If your loader is based on a JCB 310, then does the extra pneumatics (nearer the pivot of the boom) act as a sway control for the boom, and if you removed them, would it make any difference?
Also I think you have too much headstock, causing the boom to remain too level at it's lowest point. The challenge is that you end up cutting into the area for the front axle. I made a 310 and faced similar problems.
But a good model and well done with the pneumatics.
No they are extra lift cylinders just like the real one,I am happy with how the arm is pivoted If I moved this any more I would loss a bit of hight once it is at max reach and also hit the front axle.
They are both great Ryan :wink::classic::thumbup::wub:
Thanks
It's not hard to better your stuff....... :tongue::roflmao::head_back:
Edited by Alasdair Ryan
Good too see that you can even improve yourself :grin:
I like your studded truck a lot, but your second chassis look amazing, whit many futures in it, what kind off truck your build on that one?
Edited by VFracingteam
The studless truck will be based on this with 12 functions. :blush:
Trekman I think I have edited the pivot point come to think about it,in the latest video the boom should be better pivoted. :classic:
