Sebeus I Posted September 10, 2012 Posted September 10, 2012 (edited) Question: in the XL tables you need to decide wether your ship is built below waterline or not... how does this work for a ship built on prefab hulls ? And another thing, so far my ship doesn't seem to be very fast; only 5,1 knots, maybe that's because I don't have enough sails Btw, it's the Intersector I'm talking about. Just to be sure, the beam is the widest part of the hull right ? I also weighed my ship and then I see the cannons make up additional weight, it's kind of strange because my ship is 76 tons (scaled) while the cannons make 24,8 tons. confusing proportions I must say, maybe I did something wrong. Edited September 10, 2012 by Sebeus I Quote
Horry Posted September 12, 2012 Author Posted September 12, 2012 Question: in the XL tables you need to decide wether your ship is built below waterline or not... how does this work for a ship built on prefab hulls ? And another thing, so far my ship doesn't seem to be very fast; only 5,1 knots, maybe that's because I don't have enough sails Btw, it's the Intersector I'm talking about. Just to be sure, the beam is the widest part of the hull right ? I also weighed my ship and then I see the cannons make up additional weight, it's kind of strange because my ship is 76 tons (scaled) while the cannons make 24,8 tons. confusing proportions I must say, maybe I did something wrong. Sorry, I only noticed your reply now! prefabs are considered to be not built below the waterline. 76 tons would indeed be a light-weight and might explain the low speed. If you would give your measured specs I will check it out. Quote
Sebeus I Posted September 12, 2012 Posted September 12, 2012 (edited) Sorry, I only noticed your reply now! prefabs are considered to be not built below the waterline. 76 tons would indeed be a light-weight and might explain the low speed. If you would give your measured specs I will check it out. Hull length= 46 cm beam=12,5 cm Weight = 1 kg Square-Rigged Sail Area = 900 cm2 Lateen-Rigged Sail Area = 400 cm2 12 lb Long Gun x 12 When I open the tables it does say there's something it can't solve, yet there are results for draft, speed and square movements. This is kind of lame but perhaps I should just make the ship heavier...by litterally putting some weight in the hold I made the Intersector with quite a minimalistic vision. Edited September 12, 2012 by Sebeus I Quote
Lord William kane Posted August 1, 2016 Posted August 1, 2016 Yeah it sounds fun but my ship is very bad it's only a 10 gun brig and I only have one ship and it the brick bounty Quote
Capn Frank Posted August 1, 2016 Posted August 1, 2016 Yeah it sounds fun but my ship is very bad it's only a 10 gun brig and I only have one ship and it the brick bounty Please refrain from bumping old topics. This topic hasn't been active in three years and the member who started the topic hasn't logged in two years. Please see Bumping Old Topics and review the Site Guidelines You should check out Brethren of the Brick Seas, where you work with a faction to rule the Brick Seas with your builds. Quote
