  • Replies 703
I sure i wont have to do something similar to the kind i ordered. I would probably mess it up.
You won't have to alter your Crazy Crawler tires. Just a little of fanagling to get the beads fitted perfectly. They even fit the new BOSS wheels I tried it yesterday. Maybe I'll post a pic later.
Please do. It'll be a few weeks before mine arrives but i'll keep the pic for reference. BTW what beads. I thought those was on the original rc-style wheels, not the tires. But i don't really know anything about that.
Tire bead is the edge of the tire that sits on the wheel. It's the rubber sleeve on madjelly's pic (previous post you commented about) that he was trimming for better fit around the wheel/rim's outside grooves.
Ok. Here is wikipedia on the subject on beadlock. https://en.wikipedia.org/wiki/Beadlock Beadlock wheels are recommended for the third party tires i've seen but before this i didn't know what the heck beadlocks are or why i should care. Well worth reading. In short beadlocks as the name implies are something used to clamp the beads on a tire to the wheel so it doesn't come of. Not needed so much on road as off.
Well is looks like the 3-5 week shipping time need to be changed a bit because the tires arrived today, just one week after i ordered them. :classic: Still it will be some time before i have something to mount them on. I guess i could put them on my 9398 but it will still be a few hours before i'm done building it. :wub: I sure didn't think it would be this fast but i don't mind at all. :sweet:
Here's a crappy iphone pic of the crazy Crawler tires on the 41999 wheel. I like the way they look on my modded 9398.image.jpg
They look great. I just put a set of Losi Rock Claws on all black rims on my 41999. Personally, i love it. I can't wait to stick 'em on my 9398, when i get it and build it tomorrow.
Here's a picture with them on, and there's two more in spoiler bar.
I like the way those tyres deform under load, they're foam filed as well aren't they?
Is there a link to where you can get them from in this thread somewhere? I googled for them but they seem to come in a range of sizes and I'm not sure which ones I need.
Wow your boss crawler looks extra amazing from that angle! xD
Thank you! It does look fantastic.
Here you go, Tubby. They are currently $5.87 for a set of two from this seller via Amazon. They shipped very fast.
They are foam filled, yes. The rubber is so soft, that this deformation happens anyway, which i think looks awesome. They are insanely grippy and make a perfect fit for the 44772 rim.
http://www.amazon.co...0?ie=UTF8&psc=1
http://store.rc4wd.c...ires_p_671.html if i'm not mistaken these are the tiers
Those are cool, but they aren't the tires shown on my pictures above.
Edited by Trawler Man
While fitting the crazy krawler tires to the rims i decided to check the weight. Here is a table showing the tires and rims measured.
crazy krawler: 69 gr 84 with rims
44772: 15 gr
power puller: 182 gr
new: 16 gr
As you can see the power pullers are more than twice as heavy as the third party tires. I also measured the new rims and they weigh 16 gr compared to the old ones 15. BTW i fitted one of the CK on a newer rim at it looks to be working. There was another thread regarding the new rims not working with third party tires and i don't think that all third party tires are affected by the change. But i haven't and wont at the moment test drive them. Maybe something changes then.
Hello!
Desided to register to ask this question.
I found a cheap tires that might suite LEGO Crawler.
Could you tell me if they suite original LEGO Crawler rims?
Here they are:
http://www.ebay.com/...d=310736628419
I'm a not familiar with LEGO yet.
Thanks
Tires Materials:Rubber
Wheel Rim Materials:Plastics
Outer Diameter: 95 mm
Inner Diameter:45mm
Hexagonal joints: 12 mm
Tyres Wide:36mm
The tire is not glued on rim. It's mounted on rim with foam inserted.
Edited by Melaeg
I don't know if it will fit, however they do look a bit thin. Well I hope it works, and also welcome to Eurobricks!
So, I should try. Well, 20$ is not a large summ to loose if they will not fit. Ok, gonna order them shortly.
Thanks.
Hello!
Here they are:
Thanks
Inner Diameter:45mm
Tyres Wide:36mm
Dear mate,
These tires fits good as 108 mm with the same thread pattern. I have these tires with 108 mm, 96 mm and 90 mm. All are OK
Here is the MOC with 96 mm tires
http://www.eurobricks.com/forum/index.php?showtopic=83142
Edited by rm8
