The mans a genius. I like this I'm glad I asked now :)
Thanks
Firky
Sadly I don't have enough parts today to try the offsetting.
Lol what? :laugh:
Guys, do it like this:
*snip*
Also its a higher gear ratio this way.
Now that's genius, I've never worked with gears that aren't aligned along a 90° axis. Nice :thumbup:
Lol what? :laugh:
Yh erm. My lego collection went from thousands of pieces to about 100 pieces.
Its on the up again now tho.
Hi zblj
This is looking good for a robot arm wrist joint, the 8 tooth pinion even fitted first time in LDD. I hope you do not mind I have added a possible up, down to the wrist. No linkage yet to opperate.
Wrist.lxf
All designes are welcome. I find that often my ideas need a bit of a push or I make things far to complicated and miss the obvious. I've never worked with 28 tooth before I didn't even see that lego turntable in LDD before I'm going to work on a smaller wrist design than I've used before trying to keep the weight down.
If you look on youtube for "firky2010" you will see my designs for a robotic arm.
Here is a quick mock up of my current goal for the wrist. I used a similar set up with the larger turntables. But this time I'm trying to keep weight down and would like to put the motors in the forearm. So I need to route all drives from the wrist to the forearm
The next challenge will be getting the drive for the grab out of one side and the drive for the rotation out of the other.
mini Wrist idea.lxf
Here is a video of the same design but fitted with a motor to reduce the amount of drives that need to be routed to the forearm. its by no means the final design but its a rough idea of what I'm trying to get to.
Thanks
Firky
@ firky: Do you have all of the necessary parts to build it in real life?
@ DLuders thanks for embedding the vid. I couldnt get it to work. Sadly not at the moment I will have order most of the parts in the video. I was also thinking about getting a L motor instead of the M motor. as it has far more fixing holes. also the 24 tooth black gear will be changed for a clutch gear.
I've also attached the design to this post.
mini Wrist idea 2.lxf
I use yellow farm bricks. It may not be the cheapest. But every thing is well packed and the delivery is fast.
I've done a similar design of spherical wrist, but using the big turntable as I don't own those small turntables (but I should definitely get some they look very useful!)
all the motor are attached outside the structure.
soon I will post some preliminary video of the whole 6 axis arm NXT controlled
Here is my previous design using the large turntables
So guys my Lego pieces arrived today.
So I build up what I designed in LDD
There isn't enough room to use the clutch gear as I had planned so I think I'm going to use direct drive from the motor ( I can only hope this does not destroy the grab ). Only draw back to this is that the actual motor blocked the centre holes of both mini turn tables making it much harder to route the rotational drive to the forearm.
Thanks
Firky
Do you think you could whip up a .lxf file for these claw designs? They look extremely promising!
EDIT: I was able to reverse-engineer the third claw from the photos posted. Here's my mockup in LDD:
I colored the parts that wouldn't connect easily in bright colors. When assembling it in real life, all you have to do is connect those colors! I've included the original model and a design that I modified to attach an M-motor easily.
Download the .lxf here: https://dl.dropbox.com/u/84375076/firkygrabber.lxf [All credit goes to Firky for the original re-make!]
Edited by Phoxtane
@Phoxtane Great job with LDD. I really need to learn how to use it. the mount for the M motor is good. But wouldn't suit the current needs when using a mini turn table.
Thanks
Firky
