Gene Posted January 5, 2013 Posted January 5, 2013 The down gear option at the wheel ports are recommended 8/24. I'm wondering if 24T white clutch gear can be use? I read about slipping, power eating topic here: http://www.eurobrick...showtopic=43059 Are we showing any concern about 9398 motors especially it tends to stall during playtime? Motor stalling characteristic http://philohome.com...s/motorcomp.htm Quote
750ACE Posted January 5, 2013 Posted January 5, 2013 The down gear option at the wheel ports are recommended 8/24. I'm wondering if 24T white clutch gear can be use? I read about slipping, power eating topic here: http://www.eurobrick...showtopic=43059 Are we showing any concern about 9398 motors especially it tends to stall during playtime? Motor stalling characteristic http://philohome.com...s/motorcomp.htm My 9398 would stall cause of a bad battery box. It didn't put out all the power it should have. Ran some tests and tried my other battery boxes and now there is much better power. A bad shock came with the set as well, truck would lean like the Unimog! :) Quote
Gene Posted January 5, 2013 Posted January 5, 2013 My 9398 would stall cause of a bad battery box. It didn't put out all the power it should have. Ran some tests and tried my other battery boxes and now there is much better power. I've never came across something like that but all my stallings are when the wheels were jammed or caught by obstacles. Sometimes a "wheee" sound coming out of the motors. Extract from Sariel on Gears. I believed there're pro & cons: http://sariel.pl/2009/09/gears-tutorial/ Quote
kendon Posted January 12, 2013 Posted January 12, 2013 Thanks everyone, glad you like it. Instructions are comming, I just need some time. The 3d text at the start off the video is made with wax 2.0, a great free video editor. did you by any chance ever make these instructions? nevermind, found it: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=510433 thanks, gonna build that later :) Quote
DLuders Posted February 2, 2013 Posted February 2, 2013 Sunny Koo posted this YouTube video of his Lego Mindstorms IR Link Sensor testing with the Lego Technic 9398 4x4 Crawler. The device is made by HiTechnic (where there are software programs available for download), and is certified by The Lego Group (for all you "purists" out there): http://www.youtube.com/watch?v=P8Ipcy7otZM Quote
Gene Posted February 2, 2013 Posted February 2, 2013 Interesting, but it seem like the motion lack about 2sec behind control? Quote
DLuders Posted February 2, 2013 Posted February 2, 2013 Yes, that was one of the complaints noted in the official Lego Mindstorms Review webpage of the device. Quote
Paul B Technic Posted February 13, 2013 Posted February 13, 2013 A mod I made to this set last night http://mizibunktechnic.blogspot.com.au/2013/02/9398-b-model-mod-towing-arm.html Quote
Paul B Technic Posted February 24, 2013 Posted February 24, 2013 An update to the towing arm: Now includes a video of it pulling a 2.8KG load. http://mizibunktechnic.blogspot.com.au/2013/02/9398-b-model-with-tow-arm.html Quote
timslegos Posted February 24, 2013 Posted February 24, 2013 The one stud thick arm looks a little flimsy, maybe you could make a truss system? tim Quote
Paul B Technic Posted February 24, 2013 Posted February 24, 2013 The one stud thick arm looks a little flimsy, maybe you could make a truss system? tim It pulls a 2.8KG load so I think it is strong enough :) I am going to change it to make the arm fold in and out, when I do this I will be making it stronger. Quote
kevman Posted August 28, 2013 Posted August 28, 2013 I had a question, I just got this model and it leans to one side. Could this be an issue with the shock or the servo? Thanks. Quote
Kronos Posted August 28, 2013 Posted August 28, 2013 It's the shock(s). Someone else mentioned this before(this thread?). I also had this problem. Try switching the shocks around, that worked for me. Quote
750ACE Posted August 28, 2013 Posted August 28, 2013 It's the shock(s). Someone else mentioned this before(this thread?). I also had this problem. Try switching the shocks around, that worked for me. It was me. Flip it upside down so you can find out which spring is weak. I also had a junk battery box putting out weak voltage. Brand new store bought set go figure. Quote
kevman Posted August 28, 2013 Posted August 28, 2013 thanks guys, I confirmed it was the shock. oddly enough when switching rear shocks side to side it sits perfectly straight now. Another question- for the xl motors, are there additional parts needed or can they be implemented with the stock pieces of the 9398 ? Quote
Rockbrick Posted September 1, 2013 Posted September 1, 2013 (edited) A small mod Imade to my 9398 which seemed nicer in my mind than in reality, but should leave room for lots of extra features: Edited September 1, 2013 by Rockbrick Quote
Junpei Posted September 2, 2013 Posted September 2, 2013 I love it, very original! I think it would look much better if you removed the color vomit panels, they ruin the beauty of the studded beams. By the way, welcome to Eurobricks! Quote
JohannesESTONIA Posted September 2, 2013 Posted September 2, 2013 Here's my video, it's mainly about the 41999 but you can also see a modified 9398 there. Quote
Rockbrick Posted September 2, 2013 Posted September 2, 2013 (edited) I love it, very original! I think it would look much better if you removed the color vomit panels, they ruin the beauty of the studded beams. By the way, welcome to Eurobricks! Thanks for the welcome.... I left the doors as it was just a trial fit - I would love to have the blue seats on there and the V4 engine in the back with the yellow fan Edited September 2, 2013 by Rockbrick Quote
Junpei Posted September 2, 2013 Posted September 2, 2013 Oh yes, blue seats would be nice, and the engine too. Why not a V10? Quote
CisFran Posted September 3, 2013 Posted September 3, 2013 I plan to convert my 9398 to a yellow boss, just needs some more parts, though my yellow panels are already complete Quote
DreamsKnight Posted January 28, 2014 Posted January 28, 2014 sorry for the necroposting, but i finished my mod on 9398. this is my first ever original work with technic, i am very proud of it and i'd like to share. we know the problems with this (not) crawler, so i work hard to increase the perfomance. i made two new engine blocks with these features: -xl motors, but with the same overall height of the original one. you can see in photos a prototype at 90% near the original one. -no differentials, same gear reduction of the original one, incresead gear reduction before wheels. -4 studs larger, so a larger base for the crawler. this helps a lot with lateral tilt. you can see photos over a guitar case. the original can't stay in that inclination, and roll on the side. -suspensions layout reworked. front/lateral inclination helps a lot to decrease the center of gravity, without change the height of the crawler. with the new scheme, the height is equal to the original. it is possible to connect suspensions in the original point of the chassis, and the crawler will be 1 studs higher. -same steering angle of the orginal, but with reinforced axles, so now they don't bend under hight torque. -increased front angle attack with no part out of wheels, and for the same porpuse i removed the front bumper. -ansmann tires -the two new blocks are very strong, as the originals. this is my google+ album: https://plus.google....602721894295745 this is a video. it was night and very dark, but you can have an idea of performance i attach also the lxf file. :) motore 9398.lxf ps: apologize for english. Quote
astakos Posted February 14, 2014 Posted February 14, 2014 hi, i know i'am late, but i hope you'll like my modification of this great set: Quote
ed-orange Posted March 22, 2014 Posted March 22, 2014 Hi, I have modified my 9398 a bit as well and would like to show you the result :-) Quote
