  • Replies 71
Nice, if you could squeeze some train weights into the blade the it'd lower the centre of gravity and move it rearwards nicely too....
I'm really interested to see how this affects the control in the next sea trial!
i dont think that train weights would be a good idea. because the blade and the finished afterdeck it is now at the back to heavy. so i need more flotation force at the back. by the way, the current weight is 2660 grams.
a vid of the newest testrun will follow later this day
Edited by efferman
What generates that weight? I mean the battery box and motors are big part of it but isn't the hull "empty" inside ?
well, even lego is built with plastics it has a weight. as an example the 5x11 panels. one of them has 9grams 9x43= 387 grams. then all the liftarms, pins, axles, connectors, plates and electric parts. iam surprised that it is not more heavy
edit:
conclusion:
moving straight sidewards is not possible with the stabilizer sword, but normal steering is much more easy
Edited by efferman
Wow, 2.6kg, that's a lot of grey panels! Maybe additional ballast will not be required! :laugh:
I thought the blade would inhibit sideways motion, would it not be possible to counteract this with differing inputs to the two sets of vanes? eitherway she sails nicely!
Also its great the way it now looks like a monohull tug when its in the water...
Edited by Sam42
Effe try to make the sword smaller but leave the plates under it.
i think you don't need a big sword a small one would stabelize it more then enough.
just use 4 of these at the back
only the 4 cornerparts and no straight panels?
yes only the four corner parts the way it is now is that your system has to push your sword with massive force. with a smaller sword it is less
on the other hand you tug is wide enough to stay up
I like the cabine starting to look like the real deal
this will surely work good, but i like the design of the sword and i dont want left it. maybe one panel less in the length is a good compromise
you could try it out
but it's going to be a though compition with this one in it
stabilizer sword
This is normally known as a 'skeg', apparently from the Norse for 'beard'.
Fantastic model! Have you tried sideways movement using only the after Voith-Schneider unit? It is about at what would normally be the pivot point and might be a little more successful than both together as the forward unit will tend to cause the yawing motion you have experienced.
thanks for your suggestions, have you to do with marine vessels?
iam powering both voith scheider units with a single PF-M Motor. so i could not drive them separately and the pitch is only to control the direction of boost. the pitch of the two units i can change separately, so i can maybe prevent the yawing movement with an other boost direction of the propellers.
Edited by efferman
Yeah, I'm a Merchant Navy deck officer, but I have never worked with Voith-Schneider propulsion so I'm not totally familiar with how best to handle it. Does the mechanism allow you to set one unit to neutral pitch and use the other for transverse thrust?
unfortunately i can only give a direction and not a zero pitch
timr, yes this should be possible but then there is no contrast between bridge and smoke stacks
True, i think the red works :sweet: .
tim
Y'know, when I first saw this model I had my doubts that it'd be anything more than a mechanical example, but it actually looks pretty good now. :wub:
