vwpint Posted August 14, 2012 Posted August 14, 2012 Is the suspension strong enough? If i look the picture the suspension is at the bottom.(bad english) Quote
efferman Posted August 14, 2012 Author Posted August 14, 2012 (edited) i think the black springs was the right decission. at a flat surface the springs are compressed one third. so i have a good flex on uneven terrain. i dont understand why the tatras in the lego truck trial vids has on a flat surface a fully extended suspension. if there is a hole on the ground every other spring must first be compressed, before the tire above the hole can get contact to ground again. in my eyes this is not good for traction and on side slopes it let the tatras making easier a side roll. my spring setup would give them more ground contact and a lower center of gravity. Edited August 14, 2012 by efferman Quote
z3_2drive Posted August 14, 2012 Posted August 14, 2012 similar to the "droop" setup suspensions for rc and real life crawlers, I agree better for traction Quote
allanp Posted August 14, 2012 Posted August 14, 2012 This is awesome, makes me wanna build something similar except with two buggy motors under the hood Quote
z3_2drive Posted August 14, 2012 Posted August 14, 2012 This is awesome, makes me wanna build something similar except with two buggy motors under the hood v2 receiver comes in handy! tested in my nearly finished MOC, one buggy motor on one output, servo on other, goes faster and much more responsive Quote
allanp Posted August 14, 2012 Posted August 14, 2012 v2 receiver comes in handy! tested in my nearly finished MOC, one buggy motor on one output, servo on other, goes faster and much more responsive Ah ha! Thanks for the info Quote
Andrew Page Posted August 14, 2012 Posted August 14, 2012 Love the way the body panels came out. I often do not love stud-less Technic bodies, but this one is great. Nice job. Quote
88high Posted August 14, 2012 Posted August 14, 2012 (edited) @efferman Whenever I come across that dilemma I always take apart the MOC in modules or I take a look at the model really closely and I can replicate or build the sections of the model and make the whole axles and such:) Or, you can dissasemble AND take pics at the same time, and use those pics to rebuild your TruckTrial:) Edited August 14, 2012 by 88high Quote
efferman Posted August 15, 2012 Author Posted August 15, 2012 (edited) i will see what i can do i have began with building a second chassis (a bit improved) for the instruction. for the new motors iam using dummys 100_9572 von efferman auf Flickr Edited August 15, 2012 by efferman Quote
Zerobricks Posted August 16, 2012 Posted August 16, 2012 Now that looks like a hard-core chassis Quote
efferman Posted August 16, 2012 Author Posted August 16, 2012 good news, the G-Class pickup will stay alive. i have made a small order a few minutes ago [New] Light Bluish Gray Electric, Motor 9V Power Functions L with Dark Bluish Gray Bottom (x2) ..... EUR 16.70 each = EUR 33.40[New] Light Bluish Gray Electric, Motor 9V Power Functions Servo with Dark Bluish Gray Bottom (x2) ..... EUR 24.80 each = EUR 49.60 because the axles are identical i can make a instruction without dissassembling the G Quote
BrickPicker Posted August 16, 2012 Posted August 16, 2012 WOW...I can't believe that is made from LEGO bricks. Quote
Edwin Korstanje Posted August 16, 2012 Posted August 16, 2012 Great chassis, You have make a very lite and strong chassis for it Quote
bord4kop Posted August 18, 2012 Posted August 18, 2012 Excellent work Effe, brilliant!! Your standards seem to get higher and higher each time As I saw on the German forum, it took quite some time to engineer.. You are not satisfied easy are you? Quote
efferman Posted August 18, 2012 Author Posted August 18, 2012 well, iam not often satisfied. easy to see at my many unfinished mocs Quote
Morj Posted August 19, 2012 Posted August 19, 2012 well, iam not often satisfied. easy to see at my many unfinished mocs Raising the bar is a good thing if you have enough self-confidence :) Quote
efferman Posted August 20, 2012 Author Posted August 20, 2012 (edited) the instruction for the frame is finished. here some steps all steps on flickr and brickshelf it may take several days til lthe brickshelf folder is online Edited August 20, 2012 by efferman Quote
efferman Posted August 23, 2012 Author Posted August 23, 2012 (edited) the pictoral instruction is finished. here some steps axle047 von efferman auf Flickr all steps are available at flickr and brickshelf Edited August 25, 2012 by efferman Quote
_techniclego55_ Posted August 25, 2012 Posted August 25, 2012 Nice Building Instructions.. :) I really like the design of the axle Quote
timslegos Posted August 25, 2012 Posted August 25, 2012 Thanks for the instructions effe! :thumbup: tim Quote
vwpint Posted August 25, 2012 Posted August 25, 2012 How long and wide is the body work(studs)? Quote
efferman Posted August 25, 2012 Author Posted August 25, 2012 thanks guys the body (with fenders) is 27 studs wide and overall 58 studs long Quote
vwpint Posted August 25, 2012 Posted August 25, 2012 One more question, im asking beacuse i m building something like your mercedes .Did you use solution 1 or 2? Quote
