  • Replies 1.1k
Hoke uses his pick on the wall and is able to successfully ruin a fairly strong patch of a wall... As he pushes the debris away, and bat flies into the room. It appears that the room behind the wall is a smallish cave with an opening to outside and has a small waterfall. The bat hovers over and around the party, and then lands on Erdathcath's shoulder.
"Where am I? Who are you? What are you doing here? Wasn't there a wall or something there? What did you do?" The curious bat asks Erdathcath. The rest of the party just looks through the wall and around the debris but can't hear the bat.
"Hmm, well now we've got a conundrum. Do we finish looking around the dungeon or do we investigate the cave. Maybe that bat could tell you what's in the cave Erdy?"
Sylph's own bat stirs in his robes. "You don't see much action, do you girl?" He mutters to his bat, who curls up and returns to sleep. "Soon I'll be able to talk to you again... My power is growing."
Who am I? I am Erdathcath, my companions and I have been traveling in this hole for quite a while now looking for some potions, and other things that some bossy person wants, in order to collect some items we might need to make a expensive looking sword.
With that out of the way, who are you?
"Me? I'm Puddles. Puddles Junior actually. I don't know much about this place, I just live in this cave, and then I heard some knocking and woke up. And then found you humans. I might be able to help you if you give me something yummy." Puddles tells Erdathcath as he flies around the room and lands on a brick from the debris. Puddles looks around the room and flies over to the light close to the south door. "I smell something weird. Follow me!" The bat flies south, what will the party do?
Tomas cocks an eyebrow at the bat. "Puddles, huh? Interesting name..." :look: "... Ahem..." Tomas collects himself when he notices that he's staring.
We'll follow Puddles.
Ok guys, in case you didn't understand Puddles (that is his name, or actually, Puddles Jr.) he lives here, and happened to awake when we knocked on the wall, therefore, I believe there most likely won't be anything on the other side, except bats, so we should probably follow him.
The party follows puddles south, then west, and then into the unexplored room north of there.
The party enters the room and finds a large array of potions, the party assumes this was probably an experimenting room where potions were tested.
If the party would like to try any of the potions, name which one(s) or the party can leave and try to find other items needed, perhaps the book 'Aguste of the Magical Beings' Each potion has an equivalent to 1 dose per brick height (Excluding top). Yet again, the party may want to find the book for the items Sam needs, perhaps some of these potions ones they will need.
Durkon will drink the rest of the gender-changing potion, hoping he will transform.
"Be glad I brought it with me." Says Sylph who hands it to him. "A please and thank you never killed anyone though. At least to my knowledge...."
The party searches for the book, but it doesn't appear to be in this room. Durkon drinks the rest of the 2nd potion. It seems to grant him more confidence in his magic abilities, but just seems to prolong the gender change. Perhaps the party should check the unexplored rooms?
QM Note: Dang, LDD won't load for some reason. Not exactly sure what's wrong. Hopefully re-downloading it will help. Hope this doesn't pause the quest. If you guys want, now/if it still won't work I could continue this part of the quest without pictures and then pause the quest while I'm on vacation and probably have it fixed.
That doesn't sound too bad to me, but I'm not one to complain about most things.
