EXO-CHAMP Posted December 22, 2006 Author Posted December 22, 2006 Since I have the "unlock" information, I can make the 07 line, but they might be subject to changes later on. I like to tst my mechas before I post them. But I guess player feed-back would be just as good. I've be
vahkimetru Posted December 28, 2006 Posted December 28, 2006 Would you mind if I made some of the 07 mechs. I'll be away for a while and it would be a fun thing to play to pass time. *sweet*
legolad911 Posted December 29, 2006 Posted December 29, 2006 EXO-CHAMP, if I do a battle report were do I post it? Oh and does it matter if there are no pics? Thanks
EXO-CHAMP Posted December 29, 2006 Author Posted December 29, 2006 Just make a new thread in the Wargames forum. Pictures are not required. They just add to the experience.
legolad911 Posted December 30, 2006 Posted December 30, 2006 Just make a new thread in the Wargames forum. Pictures are not required. They just add to the experience. Ok thanks.
EXO-CHAMP Posted January 21, 2007 Author Posted January 21, 2007 The Templates for Blade Titan, Sky Guardian and Cyclone Defender are added. http://www.123hjemmeside.dk/EXO-DICE/5192050 Note: Energy Sphere is a blast weapon and will be added to the special weapons section in the rules. There will be add-on cards to these BMs. So far I've planned Turbo-boost for Sky Guardian (speed increases to 10, but it cannot attack while using it). Advanced Sensor package for Sky Gaurdian (effect not decided yet). Suggestions for more add-on cards?
vahkimetru Posted January 21, 2007 Posted January 21, 2007 Once we have the robots, I'll try to play.
EXO-CHAMP Posted January 21, 2007 Author Posted January 21, 2007 The robot templates will be up in a few days..
Kahgarak Posted January 21, 2007 Posted January 21, 2007 The robot templates will be up in a few days.. I have PMed you the picture and data for the Stalker Mine a while ago.Did you make the template?
EXO-CHAMP Posted January 21, 2007 Author Posted January 21, 2007 No. I totally forgot. I'm sorry. I'll make it this week. Promise.. :-$
Kahgarak Posted January 22, 2007 Posted January 22, 2007 No. I totally forgot.I'm sorry. I'll make it this week. Promise.. :-$ Tis' okay. *Goes to be in his own little world* ''All the leaves are brown, and the sky is grey...''
EXO-CHAMP Posted January 23, 2007 Author Posted January 23, 2007 07 Robot Templates added. Planned add-on cards: Iron Condor: Sensor package. Shadow Crawler: Stealth Coating, Prison Pod. Note: Errors on 07 Human BMs fixed... EDIT: Point costs for all 07 jan BMs added... EDIT2: @Kahgarak. I've been making your template but the rules are quite complex compaired to the other E-D rules. Could you re-write them so the are more simplistic? Maybe they should just be treated as regular AI models like the Robots? So far the stats are: Stalker Mine Attack 3 (only used for explosion) Defence 2 Damage 6 ES 0 Mine 30cm (Blast with center on Mine) (5/0) Movement 7 Small Target
Kahgarak Posted January 24, 2007 Posted January 24, 2007 Maybe they should just be treated as regular AI models like the Robots?So far the stats are: Stalker Mine Attack 3 (only used for explosion) Defence 2 Damage 6 ES 0 Mine 30cm (Blast with center on Mine) (5/0) Movement 7 Small Target Sure. Nice stats too.
EXO-CHAMP Posted January 24, 2007 Author Posted January 24, 2007 Here the Stalker Mine so far. I'm not sure it would be wise to spend high-tech spy gear on a mine. Maybe you could do another MOC for that?
Kahgarak Posted January 24, 2007 Posted January 24, 2007 Here the Stalker Mine so far.I'm not sure it would be wise to spend high-tech spy gear on a mine. Maybe you could do another MOC for that? Okay.Nice tempate by the way,i''m loving it! *wub*
EXO-CHAMP Posted January 26, 2007 Author Posted January 26, 2007 Glad you like it. More news on the add-on cards: I just saw the Shadow Crawler's stealth coating in action in the new flash comic. Very effective. I think it should be something like this: Stealth Coating (0/5) (zero attack/five heat) When engaged Stealth Coating hides the Shadow Crawler from all attacks. Effectively the Shadow Crawler cannot be targeted by ranged og CC attacks while the Stealth Coating is active. Prison Pod Humans cannot target the Shadow Crawler with Blast weapons and all ranged weapons must be within 50cm to target the Shadow Crawler (not to risk hitting the Pod).
Zarkan Posted January 26, 2007 Posted January 26, 2007 Man, if that's what you decide to do, Shadow Crawler will probably be the best defended unit in the game! *sweet*
EXO-CHAMP Posted January 27, 2007 Author Posted January 27, 2007 Yes maybe. But it can't use the Stealth Coating twice (due to heat) and it can't attack while using it (due to heat). Oops. Noticed that with heat 5 The Shadow Crawler could still fire its (3/1) laser, so Stealth Coating will be changed to (0/6). :-) And both add-on cards will cost points, so the Shadow Crawler will be quite expensive with all the gear..
EXO-CHAMP Posted February 13, 2007 Author Posted February 13, 2007 Attached Iron Drone Infantry added (for SV). Air Drop added (For Sentry II). Exo-Dice Army list added...
EXO-CHAMP Posted February 14, 2007 Author Posted February 14, 2007 Prison Pod added: http://www.123hjemmeside.dk/EXO-DICE/5192050?i=7841563 Stealth Coating added: http://www.123hjemmeside.dk/EXO-DICE/5192050?i=7841503 Turbo Boost: http://www.123hjemmeside.dk/EXO-DICE/5192050?i=7842983 Turbo Boost: http://www.123hjemmeside.dk/EXO-DICE/5192050?i=7842983 New rule added: Shooting on the run: An activated unit may fire or make a CC attack during the movement phase instead of the Attack phase. All attacks made this way suffer -1 success to the to-hit roll. You attack at any given time during the movement phase. This modifier is added to modifiers listed in the Attack section. EDIT: The above rule really favours flying unit too much, so they receive a -2 modifier when "shooting on the run". Ground units still only suffer a -1 modifier.
