Yeah, you aren't kidding, you nearly have to disassemble a lot of the back part of the model just to put that tan frictionless pin. I decided to just take the boom off and rebuild the whole thing, and it does shift somewhat better, wish I had had known about this before I assembled the first time, but since the set was released in summer 2010 and I built it as soon as the upgraded LA's were shipped because of that issue, I wish I was aware of this problem with the changeover function so I could have installed the right gears and the pin...ah well one day I'll get to it...
I had the same problem with shifting, so I replaced the gray 5 legnth shaft from the motor with a 4 legnth so that it no longer was in the double friction pin. With this set up I found it shifted too fast so that it was impossible to hit neutral. So I also changed the gearing as was mentioned before and kept the blue friction pin. Taking it apart to change the parts isnt so hard, but getting it back together is a very big challenge with many shafts to insert and gears to have lined up. It works great now with consistant fast shifts and the ability to get it in neutral.
  • 10 years later...
Just bought this set second hand and saw this thread.
Although it's old it helped me, so that is why I'm replying.
The solution is:
Use a black 4 length shaft (instead of the grey 5 length), and more importantly use a gear with 12 teeth and a gear with 20 teeth! (the combination of an 8-24-gear does not fit with an L-shaped beam later on in the building process)
A link to a nice summary:
(FYI: for me the ''making the left track running smoothly" did not work)
Edited by Lukaz
