BiFo Posted December 30, 2014 Posted December 30, 2014 (edited) Hey folks, I think I found possible matching tires regarding the 32020 rim (35mm outer diameter without the bigger ridges that run on the inside of the tire). Value in () is compared to 32019 Hollow tire Outer dia: 70mm (+ 7,6mm) Inner dia: 35mm (+/- 0mm) Width: 22mm (+ 2mm) http://www.afv-model...roducts_id=3501 Solid tire (don't know if these work) Outer dia: 76mm (+ 13,6mm) Inner dia: 35mm (+/- 0mm) Width: 24mm (+ 4mm) http://www.afv-model...roducts_id=1054 I'm fresh out of funding (yeah it's this time of year ) otherwise these could be nice on a slightly bigger version of the Grove GMK6400. Efferman's LAs should be still fine for that scale (maybe two are even better, oh the funding ) and the crane would look more to scale next to the truck wearing the 32019 that's supposed to pull the trailer with counterweights. Correct me if I'm wrong but in my head this setup looks gorgeous. Edited December 30, 2014 by BiFo Quote
probey Posted January 3, 2015 Posted January 3, 2015 Hey folks, I think I found possible matching tires regarding the 32020 rim (35mm outer diameter without the bigger ridges that run on the inside of the tire). Value in () is compared to 32019 Hollow tire Outer dia: 70mm (+ 7,6mm) Inner dia: 35mm (+/- 0mm) Width: 22mm (+ 2mm) http://www.afv-model...roducts_id=3501 Solid tire (don't know if these work) Outer dia: 76mm (+ 13,6mm) Inner dia: 35mm (+/- 0mm) Width: 24mm (+ 4mm) http://www.afv-model...roducts_id=1054 I'm fresh out of funding (yeah it's this time of year ) otherwise these could be nice on a slightly bigger version of the Grove GMK6400. Efferman's LAs should be still fine for that scale (maybe two are even better, oh the funding ) and the crane would look more to scale next to the truck wearing the 32019 that's supposed to pull the trailer with counterweights. Correct me if I'm wrong but in my head this setup looks gorgeous. Thanks BiFo, would love to try these tires out. Just wondering if you know any North America sources selling these tires? Attempt to buy 2 for 23 EUR to try them out, but the shipping cost is 42 EUR ...... Quote
rm8 Posted January 3, 2015 Posted January 3, 2015 Hey folks, I think I found possible matching tires regarding the 32020 rim (35mm outer diameter without the bigger ridges that run on the inside of the tire). Value in () is compared to 32019 Hollow tire Outer dia: 70mm (+ 7,6mm) Inner dia: 35mm (+/- 0mm) Width: 22mm (+ 2mm) http://www.afv-model...roducts_id=3501 Would like to see how this tires work with 42009's rims. Please, someone, test it:))) Quote
probey Posted January 4, 2015 Posted January 4, 2015 Another tire that may work with 32019, http://www.gardentrucking.com/details.tpl?action=search&cart=1420410948870397&eqskudatarq=1303&eqtitledatarq=Wheels05&eqvendordatarq=pmd Quote
BiFo Posted January 5, 2015 Posted January 5, 2015 @probey: No NA sources yet. The one you found quite possibly will not work. Outer dia: 65mm (+ 2,6mm) Inner dia: 32mm (- 3mm) Width: 17,5mm (- 4,5mm) The combination of smaller inner diameter and smaller width will stretch the tire too much I guess. Quote
AxeSlash Posted January 16, 2015 Posted January 16, 2015 (edited) Further to this thread, if anyone is interested in monster truck tyres (as an alternative to the Power Puller tyres), I've discovered that you CAN fit the tyres from a Tamiya Lunchbox / Midnight Pumpkin onto a pair of 44772 rims. I've got some pics but can't figure out how to post them on here without having to upload them to a separate server. There are only a few problems with this combination of tyre & rim: 1. You have to use two rims due to width of the tyre; this in itself isn't a problem, but pinning the two rims together without ending up with a 0.5L gap between them is a bit of a pain. 2. The bead of the tyres is stretched to it's limit - DON'T do this if you intend to use them on your Lunchbox / Midnight Pumpkin again, as I suspect they will become a bit loose after some time on the 44772's 3. Two 44772s are actually a tiny bit too wide for the tyre, so the sidewall bulges out a little bit in a slightly weird profile. 4. The bead is actually too wide for the 44772s, BUT it still fits due to how tight they are. It takes a bit of messing about to get them to fit on properly. 5. The look isn't exactly as I was hoping for; the rim diameter is too big compared to the overall diameter, so it looks like a very oldschool monster truck wheel from the 80s, rather than the modern trucks where the rim diameter is tiny in comparison. All of that said, they still look good. Caveat: the tyres feel very soft and I haven't got as far as mounting them onto a MOC yet, so it may be that they need some foam inners to support the weight of a PF-based MOC. I'm in the process of building a 1/15 Grave Digger with PF motors, so once that's complete I'll report back. Also I don't know how well they will steer due to the huge width. Edited January 16, 2015 by AxeSlash Quote
zux Posted January 16, 2015 Posted January 16, 2015 I've got some pics but can't figure out how to post them on here without having to upload them to a separate server.It is not really possible to host pictures here on EB, so you have to upload them on some external website/service first. As an example, you could setup Flickr account and use following guide to post your pics. Quote
Twelvebears Posted April 11, 2015 Posted April 11, 2015 A Lego Technic 9398 4x4 Crawler (with the Two Face 1.9 Offroad Scale Tires) crushed Stephanie's Cool Convertible! I'm working on a Wheeled Loader MOC and these will give a far more scale look than anything available from LEGO Real loader tyres have a very square profile and quite a tall sidewall, and those with the Volvo loader are simple far too small.. Quote
Block_Smarts Lego Technic Posted July 26, 2015 Posted July 26, 2015 Would these work? I still got 50$ in B-Day cash burning a hole in my pocket lol :thumbup: Quote
agrof Posted July 27, 2015 Posted July 27, 2015 (edited) Hi, i am not sure, what rim You would like to use, but 2.2 is too big for 9398 wheels. Go for 1.9 size, it will be perfekt. I own such ones in 96 mm, and work good - look good, cheap. http://www.ebay.com/...=item19f843c9a3 There are 90 and 108 mm versions on the market too. http://www.ebay.de/i...=item3f38787dfc Edited July 27, 2015 by agrof Quote
Dafgek81 Posted July 27, 2015 Posted July 27, 2015 On the 42030 you should use the rim off the 8265 loader and fit a tire with the outer diameter from the tires off the 42030 loader. On real wheel loaders, the rim is about half the hight off the complete wheel. Quote
JJ2 Posted August 12, 2015 Posted August 12, 2015 (edited) This is kind of the opposite of the topic but I found a way to get These wheels on a RED rim http://bricksafe.com...pg/800x1422.jpg http://bricksafe.com...pg/800x1422.jpg http://bricksafe.com...pg/800x1422.jpg Edited August 12, 2015 by JJ2 Quote
braker23 Posted August 12, 2015 Posted August 12, 2015 That is actually a neat idea. I am curious, how do the tires perform on off-road? Any tire slippage? Quote
nerdsforprez Posted August 12, 2015 Posted August 12, 2015 I dunno about others..... but a crawler I built a few years ago could never climb this terrain on LEGO tires. Third-party greatly increase performance. There are hundreds of such videos online demonstrating the same point. I am not sure of any specifically, but I will even bet there are some side-by-side comparisons. Quote
JJ2 Posted August 12, 2015 Posted August 12, 2015 That is actually a neat idea. I am curious, how do the tires perform on off-road? Any tire slippage? There is no slippage whatsoever The only thing is there is no way to mount the portal axles. I am working on that. Quote
Hakuberry Posted September 7, 2015 Posted September 7, 2015 I recently found out about some F1 race car moc instructions. Sadly, the prices for the wheels and tires were a lot more than I had anticipated. Are there any tires that will fit with the lego wheel or any wheel/tire combo that is similar in size to the lego wheel? Wheel 22969 and 44772 Quote
Vectormatic Posted September 8, 2015 Posted September 8, 2015 The front wheels arent too bad, but holy crap, $40 for rear wheels and tires... It does put the model in perspective though, i expected the fronts to be small wheels, but they are in fact the wheels on 42000, probably the biggest in my collection Quote
Blakbird Posted September 8, 2015 Posted September 8, 2015 I recently found out about some F1 race car moc instructions. Sadly, the prices for the wheels and tires were a lot more than I had anticipated. Are there any tires that will fit with the lego wheel or any wheel/tire combo that is similar in size to the lego wheel? Wheel 22969 and 44772 Sadly, those rear wheels and tires are unique. There is nothing else to match them in size and width, and they are perfect for F1 models (in fact that's what they were made for). Quote
Hakuberry Posted September 9, 2015 Posted September 9, 2015 Sadly, those rear wheels and tires are unique. There is nothing else to match them in size and width, and they are perfect for F1 models (in fact that's what they were made for). Thanks! Still can't believe the cost of these two tires/wheels is almost half of what I'm going to be spending on the remaining parts of the build Still worth though Quote
CisFran Posted September 9, 2015 Posted September 9, 2015 Wow, i bought a few months ago 4 sets of those F1 wheels for just $10. didn't know they cost that much now. and why is it the cost for the plain tires without print much higher than those with prints? Quote
Vectormatic Posted September 9, 2015 Posted September 9, 2015 Wow, i bought a few months ago 4 sets of those F1 wheels for just $10. didn't know they cost that much now. and why is it the cost for the plain tires without print much higher than those with prints? The prints dont match what would be on these kinds of MOCs, and wouldnt look right. I also guess that removing the print will probably ruin the look of the tire as well Quote
darsedz Posted September 9, 2015 Posted September 9, 2015 Lucky guy! For years, i've ever seen these tyres/wheels at "unapproriate" pricing :) in polish Allegro actual auctions "LEGO Technic Wheel 81,6 x 36" or LEGO Technic Wheel 81,6 x 36 -> approx 3.5 - 4.5 USD for 1 44772 rim + 56907 tire it's an "unapproriate" price?? Quote
z3_2drive Posted September 13, 2015 Posted September 13, 2015 The 1.55 Dirt grabbers are perfect for what I just finished building, but they are out of stock now :( Has anyone tested any tires in that scale that are also 75mm or less in size? Quote
