Hello people, this is my first topic so wish me luck! :thumbup:
Ok so i was reading about the xs motor topic and the longer pneumatic topic, and i was thinking, so i made this to discus all ideas of power functions!
My first idea was for a new battery box, one(s) like we have now, but have more power. Someone at TLC (name excapes my mind right now, plus this was a while back) The battery box can power 2 XL- Motors or 4 M- Motors or 1 XL- Motor, and 2 M- Motors and any combination of lights and RC... well for alot of us (us as in AFOLs that make MOCs all the time) use multiple (as in 3 or more) xl motors and tons (maybe sometimes too excessive) lights, huge rc remotes using multiple (again 3 or more) rc receivers, or any combination that would destroy the battery box (on huge mocs, ones that use like 4 ir receivers and like 4 xl motors and the excessive amount of lights and tons of m motors, would right out slaughter the battery box)
so i was thinking of making a battery box that could hold alot of functions, yes it would be bigger, but its better than using multiple battery boxes!
anyone with me on this??
  • Replies 80
Well I'm not with you, the LEGO 60€ is very decent and bigger is the same as more space. You could also just get a battery box from your local electronics store of course for C or D cells.
well i mean one meant for technic, like the one that comes in the motor set, and where i live theres not many electronics stores that will sell a battery box, and the nearest hobby store that has one that might be good enough is over 2 cities away from me, plus for people like me who dont know how to rewire the cables to make it match lego's pf connectors, it wont work and where would we get a conversion cable?
and thank you Sok for agreeing with me :thumbup:
Edited by zewy623
3 way swith for??? are you meaning like a polarity switch that can switch between 3 functions??
like when you have two wall switches in a room which control the same light. that's a 3-way switch (i believe they call it a 2-way switch on the other side of the pond). it should have a contact button like sensor bricks and sounds bricks have, though, rather than a toggle like a wall switch.
KEvron
I support the idea of having more than 4 IR channels for PF. But it should definately be compatible with the existing IR receiver and remotes.
Edited by le60head
@le60head
that makes no sense... you need the new remote and receiver to get the extra channels.
Hey there! Sorry, didn't explain clearly what i had in mind:
The new receivers & remotes should be backward compatible IMO. It would be a pain to use the NEW receivers only with the NEW remotes. Wouldn't it be more convenient if the new remote for example can use the existing channels 1-4, and be able to operate on 4 more channels (5-8 for ex). I'm not sure if the IR signal could support more than the existing 4 channels though :)
P.S.
Can someone please explain what "proportional" rc means?
Does it mean that spinning/pushing the control lever/wheel by X degrees results in the motor spinning the same amount? Thanks in advance!
Edited by le60head
@le60head
ok i see what you mean now.
and in the simplest terms i can think of for proportional, without using the dictionary term, is like the speed rc controller. on the speed you can set how fast a motor turns, on regular you cant, basically its setting how much power goes to the motor, but with lights it doesnt work.
I'd like to see PF remotes/receivers using RF instead of IR.
I vote for servo motors. A PF pneumatic valve would be nice as well.
Having 4 channels doesn't really bother since there are ways around this. Models become more complicated with more than 8 functions, but that is all part of the fun.
Edited by dhc6twinotter
YES YES YES YES YES!!!!!!!
Radio waves are sooooooo much better than infrared waves! The funny thing is im learning about this stuff in my Chemistry class, who would have though school is helpful! :wink: .
tim
Some ideas:
- Micro PF Motor, enough torque to work as a stearing motor
- RF instead of IR
- Battery box with integrated IR/RF receiver
- Linear Actuator with integrated motor
- Solenoid powered Linear Actuator
- Servo Motor
- Servo linear Actuator
@grohl
your idea for the proportional remote controller, there already is one!
http://brickset.com/detail/?Set=8879-1
I am sure you did not try to control a car or other vehicle with it. It is USELESS. It has a long delay. When you turn fast it does not go as many steps as it should and vice versa. It is good for trains and other functions but not for propulsion and steering.
True, i just got my hands on a RC-buggy Radio control remote & receiver unit and i love it! It's much more responsive, and has longer range. They're great, but they're much more-expensive than PF remotes & receivers.
The reason I personally like PF is because it it relatively cheap. Although the lag does bother me sometimes, i'd stick with Infra Red due to it's comparably lower price.
I agree with grohl, that the existing IR PF remote control with the speed-control remote is not suitable for cars as it is now. I do not have an idea how it can be improved.
Keep the topic hot!
Greets,
legohead
Edited by le60head
And very good for propulsion and steering on heavy and slow vehicles.
