  • Replies 208
The problem is if you do it with that brick you'd need to push the two bevel gears into the 8 tooth gear and that will leave a small gap behind each bevel gear so my bracket idea eliminates that (that's the idea anyway)
it also allows the brackets and the 8 tooth gear to line up with holes on beams by moving the hole for the bevel gears so they are in the right place to connect to the 8 tooth gear without need some odd spacing or needing to cut the gears.
maybe your idea could work with an un- cut 8 tooth gear, and a 12 tooth bevel gear with a washer behind it.
Edited by SNIPE
Thanks to LXF files by:
4996 - Beach house (A model) - by Calabar
5891 - Apple Tree House (A model) - by Johnnhiszippy3
31012 - Family House (A model) - by Stephan
31009 - Small Cottage (A model) - by Stephan
5771 - Hillside House (A model) - by BrickWild
Live piano BGM!
YouTube video of the new AA Roof Tile (Anti-Aliasing Roof Tile).
Compare with standard roof tile.
These new AA roof tiles use standard LDD to create with help of lxfml edit trick only, and can be rendered using LDD2PovRay.
The New AA Roof Tile System slope brick design _YouTube _Mecabricks_Demo by Nachapon S., on Flickr
The New AA Roof System new design_YouTube youtu.be/NSAUSCdEgFs  _Mecabricks Demo by Nachapon S., on Flickr
Edited by bbqqq
That's interesting, how did you introduced new geometries editing the lxf file only?
This trick can make all kind of simple new parts. But it require LDD ver.4.2.5(or below). The new version will always revert the lxfml geometries editing to defult state, then didn't work.
A quick MOC sample. Please see how this one was built on 2nd YouTube video in post #179 above.
The New AA Roof System design _YouTube_LDD_Demo by Nachapon S., on Flickr
The New AA Roof System design _YouTube_LDD_Demo2 by Nachapon S., on Flickr
Edited by bbqqq
I'm not sure I understand either how you can do this. Interesting though. Can you explain a bit?
Please support(vote) @ cuusoo, thank you.
http://lego.cuusoo.com/ideas/view/2750
Four 2-sided for SNOT work very well in LDD. YouTube demo comming soon.
2-sided = like get tons of new parts and new building techniques.
All four types of 2-sided new bricks create using Notepad only.
2-sided = get tons of new parts and techniques_YouTube demo comming soon by Nachapon S., on Flickr
Edited by bbqqq
Maybe the lxf format allow to store custom bricks inside the lxfml file.
A "for future use" feature that never has been used.
bbqqq told he will spoke about that in private with Superkalle, maybe the staff is evaluating if the technique infringes the LDD EULA (as it don't involve the hacking of the LDD software, I hope there are not problems about that).
I know the textures in the Minecraft one were used with a method that breaks the LDD EULA and uses 3rd party software.
It is possible both to add custom textures and custom bricks without to breaks the LDD EULA, samples below. ;-)
All of the LXFs below can be shared, and open/render correctly in any standard installed LDD.
Lego LDD minecraft cube made of 1x1 tiles by Nachapon S., on Flickr
LEGO minecraft decors made of 1x1 1x3 2x2 tiles A by Nachapon S., on Flickr
LEGO minecraft decors made of 1x1 1x3 2x2 tiles C by Nachapon S., on Flickr
2-sided = get tons of new parts and new techniques_YouTube demo out now by Nachapon S., on Flickr
Lego LDD decal made of four 2x2 round tiles b by Nachapon S., on Flickr
Edited by bbqqq
It is both possible to add custom textures and bricks without to breaks the LDD EULA, samples below. ;-)
Doesn't this use a lxfml file trick (that I was messing with last night)?
Thank you for your post.
Yes, five LXFs above use lxfml file trick only.
Special thanks to Superkalle for discuss with LDD team.
I am allowed to share some LXFs new parts which are not too closed to breaks the LDD EULA.
ie: AA new roof system 2x1 2x2 2x3 2x4 2x8, Pegasus-Saddle idea by The Real Indiana Jones..
Edited by bbqqq
LXF template with all red AA roof tiles in pic below, support LDD 4.3.6.
http://www.brickshelf.com/gallery/nachapon/94UCSSSD/92_aa_roof_tiles_for_ldd436.lxf
LXF of Unofficial LDD 71006 The Simpsons House Roof MOD and more
http://www.brickshelf.com/gallery/nachapon/94UCSSSD/51_unofficial_lego_simpsons_71006__ldd_by_nachapon.lxf
You can save each of them as LDD's template or groups for easy use.
Some AA roof tile template set now support lastest LDD 4.3.6. Some engrave patterns roof tile added.
Left house = original, middle four = LDD4.2.5, right three = LDD4.3.6.
Thanks to 31009 - Small Cottage (A model) - by Stephan.
flickr Original pic size(4096 x 2304).
Lego Anti-Aliasing Roof Tile template_support standard LDD 4.3.6 by Nachapon S., on Flickr
Edited by bbqqq
  • 4 months later...
This is somehow the first time I've found this post! It's amazing what you guys can do! But what about some of smaller bricks? Newer or older that have never been used. For example in the new Ultra Agents or some old bionicle pieces?
  • 7 months later...
This is a great thread. Kudos for the author for posting so many ideas and responding thoughtfully to everyone's feedback. I have my own ideas for new parts, but nothing as grandiose as this collection!
http://www.brickshel..._for_ldd436.lxf
http://www.brickshel...by_nachapon.lxf
bbqqq, how did you do this, man?
