Lazarus Posted August 3, 2013 Posted August 3, 2013 (edited) Hello All. Just been getting some issues with LDD to Pov Ray tool, my rendering gets though about 30% and then stalls. Has worked before for me, have removed all software and added back on, removed any temp files that it leaves and still does it. Any clues. My pc has ample speed and graphics. Very high end system. Edited August 3, 2013 by Lazarus Quote
Mrcool1804 Posted August 7, 2013 Posted August 7, 2013 I am in need of someone to render a model done in LDD. I would like 5 different views at the highest resolution possible. I will pay via paypal and email the 5 files. The model is 1286 bricks. I would like this done ASAP. Please PM me with your price and a link to a render you have done before. Thanks! (I had this post in the 'Buy,Sell, Trade' Forum and it was suggested I come here. Quote
BEAVeR Posted August 29, 2013 Posted August 29, 2013 Hello everyone! First of all, I'd like to thank hrontos for giving us this very nice piece of software. Then, I have a question. I've made an all-white MOC. Now I want to render it, but it doesn't stand out against the white background. So I changed the color of the background to orange. But now, my MOC also looks kind of orange (because of the reflecting light, I guess). And that's completely not what I wanted. So I ask you this question: how can I render a white MOC with a colored background without the color of my model being affected? Thanks in advance! Quote
Classicsmiley Posted August 29, 2013 Posted August 29, 2013 Are you wanting to maintain the shadows on the ground plane? If not, you might try rendering with no ground plane and a transparent background, and then adding the background in an image editor. Quote
Sarles Posted September 1, 2013 Posted September 1, 2013 I'm an idiot apparently...I did this and it doesn't clear the error. Am I missing something? ; POV-Ray VERSION 3.6 ; ; SAMPLE POVRAY.INI FILE ; ; The general form of the options is "Variable=value". Everything ; between the equals sign and the end of the line is considered part ; of the value. The spacing and layout is free-form but only one option ; per line is allowed. Variables and values are not case-sensitive. ; ; Note: characters after a semi-colon are treated as a comment ; ; Traditional POV-Ray switches beginning with + or - are also allowed ; and they may be given with more than one switch per line. ; ; Add your own options at the bottom and/or edit these to suit. See the ; general documentation for full instructions on how to use INI options. ; ; Width of image in pixels. Accepts integer values. ; Width = 640 ; ; ; Height of image in pixels. Accepts integer values. ; Height = 480 ; ; Sets minimum number of objects before auto bounding kicks in. ; Bounding_Threshold = 3 ; ; ; Turn display on Display=On ; ; Turn verbose mode on Verbose=On ; ; Library_Path="\\.\LDDIncludes" ; Quote
Gnac Posted September 1, 2013 Posted September 1, 2013 You have a semicolon (;) in front of the Library_Path line. That essentially turns the line into a comment, which makes POV-Ray ignore it. Quote
Sarles Posted September 1, 2013 Posted September 1, 2013 So this is the correct file though? It seems awful generic. Quote
fareooo Posted September 4, 2013 Posted September 4, 2013 Hello all! I have a problem,when I "convert" the model. This bellow is the problem:"Could not find a part of the path:C:\Documents and Setting\myusername\AppData\LEGO Company\LEGO Digital Designer\db.lif" I need some help....Thank you:) Quote
Classicsmiley Posted September 4, 2013 Posted September 4, 2013 Did you change the "myusername" part to your actual username when you were setting up the paths? Quote
fareooo Posted September 4, 2013 Posted September 4, 2013 (edited) Yes, of course...:D Edited September 4, 2013 by fareooo Quote
Classicsmiley Posted September 4, 2013 Posted September 4, 2013 Ok, so when you paste that path (minus the db.lif), can you actually get to the correct folder? Quote
fareooo Posted September 5, 2013 Posted September 5, 2013 (edited) I'm agreed the "Don't generate includes",and after this I can converted the model:) But I have an another problem..This is:"Parse Error:Cannot open include file ldd_default_colors.inc" Edited September 5, 2013 by fareooo Quote
CM4Sci Posted September 6, 2013 Posted September 6, 2013 I just downloaded LDD2Povray, and when I try to make a render, I'm getting this message: LDD is closed..? I don't know what's wrong. If someone could help, please do! -Sci Quote
hrontos Posted September 6, 2013 Posted September 6, 2013 May be a stupid question: is it possible that you did not run LDD yet? This db.lif file is created by the LDD when it starts for the first time. And it is possible, that this file will be in a different location, since custom location can be specified in the LDD ini file. Could you please, search for the db.lif file on the disk? Quote
fareooo Posted September 7, 2013 Posted September 7, 2013 I'm agreed the "Don't generate includes",and after this I can converted the model.It's Okay (not ok-ey)?:S But I have an another..This is:"Cannot find file 'ldd_default_colors.inc',even after trying to append file type extension" I have the ldd2povrayconverter 32bit,and povray 3.7.RC7..:D Quote
hrontos Posted September 11, 2013 Posted September 11, 2013 I'm agreed the "Don't generate includes",and after this I can converted the model.It's Okay (not ok-ey)?:S But I have an another..This is:"Cannot find file 'ldd_default_colors.inc',even after trying to append file type extension" I have the ldd2povrayconverter 32bit,and povray 3.7.RC7..:D That checkbox serves mainly to allow conversion while LDD is running (since LDD is using db.lif file in exclusive mode, it cannot be read by the converter). If you do not generate includes at least when you convert some model for the first time, POV-Ray may miss some needed include files. You should find the file somewhere. Quote
fareooo Posted September 13, 2013 Posted September 13, 2013 That checkbox serves mainly to allow conversion while LDD is running (since LDD is using db.lif file in exclusive mode, it cannot be read by the converter). If you do not generate includes at least when you convert some model for the first time, POV-Ray may miss some needed include files. You should find the file somewhere. Thx,and how I can make includes? Quote
hrontos Posted September 14, 2013 Posted September 14, 2013 Please, first find the db.lif on your disk using windows search function. Then setup the db.lif path in the converter according to that. Quote
fareooo Posted September 14, 2013 Posted September 14, 2013 (edited) Please, first find the db.lif on your disk using windows search function. Then setup the db.lif path in the converter according to that. I'm maked this,but POV-Ray always write this:"Possible Parse Error:Cannot find file 'C:\Program Files\LDD Tools\LDD to POV-Ray Converter\LDDIncludes\T ',even after trying to append file type extension" Parse Error:Cannot open input file." Edited September 15, 2013 by fareooo Quote
hrontos Posted September 20, 2013 Posted September 20, 2013 Why is the POV-Ray trying to access that directory? Did you put it into some ini file? It should not be accessed directly by POV-Ray. Could you please, post your messages pane from the POV-Ray so that we will see what settings you have. Quote
The Real Indiana Jones Posted September 28, 2013 Posted September 28, 2013 (edited) Hi Hrontos, Your LDD to POV-Ray software is excellent, and it works beautifully! This was my first official test. The grid of cubes in the center shows all of the colors in the palette in order, except for two pink ones. The statues are metallic-gold and pearl-bronze. And this one, with the vexillum-banners, is a test of the metallic colors specifically. The two rows of hemispheres show all of the metallic and pearl-metallic tones. From left to right: the first is copper, then pearl-bronze (a.k.a. "legacy metallic sand yellow"), then pearl-iron (a.k.a. "titanium metallic"), then pearl-silver, chrome-silver, pearl-gold, and chrome-gold. The one thing I want to do next is to make those pearlescent-metallic colors look a little bit more shiny, like they do in LDD, and like they do in real life. I see that they definitely have a little bit more reflectivity than the standard plastic colors, but I think it should be increased a bit. Is there a way to do that with custom files? I see in the manual that you referred to custom files called "ldd_best_finishes.inc", "ldd_best_materials.inc", and "ldd_best_part_materials.inc". I ran a search for them, but I do not have them. Is there a way to get them? And will they make those pearl-metallic colors look more pearlescent or lustrous? I'm working on a huge Ancient World project, so I want to make sure that all of the metals, especially bronze and iron, look their best! You can see images of it in post #180 and #184 of my thread here. Thanks! Excellent Work! therealindy Edited September 28, 2013 by The Real Indiana Jones Quote
hrontos Posted September 30, 2013 Posted September 30, 2013 Your models look really great great. Files having names starting with ldd_best_ do not exist in real life, they were just examples of files with custom settings. You can take ldd_finishes.inc, copy it to ldd_my_finishes.inc and try to make custom settings. Metallic materials are tricky to render, they need some nice surrounding environment to reflect, so finding realistic looking definition may require a lot of work. Pearl finishes are even more complex. If you will improve them, please, share the definition with us. Quote
Nachapon Lego Posted October 1, 2013 Posted October 1, 2013 (edited) I'm working on a huge Ancient World project, so I want to make sure that all of the metals, especially bronze and iron, look their best! For chrome, you can try to use sky shere image as environment to reflect (in Radiosity tab). cmf gold by Nachapon S., on Flickr Lego Opera house gold, LDD file base on 10234 by pbat by Nachapon S., on Flickr Edited October 1, 2013 by bbqqq Quote
The Real Indiana Jones Posted October 1, 2013 Posted October 1, 2013 (edited) Metallic materials are tricky to render, they need some nice surrounding environment to reflect, so finding realistic looking definition may require a lot of work. Pearl finishes are even more complex. For chrome, you can try to use sky shere image as environment to reflect (in Radiosity tab). Wow, this is all excellent work, both of you! And I see that bbqqq did a chrome-red Iron Man torso. How did you do that? I could probably use the same method to adjust the pearl-metals' reflectiveness upwards to be closer the chrome colors. P.S. - They also look nice and vibrant with great contrast. Do you just edit them in PhotoShop afterwards, or do you adjust the lighting/palette beforehand in some way? What standard default settings do you usually use? Edited October 6, 2013 by The Real Indiana Jones Quote
