Ok, after some thinking, I have narrowed the search between 8880, 8448 and 9398!
The 8466 I liked only for doors, wheels, and panels, while the 8480 for its realism.
OK, from your remaining choices, I recommend:
1) IF you want to be able to "drive" your Lego set using onboard motors, then select the 9398 4x4 Crawler.
2) IF you want a "classic" Lego Technic set, then select the 8880 Super Car.
3) IF you want to be able to build FOUR ADDITIONAL models (besides the standard "A" and "B" models), then select the 8448 Super Street Sensation because you could build a Concept Car, Racer, Hot Rod, and Buggy alternate too. :classic:
Edited by DLuders
8880 is best, Done!
Meh, it's just a car. And it's studded.. If you're down for that you should take the 8880.
On the other hand the new Crawler (9398) is something else. Maybe not as awesome as a super car it's playability is much higher,
Plus you get the new PF motors which can be used in future studless models.
I Myself would buy something 'future-proof' thus ending up buying the new crawler.
Ok, I have updated my list to these sets. (some aren't technic but are mostly built with technic.) 8653, 8448, 8674, 8145 and lastly......... 9398. If I get a cheaper one I'll buy maybe a rc buggy motor or pf servo/L.
Thanks for your comments and support, I appreciate it!
Also, I'm into building supercars, (1:10 scale) and trtr, but I need more parts! If anyone could sell me some spare parts I would appreciate it!
Your best bet for parts is on bricklink and ebay,over time you will build up your part's to build bigger models.
-_- I know how to use bricklink. :hmpf_bad:
That's not very nice......
Edited by Alasdair Ryan
They are all made of Lego.
lol... true but, the older studded ones are harder to modify IMO because you would need old studded technic pieces. The 9398 is very easy to modify, its already been proven...default_classic.gif
