roland Posted November 4, 2017 Posted November 4, 2017 13 hours ago, mocbuild101 said: Yeah, that's really annoying... You could try playing around with ldrawPlasticTrans_f and ldrawPlasticTrans_t e.g. #local ldrawPlasticTrans_f=0.3; #local ldrawPlasticTrans_t=0.7; Seems to work better with black trans, but it reduces (imho) the quality of normal transparent stuff. But you don't have that in your scene anyway. Quote
mocbuild101 Posted November 5, 2017 Posted November 5, 2017 6 hours ago, roland said: You could try playing around with ldrawPlasticTrans_f and ldrawPlasticTrans_t Seems to work better with black trans, but it reduces (imho) the quality of normal transparent stuff. But you don't have that in your scene anyway. Thanks, I will make sure to try that next time! Quote
dagupa Posted November 12, 2017 Posted November 12, 2017 I found a solution to the problem of rendering a subset of frames inside out of a larger animation. I post it here in case anyone have the same problem. As @mocbuild101 pointed out the problem with my animation accelerating for no reason around 00:04 was due to a glitch. https://bricksafe.com/files/dagupa/others/ebvarias/BrickbankFirstAttemp.mp4 After many attempts and a quick search, I found out the exact problem. It was the recovery code. I did the animation with a simple code: Initial_Frame=1 Final_Frame=360 PovRay exports each frame with a file name and a number. Example brickbank00001.png;brickbank00002.png;brickbank00003.png(...) If the program crashes, there is a script that reads the last file written and takes the number from that name. It stores the number as a variable "LastFrame" and starts the process from that frame Initial_Frame=LastFrame Final_Frame=360 Well, it turns out that this is NOT the way to restart the rendering process. What PovRay does is to divide 1 by 360 and then you have 360 different values in the internal variable called "clock" which is the variable that I used to move the camera position 1 degree at a time. So: Initial_Frame=1 Final_Frame=360 is not the same as: Initial_Frame= LastFrame Final_Frame=360 In the first code you have a "clock" variable that increases 1/360 at a time. In the "recovery code" the "clock" variable increases LastFrame/360. In my case the program crashed around frame 172, so in the new process each frame changed 172/360 at a time. That's the reason why the first subset of renders looks different to the second subset: The camera rotates at different speeds. It turns out that the solution is very easy. A simple google search point to the solution: If you wish to render a subset of frames such as 172 through 360 out of a 1 to 360 animation, you should not change Initial_Frame or Final_Frame. Instead you should use the subset commands. Subset_Start_Frame=172 Subset_End_Frame=360 It took me almost a week to figure this out, not because of the complexity of the problem, but because each animation took 110 hours to render.@mocbuild101 I managed to remove 300 pieces and saved a couple of hours. It's not easy to identify internal bricks that are not seen in a 360-degree animation when the model has so many windows. @rolandI tried your LDCad. It's a very useful tool. Too bad there's no Mac version. Thanks for all the advices. I hope someone finds this useful. Quote
mocbuild101 Posted November 13, 2017 Posted November 13, 2017 It's great to hear the problem (and the solution) was found, and I'm sure someone will find it useful - I probably will end up using it too one day... Quote
cosmocaos Posted December 8, 2017 Posted December 8, 2017 (edited) Hello I have created a topic: Stud.io, exporting POV-ray files, some is covered here. The new topic focus on editing .pov files exported from Stud.io and then rendered from a mac OS terminal. Right now I'm learning to edit .pov files. I'm trying to adapt the lines of code from CRPOwen' guide to the .pov file exported from Stud.io. But I had some trouble, because the .pov file, already has a macro for lights: WriteLight(0, 0, 1, 0, 200, 5) . If I remove that macro (see line below), somehow the rendering fails. I'm trying to understand more of the POV-ray language to find whats happening. Any help will be greatly appreciated. Solution Update: .pov files exported from Stud.io give me some trouble, so instead, from stud.io I export a .ldr file, which then I open in LDView, and from there I exported the .pov file. This also allow me to select the perspective of the model, and automatically translated to the .pov file (Which I could not do it in Stud.io). At first time the .pov file exported from LDView has mismatch colors, that was fixed updating the file /Applications/LDView.app/Contents/Resources/LGEO.xml. NOTE: I will eliminate the topic I created, or maybe change to focusing on mac OS related issues of POV-Ray Rendering. Edited December 9, 2017 by cosmocaos Update Quote
roland Posted December 8, 2017 Posted December 8, 2017 11 minutes ago, cosmocaos said: Hello I have created a topic: Stud.io, exporting POV-ray files, some is covered here. The new topic focus on editing .pov files exported from Stud.io and then rendered from a mac mac terminal. As far I know stud.io pov exports are LDView exports wich most people in this topic use / talk about, so I don't think you need to make a distinction. Quote
cosmocaos Posted December 8, 2017 Posted December 8, 2017 1 minute ago, roland said: As far I know stud.io pov exports are LDView exports wich most people in this topic use / talk about, so I don't think you need to make a distinction. I did not know that, thanks for the clarification. I will read more in this post to see if solves the issue I'm describing. Quote
antomio Posted January 6, 2018 Posted January 6, 2018 (edited) hello, Someone can help me please, i want to make the background totaly transparent not white and i can't figure out to do this. i tried LDXFloor = 0 and +UA on the white box (command line option) near to the selection resolution box but the background on the final render still white and not transparent. Thanks for your help, F. Edited January 6, 2018 by antomio Quote
mocbuild101 Posted January 7, 2018 Posted January 7, 2018 3 hours ago, antomio said: i want to make the background totaly transparent not white and i can't figure out to do this. Just edit-out the white in a photo editing program. (like GIMP) Quote
legolijntje Posted January 7, 2018 Posted January 7, 2018 9 hours ago, antomio said: hello, Someone can help me please, i want to make the background totaly transparent not white and i can't figure out to do this. i tried LDXFloor = 0 and +UA on the white box (command line option) near to the selection resolution box but the background on the final render still white and not transparent. Thanks for your help, F. Have you also tried +FN +UA ? Quote
dagupa Posted January 9, 2018 Posted January 9, 2018 On 1/6/2018 at 6:19 PM, antomio said: hello, Someone can help me please, i want to make the background totaly transparent not white and i can't figure out to do this. i tried LDXFloor = 0 and +UA on the white box (command line option) near to the selection resolution box but the background on the final render still white and not transparent. Thanks for your help, F. Hello. Leave the LDXFloor=0 and the +UA, plus change the background colour to: background { color rgbft 1 } This usually works for me. Quote
antomio Posted January 9, 2018 Posted January 9, 2018 (edited) Thank guys, it work now ! i've add this line : "background { color rgbft <LDXBgR,LDXBgG,LDXBgB,0,1> }" +UA in the command box Edited January 9, 2018 by antomio Quote
Dilvish Posted June 14, 2019 Posted June 14, 2019 Two questions: 1. Could you mirror this tutorial to the LDraw wiki? 2. How do you export to POV-Ray from within LDCad? Quote
djm Posted June 14, 2019 Posted June 14, 2019 7 hours ago, Dilvish said: Two questions: 1. Could you mirror this tutorial to the LDraw wiki? 2. How do you export to POV-Ray from within LDCad? For 2, the menu path is "View/Editing Views/Export/POV-ray view export". Quote
Dilvish Posted July 1, 2019 Posted July 1, 2019 (edited) The LGEO files "lg_10197.inc", "lg_10288.inc" and "lg_85940.inc" reference an object named "lg_tech_tube", but this object is not defined anywhere in the LGEO library. It is causing my scene to stop rendering. What can I do to fix this? Thanks. Edited July 1, 2019 by Dilvish Quote
