Hi !
This is my first Lego Technic construction, I have tried to make a model of a hooklift truck. This hooklift system invented by Zetterbergs is a unique system for hooklifting. It can lift with a very low angle, and it can tilt it 90 degrees. Ive used parts from lego lots and some parts from my old lego from the 70's.
The truck itself is no special model of an existing truck. My goal was to build the hook system.
Its drivenby:
1 Motor for steering
1 Motor for propulsion back and forth no gears
1 Motor for driving pumps for the pneumatics
1 Motor for the pneumatic switch
1 motor for the hooklift system driving the special made linear actuator (the standards were not long enough)
1 motor for the Hooklift tilt system driving 2 linear actuators
1 batterypack
2 pair of led lamps
Basicly its a tilted forklift truck stand with a hook on.
So here is the Movie
And here is the original truck with system
In my version I couldnt hide the pneumatics hoses, basicly the should run beside the chains that are used to pull the stand/mast.
The truck is rather big and it was hard to keep everything small.
Take Care Regards Case
Edited by Caselogic08
@ Caselogic08: The hook lift mechanism is very clever. :thumbup: They don't have trucks like this in the USA!
Welcome to eurobricks your truck is very good.:sweet:
Thanks Guys ! This comes in handy when operatng containers in garage buildings.
Regards Case
Welcome to Eurobricks! You have definitly started your MOCing career off well! I look forward to more.
tim
tim
Thanks
Sounds like your steering mechanism clicks badly in the video
Yes it does, I used a slipper cluth gear first. But it didnt have enough power to turn the wheels. Il come up with a new solution later.
Regards C
