  • Replies 55
@ Gijserman: Did you consider making your Lego Rollercoaster with the Lego 8867 Flexible Train Tracks, twisted in 3 dimensions?
Hey! Haven't tried to work with flexible track yet.. Looks nice, but I think it will need a lot of support structure to keep it in the air. Also it might not be as smooth.. But haven't tried it yet!
Awesome.
The speed is incredible. I would have thought that the wagon would fall of at those speeds.
Incredible technique. Most have taken some time to put together.
Anyhow very well done.
Cant wait to se V2 of it. ( There will be a V2 right ? ... You really should make one ) :)
Awesome.
Actually, this is version 2 already :classic: , version 1 is here:
Take over the entire house for "Research and Development"! :tongue: It must have taken many weeks to refine the design.
We actually built this in one weekend! But we were well prepared when we started :classic:
We made some rollercoasters before, so we knew what to do :sweet:
So how did you use the track to make more of a bent motion and them no fall off or break apart? Or maybe it is just my blue track that comes off easily?
Thanks, Rail Co.
Thanks, Rail Co.
This falling apart is definitely because of the blue track! Grey track is way better for this.
Edited by Gijserman
Have you tried having a long train of cars, like 6 or 7 together?
We experimented with more cars, but without success so far.
In the curves they derail pretty easy, because the front car is being pushed rather than going on its own. Loopings have to be built really strong, cause the weight of the cars is much heigher.. Stuff like that.
I'm going to do some more experimenting with more cars though, just ordered some extra lego on bricklink just for that purpose :classic:
Excellent! Can't wait to see more :thumbup:
Looks awesome! How will you do curves?
tim
I think we will use the same same type of curves we used with the roller coaster in video at the start of this topic, but maybe a little more reinforced and a bit smoother..
It's not the curves I'm worried about, it's the chain lift and the loop. I'm not sure the lego chain will be able to pull up all this weight without breaking and I'm certainly not sure if the loop can handle all these forces...
Will find out soon enough though..
Gijs
maybe you can use a dual link setup to pull the cars up, or divide them in a few smaller loops. Adding a hook to the bottom of the second cart (or even all of them) will allow for transitioning between the smaller loops.
Zblj, are you referring to the threads used in 8043 ? Because I think those might be a bit too wide maybe ?
Or the older 2 stud wide ones?
