  • Replies 161
The first part of the factory is finished
this part is now stopped.
That because I start the high voltage masts
on a new baseplate 48x48
more on:
pictures old factory on brickshelf built from 0 to 100%
pictures brickshelf
:blush::sadnew:
Edited by patje
  • 4 months later...
on the end 2011 beginning 2012, I have decided to demolish the layout
it is a old layout 2003-2004 and ended on 2011
All the nine volt becomes dismantled…
All nine volt must be gone and all the rest (buildings and landscape to…
This is a sad job. But no need…. ,
we work hard on the attic for a rebuild
Everything are modernised, there comes automatic signals…
everything what is on the track will be dedected and will become on the pc
the track is divided in sectors (parts)
every part becomes provide with electricity and connected on the pc.
al the trains and traincars will be dedected
see more of the rebuild:
with exclusive pictures
what new pictures:
*huh*
gladly responses
Edited by patje
new on the layout
at the end of the tracks new buffers have been introduced
the old trainbuffers are not beautiful, I wants more detail and put in authenticit.
the older trainbuffers are just bricks on each other,
for the stability
night picture:
more on
my brickshelf pictures
:blush:
Edited by patje
Wow Patrick, this is a massive plan that you're implementing, the idea looks fantastic! It's sad to see your old layout taken apart, but I'm sure the new one will be bigger and better.
It looks like there's a lot of custom stuff you're using for the signalling, can you give us any details on the electronics, interface to the computer, and software in use?
I love the picture of the train yard at night, but then you've always been great with LEDs and electronics. Good luck with the new project!
I will give certainly explanation
when everything work perfectly
then I take pictures of the plates and other stuf
At the present we have a problem with signals and pc. + sofware.
the test program works perfectly.
from the pc we can change the signals …
dedection works perfectly.
But the programme which does the communication, of the signals and the dedection of the tracks,
if a train stand still ore passed, and addapted the signals,
this program dont work.
the programme is written by a friend.
Sunday we work further for the communication
Meanwhile I have find errors that i gave removed in the dedection of the tracks on the layout… that is now solved…
I promise you to give explanation if everything work perfectly.
see more on:
:wink:
thanks for the interest
soon I give a new update
I work on it to finish the signals
:thumbup:
Edited by patje
Wow, that's very impressive patje. :thumbup: Looking forward to more details.
I've got to ask, in your post here http://legotreinforum.forum2go.nl/post13154.html#13154 how did you get and/or make the metal wheels?
I have seen the weels once on the Internet
on my forum I written that on a topic
and we have bought the wheels together.
A friend of my dit that... :blush:
update:
belgium signals
on the layout:
without lego:
with lego:
on brickshelf
:wink:
Edited by patje
I've tried looking through your amazing forum (a lot) but still can't find the topic.
indeed by crach several topics are probably gone
also these.
I'm sorry..
I have replaced it :cry_sad:
metal weels
you must buy them by 100
the time that we bought them
(that for the information)
:blush:
Edited by patje
small update
in real, (Belgium)
we have the dedection below the train.
a steel brush hangs below the train
and touched the pieces between the rails
the train becomes dedected and further the signals
changed. see picture:
for this small update on the layout
i needed 450 bricks
more pictures on
:blush:
Edited by patje
changed.
Fantastic stuff :blush:
Is that PF track or your self-made 9v track, as the picture is quite dark?
Just as if it's 9v then the train automatically stops every time? Is there an override for that?
these are ordinary 9 volt tracks
that become divided in pieces of approximately 1m30
this is a sector. every sector still have a piece of 4 pieces straight rails…
this part will stop the train … by means of a relay (more later)
(a second small sector in the large sector)
with 4 little papers you make a sector
2 along both sides,
his part is no more conected to the other rails
and you have a sector.
papers:
complete sector (in the middle)with stop part of 4 straight rails:
:wink:
Edited by patje
That is a SWEET addition :sweet:
I think most people (myself included) would have been tempted to do that 2 studs wide. The fact that you've gone for one stud wide makes it look even nicer in my opinion.
A very nice detail to add that not many would notice. Well played :sweet:
yea...this one looks great! We see a lot in Hong Kong as well!
thanks for the replay
:thumbup:
unfortunately it is not in the middle.
such as it would have be
buth with a plate below,
it came too high and stuck to the train
:sad:
The first test programme changes all signals in 1 time of colour.
(test phase)
With update of the new programme
I can give a colour one 1 signal only or to several signals
Every signal must get a address, the pc. recognises the signal…
and can change that…
every signal gets a serial number in the next step….
more:
Edited by patje
The signals have now all an address also the cabins…
every signal can be checked from the pc.
works perfectly
:sweet:
The switches have now also a number, and are also numbered in the pc., as such that the programme can indicate the correct number and switch
more explanation how the switches will work finds you here
explanation
:blush:
Edited by patje
new update with new plan
the large signals stands there already
the numbers 1 , 2 and 3 are smaller signals
more explanation concerning the different small signals:
small signals
:wink:
Edited by patje
Nice to see your updates Patrick, I'm currently working on Dutch style signals with PF possibility. Your signals look nice! And of course your layout too, but that is no news in your case ;)
Gr. Johan
Gr. Johan
Thanks Johan for the replay.
I hope to update pictures today
of the working dedection, when trains running
on tracks..
:blush:
Edited by patje
at last the trains drive back
:sick:
the dedectie run now perfectly
with dedectie plates under the layout and the leds for the controlle on layout
1led is a piece track (sector)
when the led light up, the train driving on that part of the track
when the train has passed the led extinction;
the train is already on another sector
that's why the leds jumping
examine the result
here a film concerning the dedectie on layout
(takes little time for uploud)
film
more explanation:
explonation
gladly your opinion
:blush:
Edited by patje
new update
We stand a step further
after the dedection on the layout
see previous explanation.
we have now also the dedection on the screen (pc)
the red lines which move, are trains driving on these sectors
and the sectors are occupied… (red)
(3 trains drive on the example )
look film
more explonation
Edited by patje
