Lego Posted October 11, 2012 Author Posted October 11, 2012 (edited) lego minecraft bricks & minifig by nachapon bbqqq by Nachapon S., on Flickr lego minecraft minifigures by Nachapon S., on Flickr Edited October 11, 2012 by bbqqq Quote
Nachapon Lego Posted January 2, 2013 Author Posted January 2, 2013 (edited) I found this idea on brickset.com. http://www.brickset....rticle/?ID=5321 The author Takanuinuva said "If someone who is good at making 3d images of lego parts. Perhaps you could make 3d images of my parts for easier viewing" . New Short Minifigure Parts by Takanuinuva by Nachapon S., on Flickr Edited January 2, 2013 by bbqqq Quote
legolijntje Posted January 2, 2013 Posted January 2, 2013 That looks very good. I don't understand why Lego doesn't make small movable legs? Any ideas? Quote
Calabar Posted January 2, 2013 Posted January 2, 2013 Probably because the short legs are very limited in movement when attached to a basis. And because are cheaper, obviously! About the "minecraft guys", I like the first version, but with the arms of the third one. Quote
Nachapon Lego Posted January 2, 2013 Author Posted January 2, 2013 That looks very good. I don't understand why Lego doesn't make small movable legs? Any ideas? Probably because the short legs are very limited in movement when attached to a basis. And because are cheaper, obviously! About the "minecraft guys", I like the first version, but with the arms of the third one. Thanks, I found that the legs are still too long so a modify it a bit. New Short Minifigure Parts by Takanuinuva 2 by Nachapon S., on Flickr Quote
Calabar Posted January 2, 2013 Posted January 2, 2013 There could be another reason for the "unmovable" legs made by TLG (and I think it is the main reason): These legs seems to be longer because designed to appear partially hidden under the torso. Movable legs instead appears too short, and the minifig became disproportionate. Quote
Nachapon Lego Posted January 2, 2013 Author Posted January 2, 2013 (edited) There could be another reason for the "unmovable" legs made by TLG (and I think it is the main reason): These legs seems to be longer because designed to appear partially hidden under the torso. Movable legs instead appears too short, and the minifig became disproportionate. You are right, Calabar. The 2nd version will let minifig's height close to minifig with TLG "unmovable" short legs. And close to Takanuinuva's original design here http://lego.cuusoo.c...deas/view/29452 But legs appears too short. Maybe it is because of this minfig model is base on Ldraw's minifig and seem like the orange belt is too thick. Another solution is to make Takanuinuva's short torso and short arms, too. But it will require five new moulds in total. Edited January 2, 2013 by bbqqq Quote
hrontos Posted January 2, 2013 Posted January 2, 2013 (edited) May be this has some structural limitations. If you look at a real minifig leg and how it is attached, there is high probability that stud would not fit into that short version. Or it would not be sturdy enough. I am also not sure about movement, such short legs would be quite stiff to move. But it would be nice to have such cute little moveable legs. Edited January 2, 2013 by hrontos Quote
Nachapon Lego Posted January 4, 2013 Author Posted January 4, 2013 (edited) May be this has some structural limitations. If you look at a real minifig leg and how it is attached, there is high probability that stud would not fit into that short version. Or it would not be sturdy enough. I am also not sure about movement, such short legs would be quite stiff to move. But it would be nice to have such cute little moveable legs. I agree with you, how about this leg idea. http://www.shapeways...oductBox-search Not sure about this gear. If stack many of them zigzag way can make small gearbox with high gear ratio. Lego new gear 24 + 8 teeth with hollow shaft. by Nachapon S., on Flickr Edited January 4, 2013 by bbqqq Quote
Nachapon Lego Posted January 5, 2013 Author Posted January 5, 2013 (edited) The 24 teeth outer/ 8 teeth inner double gear with hollow shaft can make a smaller gearbox with high gear ratio. The gear ratio = 3 ^ (number of new gear + 1) For example use 4 new gears as pic below (hollow shaft simulate). gear ratio => 3^5 => 243 : 1 http://lego.cuusoo.c...deas/view/33160 Lego new double gear 24 + 8 teeth with hollow shaft.(simulation) by Nachapon S., on Flickr Edited January 5, 2013 by bbqqq Quote
Nachapon Lego Posted January 9, 2013 Author Posted January 9, 2013 Technic Double+ Gears with Hollow Shaft. lego hollow shaft gears by Nachapon S., on Flickr Quote
Nachapon Lego Posted January 13, 2013 Author Posted January 13, 2013 (edited) Add new 2nd pic on http://lego.cuusoo.com/ideas/view/2750. Usage example: Eliminate unwanted gap cause by connector peg with knob SNOT technique. bubble_bobble_character by arvo by Nachapon S., on Flickr Edited January 13, 2013 by bbqqq Quote
The Mugbearer Posted January 14, 2013 Posted January 14, 2013 (edited) Yay, I just now saw those Minecraft minifigs and blocks! And they are brilliant! =D Edited January 14, 2013 by -N13OS- Quote
Nachapon Lego Posted January 14, 2013 Author Posted January 14, 2013 (edited) Yay, I just now saw those Minecraft minifigs and blocks! And they are brilliant! =D Thanks, I'm glad you like those Minecraft minifigs and blocks. They are my favorate. I put them on cuusoo and update many times, but don't know why, this project always be reject by cuusoo staff (show: Needs Work). So I put it on MOCpages here http://www.mocpages.com/moc.php/343409. Edited January 14, 2013 by bbqqq Quote
Nachapon Lego Posted February 11, 2013 Author Posted February 11, 2013 (edited) Thanks for your supports. I got an official Lego comment on cuusoo here. http://lego.cuusoo.com/ideas/view/2750 It is a good idea to add a 1x4 plate there. Lego Design ID 11267 Slide 6 Modules High new part by Nachapon S., on Flickr Edited February 11, 2013 by bbqqq Quote
Nachapon Lego Posted October 10, 2013 Author Posted October 10, 2013 (edited) Pegasus-Saddle with wings holders. Thanks to EB member"The Real Indiana Jones" for this good new brick idea. Cuusoo project in review stage. http://lego.cuusoo.com/ideas/view/51303 please support(vote) if you like it, thank you. Lego Pegasus-Saddle idea byThe Real Indiana Jones by Nachapon S., on Flickr Edited October 10, 2013 by bbqqq Quote
Nachapon Lego Posted October 11, 2013 Author Posted October 11, 2013 (edited) Wings of a wild and free Pegasus can be attached using exiting parts, but not so stable. Lego Pegasus-Saddle 3 idea byThe Real Indiana Jones by Nachapon S., on Flickr Edited October 11, 2013 by bbqqq Quote
Nachapon Lego Posted October 13, 2013 Author Posted October 13, 2013 (edited) Pegasus-Saddle with wings holders. Cuusoo project http://lego.cuusoo.com/ideas/view/51303 This idea base on "The Real Indiana Jones"(therealindy) 's suggestion. Please also support(vote) his I.M.C.T.B. : THE INFINITELY MODULAR CLASSICAL TEMPLE BUILDING project below. http://lego.cuusoo.com/profile/therealindy#projects Lego Pegasus-Saddle 4 idea byThe Real Indiana Jones by Nachapon S., on Flickr Edited October 13, 2013 by bbqqq Quote
Nachapon Lego Posted October 15, 2013 Author Posted October 15, 2013 (edited) Alt versions of Pegasus new part from The Real Indiana Jones. Lego Pegasus-Saddle 5 idea byThe Real Indiana Jones by Nachapon S., on Flickr Edited October 15, 2013 by bbqqq Quote
freakwave Posted October 24, 2013 Posted October 24, 2013 Add new 2nd pic on http://lego.cuusoo.com/ideas/view/2750. Usage example: Eliminate unwanted gap cause by connector peg with knob SNOT technique. bubble_bobble_character by arvo by Nachapon S., on Flickr Did you ever had a sample of that 3D-printed? I would be interested to do so for a trial Quote
Nachapon Lego Posted October 24, 2013 Author Posted October 24, 2013 (edited) Did you ever had a sample of that 3D-printed? I would be interested to do so for a trial Thanks, I will very happy to see it in 3D-printed. What 3D file format do you use for 3D-print? I can send it to you. Today I test it by modify(cut) the cross axle 3M with knob, it work fine and can be pull out by nails easily. LEGO 2-sided stud prototype cuusoo nr 2750 by Nachapon S., on Flickr Edited October 24, 2013 by bbqqq Quote
SNIPE Posted October 29, 2013 Posted October 29, 2013 (edited) Hi I'd like a guide bracket/connector that enables the new 8 tooth gear to be used with double or single bevel gears There would be one either side and one would be flipped horizontally to allow the bevel gear to fit in right: if its being used with a double bevel gear you simply move each bracket outwards by 0.5L as it equals 1L which is how thick double bevel gears are The 8 tooth gear has some of the axle sticking out to allow it to drop down for the smaller side bevel gear however it needs to have a spacer too but is flush with the tops of the brackets. The brackets have end holes too so you can add more support beside the axle on the 8 tooth gear. the total dimensions of the brackets excluding the bevel gear is 3x3L which is quite compact, each bracket is 1x1x3 so its like a 3L liftarm. You can probably using the large side bevel gear too if you add some spacing between the brackets and your model but I wouldn't recommend putting high load onto it incase you break the 8 tooth gear, I'm doubtful that the old 14 tooth gear would work especially since its a stupid thickness. The sides of the brackets have 1 or 2 pinholes (undecided) This idea would make it possible to have a simple way to use the new 8 tooth gear in situations where you need a new gear ratio or where there is little space Edited October 29, 2013 by SNIPE Quote
