allanp Posted July 8, 2013 Posted July 8, 2013 (edited) Something the same speed and torque of the micro motor would be cool in a pf form and way more reliable, or at least easy to open so you can un-jam the gears, I never really liked dropping mine onto a tiled floor to get it working again. Edited July 8, 2013 by allanp Quote
Junpei Posted July 8, 2013 Posted July 8, 2013 I guess I should've mentioned that there is enough space to gear it down much like the harmonic drive in the micromotor, and since it is only 1,5 studs long there might be room for two harmonic drives. That might be painfully slow though. Quote
The Ghost Racer Posted July 9, 2013 Posted July 9, 2013 So cool, but i think that micro motor is smaller than xs and than you can use it to make much things Quote
The Ghost Racer Posted July 9, 2013 Posted July 9, 2013 (edited) I found this pic of various motors here http://www.philohome...s/motorcomp.htm, I hope you find it useful MOD Edit: Removed large image - please see Members Guidelines for max image size rules! Thanks! Edited July 9, 2013 by Si-MOCs Removed large image. Quote
Junpei Posted July 10, 2013 Posted July 10, 2013 Yes the micromotor can easily be used with technic especially because of the fact that it is 2 1/3 bricks high for easy mounting on technic bricks, but I think the usefulness of the xs motor vs the micromotor depends on the dimensions you're working with. e.g. the micromotor is only 3 studs long with the pulley but is also 5 studs tall if there are 1x2 technic bricks on the top and bottom. However with the XS motor it is completely the opposite, 5 studs long and 3 studs tall (or wide). But its shape is less blocky and more technic-oriented, plus having the advantage of fitting in a linear actuator holder, so I think depending on your situation it might be a real improvement. Quote
allanp Posted July 10, 2013 Posted July 10, 2013 5 studs long? It would have to be smaller that that to be worth while I think. Quote
Junpei Posted July 10, 2013 Posted July 10, 2013 Yeah I guess you're right. I think 4 studs long would be possible, considering the motor is 2.5 stud and the axle hole has to be 1 stud, that would leave 0.5 stud left in the middle for gear reduction. Quote
pepijnyp Posted May 19, 2014 Posted May 19, 2014 I Thought of the same thing, but with the Rc motor. I Think we need a new pf motor, a replacement of the RC-motor, because if you want to buy one now you have to pay very much. This is a concept, I hope more people think the same Quote
Nico van Duin Posted May 19, 2014 Posted May 19, 2014 (edited) Nice concept! But I would rather see Lego making a new pf-motor with the same characteristics as the rc-motor(high speed and power! ), but with a different shape, such as the L-motor, so it's easier to mount. Edited May 19, 2014 by Nico van Duin Quote
