mifkar33 Posted February 12, 2021 Posted February 12, 2021 Hi All, I'm new to the Lego world and this forum, so if I'm messing anything up here, please give me a pass! I have a mix of Legos and am hoping you all can help me identify some of the parts so I can try and find instructions and build a few sets. 2nd Image... Sorry for the poor quality pics. Quote
koalayummies Posted February 12, 2021 Posted February 12, 2021 46 minutes ago, mifkar33 said: 2nd Image... You need to upload your images to an image host as EB doesn't host images. This will also allow for the linking of larger images; Flickr and Bricksafe are two of the preferred around here. Unfortunately a lot of those pieces are in many sets, too many to really narrow down specifically which they came from but here goes: The 3x2 slope blue with red triangles is in 15 different sets The 3x4 slope blue with red triangles is in 13 different sets 3x4 slope green with with yellow triangles is in 7 different sets The white computer screen slope brick is in 71 different sets Tile 1x2 with dynamite pattern is in 40 different sets The grey wing piece bottom middle is from these 2 UFO (space subtheme) sets this is one of your rarer pieces I'll locate more later if someone else doesn't get around to it. Quote
Aurore Posted February 12, 2021 Posted February 12, 2021 @mifkar33 A few more : The white brick with three stars (4 sets) The grey container door (5 sets and an extra brick pack, all from the M-Tron theme) The blue slope with classic space logo (only 1 set and an extra brick pack, unsurprisingly from the Classic Space theme) The grey plate, modified, cross with dome (hard to tell from the photo if it's light gray (4 sets) or light bluish grey (more recent, 15 sets)) The large grey wedge, triple curve (much more recent than the other parts, 15 sets) Quote
Peppermint_M Posted February 12, 2021 Posted February 12, 2021 11 hours ago, CreeperBrix said: the part HAS to be there, I'll update my version of it and see if it's there. It was in the first series of Harry Potter CMFs, so I would expect it to be. I found it on the Bricklink site by searching "saucer" and "Tea" should also work. As the software uses the bricklink database, I should hope their search algorithm does the same thing in each. Quote
Sansy Posted February 12, 2021 Posted February 12, 2021 2 hours ago, Peppermint_M said: It was in the first series of Harry Potter CMFs, so I would expect it to be. I found it on the Bricklink site by searching "saucer" and "Tea" should also work. As the software uses the bricklink database, I should hope their search algorithm does the same thing in each. For some reason, it's not on Stud.io, but I downloaded the dat. file for it from LDraw and imported it into Stud.io as a custom part. Quote
mifkar33 Posted February 12, 2021 Posted February 12, 2021 Thanks so much, all! I appreciate the time an effort it took to respond! Quote
Alexandrina Posted February 16, 2021 Posted February 16, 2021 Not sure if this is the right thread, since I'm fairly sure I have identified what the part is, but I recently acquired a job lot with some parts whose authenticity I'm not sure of (images spoilered since I'm having a hard time making them not prohibitively large): Spoiler Now, I'm fairly sure they're Part 71076, and colour-wise they are a perfect match for known legitimate bricks in the old Light Grey. Bricklink recognises the existence of this part in the old Light Grey. Fabulous. What gets me suspicious is the fact that they're not included in any set inventory in Light Grey, and the few they have are going for several quid. That to me implies that these aren't common bricks, so finding three in a job lot is unlikely. Unfortunately, I've not got any others to compare against, and while there's no visible Lego logo, there often isn't on parts with a blocked open stud like this seems to have. So failing that, is there any way to be sure whether or not these are legitimate Lego? It's worth mentioning that the job lot appears to be mostly legitimate Lego, though a significant minority of the parts were other brands. Apologies if this is the wrong thread! Quote
MAB Posted February 16, 2021 Posted February 16, 2021 It is very hard to prove they are LEGO, without scraping some of the surface and comparing it with a part of known colour. They could be unchromed or dechromed parts. Some old chromed parts are transparent / clear underneath, some are more of a dirty white, while I've also seen grey and tan underneath some chromed parts. Quote
ukbajadave Posted February 19, 2021 Posted February 19, 2021 Evening all, I'm sorting through a big box of old Lego and a couple of bits don't seem familiar. Any help gratefully received Some kind of creator style shark, perhaps a poly bag? Another creature, this time a crab or spider? Last but not least this legless guy and his enormous weapon. Bigger pics should be available on bricksafe LINK HERE Cheers Quote
Alexandrina Posted February 19, 2021 Posted February 19, 2021 9 minutes ago, ukbajadave said: Last but not least this legless guy and his enormous weapon Sounds dirty The head was one of the standard City selection for a decade, so it won't be easy to pin down where it came from. Even then, do you know for sure that the head and torso are from the same source? Quote
Aurore Posted February 19, 2021 Posted February 19, 2021 (edited) The shark looks like the one from this polybag, but modified : The crab comes from an Atlantis set : The machete appeared in recent City Jungle sets : https://brickset.com/parts/6177418/sword-no-12 Edited February 19, 2021 by Aurore Quote
ukbajadave Posted February 19, 2021 Posted February 19, 2021 2 minutes ago, Alexandrina said: ...do you know for sure that the head and torso are from the same source? Nope, its just a giant mixed box of stuff! @Aurore Nailed it!! I wonder if the shark was two poly bags put together. Quote
Alexandrina Posted February 19, 2021 Posted February 19, 2021 Your best bet is identifying uncommon sets then seeing what common parts are there. I can see most of the 7668 Rebel Scout Speeder at a glance though Quote
ukbajadave Posted February 19, 2021 Posted February 19, 2021 4 minutes ago, Alexandrina said: I can see most of the 7668 Rebel Scout Speeder at a glance though Yep, its mostly Lego City from the last 15 years but I'm certain there's some 70s or 80s stuff in there too (and a whole lot of sweet wrappers, beads and megablocks!) Quote
Alexandrina Posted February 21, 2021 Posted February 21, 2021 I'm in the process of sorting through a big joblot I acquired last month, and while I'm getting good at narrowing down mysterious parts, some are still eluding me. For instance, this torso: Spoiler It's a genuine Legoland Torso with the Lego logo on the stud, but I don't know of any way to identify whether a sticker is genuine Lego or not. This particular sticker does not belong on the black Legoland Torso according to Bricklink's inventory, nor is it on the sticker sheets for any set the torso appears in, and a Bricklink search for "torso sticker" yields some similar results but none quite the same. I'm curious to know whether the sticker is a genuine one from some set - obviously I'd like to avoid going through the entire Bricklink database and checking the sticker sheets for every set which ever included minifigure torsos if possible so hopefully somebody here will recognise it. Quote
Man with beard Posted February 21, 2021 Posted February 21, 2021 (edited) @Alexandrina, looks to be from a Lego Idea book. Way before my time, but I recognized it from the video by Jangbricks on that book. Edited February 21, 2021 by Man with beard Quote
Alexandrina Posted February 21, 2021 Posted February 21, 2021 19 minutes ago, Man with beard said: @Alexandrina, looks to be from a Lego Idea book. Way before my time, but I recognized it from the video by Jangbricks on that book. I think that's the one. Cheers! Quote
1974 Posted February 21, 2021 Posted February 21, 2021 On 2/16/2021 at 4:46 PM, Alexandrina said: Not sure if this is the right thread, since I'm fairly sure I have identified what the part is, but I recently acquired a job lot with some parts whose authenticity I'm not sure of (images spoilered since I'm having a hard time making them not prohibitively large): Hide contents Now, I'm fairly sure they're Part 71076, and colour-wise they are a perfect match for known legitimate bricks in the old Light Grey. Bricklink recognises the existence of this part in the old Light Grey. Fabulous. What gets me suspicious is the fact that they're not included in any set inventory in Light Grey, and the few they have are going for several quid. That to me implies that these aren't common bricks, so finding three in a job lot is unlikely. Unfortunately, I've not got any others to compare against, and while there's no visible Lego logo, there often isn't on parts with a blocked open stud like this seems to have. So failing that, is there any way to be sure whether or not these are legitimate Lego? It's worth mentioning that the job lot appears to be mostly legitimate Lego, though a significant minority of the parts were other brands. Apologies if this is the wrong thread! I used to have this part in quite a number of colours, besides chrome. Loads of non-production parts/parts in non-production colours were made for the modelshops in the UK Cheers, Ole Quote
Alexandrina Posted February 21, 2021 Posted February 21, 2021 3 minutes ago, 1974 said: Loads of non-production parts/parts in non-production colours were made for the modelshops in the UK That might well explain it. The seller I bought from is UK based, and I can't vouch for the path the parts took before they came into my possession so it's entirely possible there was a model shop connection somewhere down the line. Quote
Kit Figsto Posted February 22, 2021 Posted February 22, 2021 On 2/19/2021 at 2:26 PM, ukbajadave said: Last but not least this legless guy and his enormous weapon. The weapon seems to be this machete pieces, available in 23 sets: https://www.bricklink.com/catalogItemIn.asp?P=29109&in=S That torso appeared in 5 sets, two of which (30225 and 60011) had the sunglasses head, so it's likely from one of those, though the head is so common that it could be a mixture of figures very easily too. https://www.bricklink.com/catalogItemIn.asp?P=973pb1436c01&in=S Either way, the weapon definitely was from a different source than the rest of the figure. Hope that helps! Quote
MrZ Posted February 23, 2021 Posted February 23, 2021 Any idea what set this truck is that appears on the front of the 1986 catalog? https://brickresales.com.au/products/lego-1986-catalogue-2474 Quote
timemail Posted February 23, 2021 Posted February 23, 2021 48 minutes ago, MrZ said: Any idea what set this truck is that appears on the front of the 1986 catalog? https://brickresales.com.au/products/lego-1986-catalogue-2474 That is from the basic building set 740.https://www.bricklink.com/v2/catalog/catalogitem.page?S=740-1&name=Basic Building Set&category=[Universal Building Set][Basic]#T=S&O={"iconly":0} Instructions are here if you are interested.https://worldbricks.com/en/instructions-number/0000/700-799.raw?task=download&fid=483 Quote
ukbajadave Posted February 24, 2021 Posted February 24, 2021 On 2/22/2021 at 1:24 AM, Kit Figsto said: ...That torso appeared in 5 sets, two of which (30225 and 60011) had the sunglasses head, so it's likely from one of those... Spot on! The surfboard from 60011 is also present. Cheers Quote
PhillyFrank Posted March 8, 2021 Posted March 8, 2021 Hello! Having a hard time figuring out what the piece at the top is. Appears to be some sort of 4x4 dish? Thank you! Quote
Alexandrina Posted March 8, 2021 Posted March 8, 2021 12 minutes ago, PhillyFrank said: Hello! Having a hard time figuring out what the piece at the top is. Appears to be some sort of 4x4 dish? Thank you! It appears to be this piece. Quote
