rm8 Posted May 23, 2018 Posted May 23, 2018 (edited) 32 minutes ago, efferman said: My RC4WDs are arrived. The Grip between rim and Tire is superb, but i think the foam insert should have a smaller inner diameter to fit into the large ringse inside the rim. Actually it feels a bit to soft against sideforces [ Driving test will follow when i find the time Thanks for feedback. May be you are right, side deformation is the moment we have to improve. And improving foam inserts can help. Any feedback will be useful to update product in the future Edited May 23, 2018 by rm8 Quote
rm8 Posted May 24, 2018 Posted May 24, 2018 (edited) Test drive! Review waiting for translation and will be shared ASAP Edited May 26, 2018 by rm8 Quote
rm8 Posted May 26, 2018 Posted May 26, 2018 (edited) May be you'l find it interesting: I did review with english translation subtitiles Edited May 26, 2018 by rm8 Quote
suffocation Posted August 18, 2018 Posted August 18, 2018 What tyres would you guys recommend for a heavy model (around 4.5 kg) with four planetary hubs, so with the tyres squeezed between two second-generation z56 turntables? Unimog and Claas tyres seem to pop out as soon as I press down on the model. Sample axle by @efferman with the planetary hubs I have in mind: Quote
efferman Posted August 18, 2018 Author Posted August 18, 2018 This type of hub works best with 1.9" third party crawler tires. Quote
suffocation Posted August 20, 2018 Posted August 20, 2018 Thanks, Efferman So these should be okay, if I'm not mistaken: https://www.amazon.it/gp/product/B07FCLHXBZ/ref=ox_sc_act_title_3?smid=A250KNM9XJL1LQ&psc=1 Quote
Ivan_M Posted September 6, 2018 Posted September 6, 2018 Anone ever trided something from AVF model shop? I'm particularly interested in this one: https://afv-model.com/52/Maßstab-1%3A16-LIV-und-Wolf-Reifen-Vollreifen Not the best thread, but the size would be very good for trucks in scale 21,5:1 - it would be possible to have duallies on Mack style truck. However the price is monstrous without knowing if it will fit any of the lego rim (and even if it fits it is bloody expensive) Quote
fosamax Posted September 26, 2018 Posted September 26, 2018 (edited) Hi I just registered to show you the result of budget tyres from ebay (less than 9 euros for a set of 4 tyres with foam insert). Those are the AUSTAR 3020 1.9inch Tires Tyres They fit quite well on 42077 rims even if you need to push a little toward the inside of the rim. Edited April 2, 2019 by fosamax Quote
TeamThrifty Posted September 26, 2018 Posted September 26, 2018 On 5/13/2018 at 6:01 PM, I_Igor said: BTW did anyone find 120mm tractor tire with self cleaning treads like CLAAS tires? Yes, well, 130mm... check out my Axion 960 moc thread. I'm currently building a Xerion at that scale, may start a wip thread for it soon. Quote
1gor Posted September 26, 2018 Posted September 26, 2018 7 minutes ago, TeamThrifty said: Yes, well, 130mm... check out my Axion 960 moc thread. I'm currently building a Xerion at that scale, may start a wip thread for it soon. I saw it and it looks nice (if I remember correctly I have even posted image of Axion 960 with tracks in your tread), but treads on 130mm tractor tire that you use are not the same, LEGO treads are more angled if you understand what I mean. Thank you for your honest intentions. It could be at the end that this tire introduced with Xerion will be the one and only tractor tire in LEGO production Quote
TeamThrifty Posted September 26, 2018 Posted September 26, 2018 i agree, they're not identical.. but, for me they're at least the correct agricultural pattern, so better than nothing! As you say, i doubt we will get a 120/130mm tyre from TLG unfortunately.. ..and on my new Xerion moc, they're all the same, so they at least match! Quote
1gor Posted September 27, 2018 Posted September 27, 2018 12 hours ago, TeamThrifty said: i agree, they're not identical.. but, for me they're at least the correct agricultural pattern, so better than nothing! As you say, i doubt we will get a 120/130mm tyre from TLG unfortunately.. ..and on my new Xerion moc, they're all the same, so they at least match! and as time passes I doubt that we will become smaller ones... I saw images of axles for your Xerion and it looks to me that you use orange clutch (from Chiron) as locking differential Quote
TeamThrifty Posted September 27, 2018 Posted September 27, 2018 52 minutes ago, I_Igor said: it looks to me that you use orange clutch (from Chiron) as locking differential You're right, i do! Its got all 3 diff's lockable using that orange clutch Quote
1gor Posted September 27, 2018 Posted September 27, 2018 4 hours ago, TeamThrifty said: You're right, i do! Its got all 3 diff's lockable using that orange clutch I'm afraid it would end up very huge. I'm fan of small scale mocs, but since I have several tractors build I'have decided to make something that could be mid-scale; scale 1:15 and use modified LEGO tires if I need, but with current tractor tire I have my limitations; probably biggest diameter that I could achieve is some 113mm without deformation...so I'll be continue o work on JCB fastrac and some tractors that size with 4 equal tire sizes...but I'm looking forward to see your version of Xerion. About 10 years ago I have build Saddle Trac with Powerpuller tires, but it looked to wide with them...your's would probably have much better proportions Quote
MultiDoc Posted December 12, 2018 Posted December 12, 2018 (edited) Resurrecting again this thread. I’m in the process of building Madoca’s Tatra 813, and I’d like to put on some aftermarket wheels on it. I understand @Blakbird has used some RC4WD ussr military tires on it with success (couldn’t find pics or info on this though) but these are out of production now. Anyone can suggest some tires that would work for this ? Rims are 42775. As for @rm8‘s specially built for Lego tires, they are excellent but only come on 1.55” Thanks in advance! P.S: do you think these would fit the rims and the Tatra well ? https://www.modelsport.co.uk/rc4wd-zt0052-rock-crusher-x-t-1-9-tires/rc-car-products/401737 Edited December 12, 2018 by MultiDoc Quote
fosamax Posted December 13, 2018 Posted December 13, 2018 (edited) I'm not sure which rim is the 42775. But I guess 15038 rims from 42077 (in red) or from 42070 (in yellow) should fit any 1.9" tires. You can see some budget ones mounted on red rims a few post above. Those are Austar 3020B. You can buy 4 of them (rim included) from Gearbest for less than 15 euros. The tires are not glued which is a plus if you want to use original lego rims. If not the austar rims can be used with lego with very little modification. Just need to enlarge a little the mounting hole and force a conical z12 wheel inside the rim. Then use a pair of pulley 4185 to mount the rim onto the steering hub. Edited April 2, 2019 by fosamax added picture Quote
MultiDoc Posted December 14, 2018 Posted December 14, 2018 (edited) Thanks for your input, after reading the whole thread twice and searching online everywhere I finally ordered a set from a UK based shop for Rock Crusher II X/T 1.9”. I’ll post any feedback as soon as I install them and test. Edited December 15, 2018 by MultiDoc Quote
gate Posted December 15, 2018 Posted December 15, 2018 Recently bought 130 mm huge crawler tires. Standard 56 mm lego rims are too small for them both length- and wide- wise. Found out that these 8462 tow truck rims are sitting perfect, but they are not wide enough. However used together with 62mm arocs wheels from the other side makes a perfect and strong combo, just enough to hook 8l axle with stop through portal hubs too. Quote
1gor Posted December 15, 2018 Posted December 15, 2018 (edited) @gate perhaps you could add this wheel together with wheel 70 X 28 futuristic... Edited December 15, 2018 by I_Igor Quote
MultiDoc Posted December 15, 2018 Posted December 15, 2018 Just received the Rock Crusher II tires made by RC4WD. I installed them on the rims and first impressions are good, they are extremely sticky, no comparison with the Lego counterparts. Now I need to start building my Tatra and will post how they do on it. Quote
gate Posted December 16, 2018 Posted December 16, 2018 13 hours ago, I_Igor said: @gate perhaps you could add this wheel together with wheel 70 X 28 futuristic... If only I had these. They might just be perfect here Quote
1gor Posted December 16, 2018 Posted December 16, 2018 Just now, gate said: If only I had these. They might just be perfect here If this info could be usefull https://www.bricklink.com/v2/catalog/catalogitem.page?P=32057#T=S&C=67&O={"color":67,"iconly":0} Quote
gate Posted December 16, 2018 Posted December 16, 2018 But I actually like how 62 mm tires sits in there, also providing 3 pins for connection Quote
1gor Posted December 16, 2018 Posted December 16, 2018 6 minutes ago, gate said: But I actually like how 62 mm tires sits in there, also providing 3 pins for connection You will know what suits you best... (Just for info; working on my latest project, I have decided not to use 3 points for connection, so I have skipped Xerion hubs) Quote
mpj Posted January 28, 2019 Posted January 28, 2019 Did anybody try these tires on lego rims? They are 1.9” so they should fit on 56mm rims, but the dimension I see in the photo is 48mm (inner hole) Option 1 (1.9”, 96mm) https://www.ebay.it/itm/1-9-1-10-96mm-OD-Rubber-Tyres-for-RC-Rock-Crawlers-RC-4wd-AXIAL-SCX10-CC01-4PCS/223220301269?hash=item33f8f77dd5:g:eBYAAOSwab1b4Q-T:rk:3:pf:0 Option 2 (1.9”, 95mm) https://www.ebay.it/itm/5pcs-RC-1-9-Rock-Crawler-Tires-Tyres-95mm-Fit-RC-4wd-Axial-1-9-Beadlock-wheels/173382540219?hash=item285e679bbb:g:8AoAAOSwWwtbM1Jp:rk:3:pf:0 Option 3 (1.9”, 90mm) https://www.ebay.it/itm/5pcs-1-9-Rock-Crawler-Tires-Tyre-90mm-Fit-RC4WD-Axial-1-9-Beadlock-Wheels-Rims/282605555574?hash=item41cc9a8f76:g:sEQAAOSwIIxZjAJY:rk:1:pf:0 Quote
