drakmin Posted August 19, 2017 Author Posted August 19, 2017 (edited) 19 minutes ago, dmaclego said: I hope it's not too late to ask this question but... Do you trust your blueprints 100%? The rear landing gear you built according to your blueprints does not look exactly like the real thing. The struts are paralel in your version, while in the film it's clear that only the rear strut is vertical, while the front one is somewhat slanted towards the rear one. This is a good question which I have considered for a long time. In the movies and most scale models the read landing gear seems to be built like in the image below. I think they didn't have to build a version where the landing gear actually fits inside the engine with all the mechanics and is foldable. Also, the geometry like shown below is almost impossible to build so that it would fold inside any reasonable amount of space. I think the movie version is built only thinking about the 1:1 scale models stability on ground on the set. I will build my version like in the next blueprint below. Parallel landing gear struts allow for simple rotational movement and quite compact space when folded. Actually even this parallel version was quite close to impossible to build so that it would fit yet carry the weight of the ship. So basically it is a trade between looking exactly like in the movie or to be functional. Generally I have learnt in many movies the scale models are quite different for each shot :D For example with the snowspeeder the flight model would not fit pilots legs etc. so some compromise and interpretation must be made. Hopefully you can now see my solution acceptable :D Edited August 19, 2017 by drakmin Quote
dmaclego Posted August 19, 2017 Posted August 19, 2017 Just now, drakmin said: Parallel landing gear struts allow for simple rotational movement The key word here being "simple" :) . Come on, you are building a very impressive, beautiful, huge scale model here! No place for compromises! Don't go the "simple" way; make your model so that no-one (a grumbling old fart like me, for instance :) ) can say "nice build but could have been better"! Please, don't read all these exclamation marks as scolding - I'm just trying to cheer you, to make you try even harder, because I believe you can :) . Quote
drakmin Posted August 19, 2017 Author Posted August 19, 2017 2 minutes ago, dmaclego said: Please, don't read all these exclamation marks as scolding - I'm just trying to cheer you, to make you try even harder, because I believe you can :) . Hmm, not sure at all if I can make it the 100% correct rear landing gear geometry. Atleast in this scale since it would need variable lenght for each landing gear strut to make them fold. I must remind that the model weights like 20kg :D Later when I see if the wings currently hold the laser cannons horizontal I can see if I can remove some wing structure to have more space for the landing gear mechanism but I doubt it heavily with the current information. Happily I have built everything in pretty modular way so it is always possible the revisit one design area later! Quote
dmaclego Posted August 19, 2017 Posted August 19, 2017 Having finished a 200 kg model recently, I know exactly what you mean when talking about strain in the structure ;) . OK, I did my duty and i'm not going to nag you anymore. Good luck with your project - you're gonna need it, as Han said ;) . Quote
drakmin Posted August 19, 2017 Author Posted August 19, 2017 (edited) I will try to improve it but later :D Actually there might be a solution of making only the front struts upper pivot movable so it could slide more close to the front of the engine when landing gear is fully opened. Edited August 19, 2017 by drakmin Quote
drakmin Posted August 21, 2017 Author Posted August 21, 2017 (edited) On 19.8.2017 at 11:31 AM, dmaclego said: The struts are paralel in your version, while in the film it's clear that only the rear strut is vertical, while the front one is somewhat slanted towards the rear one. I now have this new prototype: Edited August 21, 2017 by drakmin Quote
LOBOT-OMY Posted August 21, 2017 Posted August 21, 2017 Perfect ! But how do you move the front strut back into the parallel position for retraction of the landing gear into the fuselage? Quote
dmaclego Posted August 21, 2017 Posted August 21, 2017 2 hours ago, drakmin said: I now have this new prototype: Mission accomplished, then :) . I knew you could do this. Good luck with the rest of your X-wing! Quote
kieran Posted August 22, 2017 Posted August 22, 2017 The new landing gear is a ver elegant solution, I hope it works out when fully loaded Quote
drakmin Posted October 13, 2017 Author Posted October 13, 2017 Image dump aligns quite ok with blueprints some shaping to do around canopy inspecting bricklink order :) Quote
sokewl Posted October 13, 2017 Posted October 13, 2017 On 13/10/2017 at 8:29 AM, drakmin said: Image dump *Snip* aligns quite ok with blueprints really great work. could you post this without the finelined white lines so we could see the model itself? or a pic of the whole thing until now? the nose looks really accurate now :) Quote
DWJ2018 Posted October 29, 2017 Posted October 29, 2017 Exceptional concept and implementation. Could be a master piece when complete. Quote
Jim Posted October 29, 2017 Posted October 29, 2017 2 hours ago, DWJ2018 said: Could be... Will be... Quote
Miro78 Posted October 29, 2017 Posted October 29, 2017 Oh man, this project is so fun to follow. Thanks for allowing us to watch this evolve. What a fun yet technically challenging project. Quote
All in the Reflexes Posted October 29, 2017 Posted October 29, 2017 You know its a massive model but when you see that cup of tea next to the engine/landing gear.......ermergherd its hueeeerge! Quote
Gene Posted October 29, 2017 Posted October 29, 2017 Still following this engineering building progress. Quote
jemakrol Posted December 15, 2017 Posted December 15, 2017 This has to be the most awesome Lego project I've ever seen. The attention to detail is simply out of this world! I've dreamt about doing the X-wing in this size with landing gear and all. Now I can't wait to see you progress with this one! The whole SW-universe is filled with things that are made to look good in the movies, but does not have a design intended to be functional or even realistic (dimension wise, placement wise etc etc). Just trying to make this X-wing work with respect to that is a feat by itself! Quote
drakmin Posted March 28, 2018 Author Posted March 28, 2018 Small update! I've been lately working on the top and rear greebling. Here are first versions of those. Quote
atlas Posted March 29, 2018 Posted March 29, 2018 Amazing. The top part looks just like the miniatures. I think you have even included the angled-down seam of the top sides of the fuselage behind the cockpit. Never seen anyone try that before - granted this thing is huge, but it's incredibly impressive nonetheless, especially with mostly technic parts. It's going to be beautiful when completed, I'm sure Quote
drakmin Posted March 29, 2018 Author Posted March 29, 2018 5 hours ago, atlas said: I think you have even included the angled-down seam of the top sides of the fuselage behind the cockpit. Never seen anyone try that before - granted this thing is huge, but it's incredibly impressive nonetheless, especially with mostly technic parts. Yup! Sharp eyes and thanks! Actually the large scale allows but also demands for this angled seam. Here's an older photo of the seam: Quote
atlas Posted March 29, 2018 Posted March 29, 2018 Man, wow. I can't really see a single thing that's out of place. Keep doing what you're doing, because it's working, regardless of the time it's taking. Like I said, can't wait for it to be completed, it'll be a real sight. Quote
drakmin Posted April 3, 2018 Author Posted April 3, 2018 (edited) Does anyone have any ideas or suggestions on how to solve the astromech droid? The round part needs to be 5 studs in diameter :) Below you can see 4 studs version and it looks (and is) too small :) Edited April 7, 2018 by drakmin Quote
