I bought those on ebay from China for 13,90 USD for 4 pieces, free shipping worldwide. They were the 108mm diameter and zhey fit perfect, but not in the rims channels, if you put them there, they deform a bit...
  • Replies 703
Found these tires. They fit almost perfectly. Just a little tight causing the surface to bow in. Could be solved with some air pressure or foam
Edited by camaudio
Looks really nice!
They look like Axial Maxxis Trepador tires:
I see these a lot at my local hobby shop, they replaced my favorite Ripsaws with them. :look:
Edited by Victor Kojenov (TFOL)
Anyone tried 2.2" ? Is the same size of the wheel... 56mm
Theoretically, 2.2s are a better fit (in terms of dimensions), but you have to glue the tires. 1.9 fits with some light stretching, which is perfect for LEGO.
Looking at the dimensions, they should be able to fit.
It's not enough, i need to know for 99% I do not want to buy something that I will not use. :classic:
Here's an idea guys. What about tyres for the PP rims? Those are wider and should support a bigger tyre?
Dluders did some tests earlier, 2.2" tires fit pretty well on those rims:
Plumped & Normal Mounting of RC4WD Hollowpoint 2.2 Tires on Lego Power Pullers 22969 Wheels by dluders, on Flickr
The only thing is, PP wheels are a little wider than the 2.2" tires, so the tires look better when mounted on the inside of the outer flange (as seen on the right of the above picture).
I am looking for tires with diameter over 15cm that will fit to LEGO rim. Any ideas?
For those who are curious; this is main reason:
Edited by M_longer
The closest you'll get are probably these Mickey Thompson tires, which will fit the Power Puller wheels:
Dimensions:
- Outer Diameter: 5.84in / 148.5mm
- Width: 2.29in / 58.2mm
- Inner Diameter: 2.2in / 56mm
For those interested in the Good Year slicks. I have about 100 of them to sell.
$20 USD for 4 tires + Actual Shipping.
Dimensions:
- Outer Diameter: 3.78in / 96mm
- Total Width: 1.7in / 43mm
- Inner Diameter: 2.09in / 53mm
Weight: 4.8 Ounce / 136 Grams
Edited by camaudio
