March 8, 20168 yr I put 1 large balloon tire inside 1 Power Puller tires; the PP wheels are too soft for this heavy MOC. If you look at the gearing of the frontloader, I replaced the 20 tooth gears with 12 tooth gears. Just a bit slower but the L-motors deliver adequate power. Which tires did you put inside?? I don't see what you mean about those gears for the frontloader? Edited March 8, 20168 yr by emielroumen
March 8, 20168 yr Absolut cool MOC! Thumbs up! Are you planning to use bigger tyres on the front axle? JB
March 9, 20168 yr I put 1 large balloon tire inside 1 Power Puller tires; the PP wheels are too soft for this heavy MOC. If you look at the gearing of the frontloader, I replaced the 20 tooth gears with 12 tooth gears. Just a bit slower but the L-motors deliver adequate power. Do you mean the ones on the actuators? Or somewhere else?
March 9, 20168 yr With larger front tires the swing axle would have to be adjusted quite a bit. The tires are per Jurgen's design in terms of size. Absolut cool MOC! Thumbs up! Are you planning to use bigger tyres on the front axle? JB Yes, on the actuators all larger gears have been replaced by 12 tooth gears (1:1). Do you mean the ones on the actuators? Or somewhere else?
