Posted June 15, 201212 yr Hi Everyone Im working on a LDD Modular Record Shop and I know how I want to build the store but I'm trying to figure out an idea for a sign for it. making words out of Lego is really the toughest part of building. Does any one have any ideas on how to make a sign that says records? I'm using a 16 stud wide base. Any ideas are welcome and would really help. They can be horizontal or vertical. It could even be a half record that sits on a 10 wide base. Thanks Charlie
June 16, 201212 yr Hi Charlie, I was just messing about in LDD and threw together a couple signs for you. The middle one is exactly 16 studs long, and for the "O" I would use a round 2x2 tile with the record sticker from the upcoming Haunted House, attached to a 1x2-2x2 bracket. The sign is built similar to the one from the Pet Shop modular building. Also, here are some rough overhead signs that you could attach to the front of the building so they stick out over the sidewalk. Let me know if you'd like the lxf file.
June 16, 201212 yr Hi Charlie I think I may of seen this on eurobricks a little while back from lgorlando; The dish used as a records is a neat idea!
June 16, 201212 yr Author Thank you both for the fantastic ideas. Malleable I love the vertical sign and the half record. I really appreciate the help. If I send you a pm with my email address is there any way you can email me the vertical sign file. I'm really no good with Lego letters. Thank you so much Charlie
