cavegod Posted March 8, 2012 Posted March 8, 2012 After seeing Anio's Sebulba's Pod Racer and already having built Anakin's it seemed only right to build this to go with it since Kids at the shows I exhibit at always asked me where it was So with the help of Anio i have recreated it with just a few tweaks and before you start pestering him about it i can confirm it is not easy to obtain the parts required at all!! Sebulba's Pod Racer Oh and before anybody says, I need to change a few dyed parts as I left them a little to long and hence why they are darker than they should be. I have only dyed the 4x9 wedge plates, 3x3 rounded corner plates and the 3x3 arched domes. the rest is all unmodified Lego elements. Quote
mortesv Posted March 8, 2012 Posted March 8, 2012 Looks really, really good I really like Anio's design. Can you highlight what tweaks/differences there are between the two model (other than missing/dyed parts)? Good job Quote
cavegod Posted March 8, 2012 Author Posted March 8, 2012 only minor tweaks but I changed the rear of the split x intakes and also the front of them to be more accurate I feel, I added the cable supports to the pod as well, other than that just a few greeble changes due to availability issues. Quote
Fuppylodders Posted March 8, 2012 Posted March 8, 2012 (edited) You dyed pieces? I didnt know people did this :o The podracer looks a really neat and tidy job of it too! How well does dying fare, compared to just spraying pieces? Does it come off easily, is it permanent, or just as permanent as you wish it to be. How well does the dye adhere? Edited March 8, 2012 by Fuppylodders Quote
cavegod Posted March 8, 2012 Author Posted March 8, 2012 The dye is absorbed by the plastic and will not rub off at all, you retain the Lego shine as well, the trick is to dye it just the right amount of time which i did on most of the parts, won't happen next time. Quote
Darth Yogi Posted March 8, 2012 Posted March 8, 2012 This looks great and huge. I think that the electricity connector should be a bit bulkier, but other than that this is truly amazing. Great job Quote
Aeroeza Posted March 10, 2012 Posted March 10, 2012 Look's great! I suspect I'd be speaking on behalf of more than a few of us if you could also add a photo of your UCS Pod Racers sitting side-by-side. That would be a marvelous sight to behold Cavegod! Never mind the little kids, us 'big' kids also want to see them... Quote
cavegod Posted March 10, 2012 Author Posted March 10, 2012 I will do as soon as I have finished the interior of the Sandcrawler. Quote
Brickmamba Posted March 10, 2012 Posted March 10, 2012 That is one humungous pod racer, magnificent effort! Quote
Lobot Posted March 10, 2012 Posted March 10, 2012 Excellent work cavegod, as usual! I'm surprised that you can dye bricks, but it clearly works well. Did you use white bricks or does it work with other colours as well? I will do as soon as I have finished the interior of the Sandcrawler. I've been really looking forward to see the inside, any chance of a sneak preview? Quote
markus1984 Posted March 10, 2012 Posted March 10, 2012 great work, I find the details at the drive-jets simply brilliant. Quote
