The skip can be attached when the top arm it moved back,i have made it so the skip is locked then the top arm is forward.
ohh okay, nice feature.
tim
Hello,
Here is the video of my TREMO carrier
Hope you like it :blush:
Edited by dfs473
are you going to make instruction for this would love to build one
@dfs473: WOW, the vidoe and the MOC are both great! Can't wait to get instructions or LDD.
Thank you everybody^^
The LDD file is work in progress :wink:
Oh, thats good to read!!! Hmmm, there'll be a huge order at BL :laugh:
But I think I'll rebuild your marvelous MOC without RC.
Pat
@Alasdair: I rebuild your tipper in LDD. I made it a little wider. I think the Tremo is about 15 studs wide. If you can open lxf-files you can check if I rebuild it correctly.
And here's the LDD:
tremo_absetzkipper_v2.lxf
Great,i should of done it in ldd to i think.:blush:
I think you might need to move the two main rams a stud back.:thumbup:
Also you need to have a look at the hook part of the skip its self (black bit) it does not seem very strong,also you can remove the two axle friction pin (tan)
Edited by Alasdair Ryan
@Alasdair: which two main rams??? Yes, the hook isn't very strong. I'll do it better if I build it in real. :sweet: I hope, you are not angry, that I copied your design. :blush: Didn't ask before...
Can't wait for the LDD :wink:
looks very good
The Tremo is 15 studs wide (withoud 2 Studs for wheels)
OK, thank god, I'm still able to count :laugh:
How far is the LDD? Can't wait to place an order at BL :wink:
The Chassis is ready
cabin in work
I must make the spreader then it is ready-,-
